Hey thanks for the response. Not sure what you meant by restarting the Account thing but i just deleted them and re-added them and got the same result. here are the logs from when i removed them, restarted the binding, and then added them back.
EDIT: See my post directly below this one
2021-09-11 22:11:15.502 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'myq:garagedoor:6bfdf9c223' changed from UNKNOWN to REMOVING
2021-09-11 22:11:15.503 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'myq:garagedoor:6bfdf9c223' changed from REMOVING to REMOVED
2021-09-11 22:11:15.506 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'myq:garagedoor:6bfdf9c223' changed from REMOVED to UNINITIALIZED
2021-09-11 22:11:15.510 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'myq:garagedoor:6bfdf9c223' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2021-09-11 22:11:30.032 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'myq:account:5b6a6d1cde' changed from ONLINE to REMOVING
2021-09-11 22:11:30.033 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'myq:account:5b6a6d1cde' changed from REMOVING to REMOVED
2021-09-11 22:11:30.038 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'myq:account:5b6a6d1cde' changed from REMOVED to UNINITIALIZED
2021-09-11 22:11:30.038 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'myq:account:5b6a6d1cde' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2021-09-11 22:12:12.510 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'myq:account:77ab746642' changed from UNINITIALIZED to INITIALIZING
2021-09-11 22:12:12.511 [DEBUG] [q.internal.handler.MyQAccountHandler] - Sending GET to https://partner-identity.myq-cloud.com/connect/authorize?
client_id=IOS_CGI_MYQ&code_challenge=SSvQ1gje4Odo5Rr-Woj8z9wMm8Z4jWI-ZCu6Ui_8dAk&code_challenge_method=S256&redirect_uri=com.myqops%3A%2F%2Fios&response_type=code&scope=MyQ_Residential+offline_access
2021-09-11 22:12:12.512 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'myq:account:77ab746642' changed from INITIALIZING to UNKNOWN
2021-09-11 22:12:12.891 [DEBUG] [q.internal.handler.MyQAccountHandler] - Login Code 200 Response <!DOCTYPE html>
<title>MyQ Security</title>
<form action="/api/Account/LoginWithEmail?returnUrl=%2Fconnect%2Fauthorize%2Fcallback%3Fclient_id%3DIOS_CGI_MYQ%26code_challenge%3DSSvQ1gje4Odo5Rr-Woj8z9wMm8Z4jWI-ZCu6Ui_8dAk%26code_challenge_method%3DS256%26redirect_uri%3Dcom.myqops%253A%252F%252Fios%26response_type%3Dcode%26scope%3DMyQ_Residential%2520offline_access" method="post"><input id="ReturnUrl" name="ReturnUrl" type="hidden" value="/connect/authorize/callback?client_id=IOS_CGI_MYQ&code_challenge=SSvQ1gje4Odo5Rr-Woj8z9wMm8Z4jWI-ZCu6Ui_8dAk&code_challenge_method=S256&redirect_uri=com.myqops%3A%2F%2Fios&response_type=code&scope=MyQ_Residential%20offline_access" /> <div class="form-fields">
<a href="/api/Account/ForgotPassword?returnUrl=%2Fconnect%2Fauthorize%2Fcallback%3Fclient_id%3DIOS_CGI_MYQ%26code_challenge%3DSSvQ1gje4Odo5Rr-Woj8z9wMm8Z4jWI-ZCu6Ui_8dAk%26code_challenge_method%3DS256%26redirect_uri%3Dcom.myqops%253A%252F%252Fios%26response_type%3Dcode%26scope%3DMyQ_Residential%2520offline_access" class="link">
2021-09-11 22:12:12.944 [DEBUG] [q.internal.handler.MyQAccountHandler] - Posting Login to https://partner-identity.myq-cloud.com/api/Account/LoginWithEmail?returnUrl=%2Fconnect%2Fauthorize%2Fcallback%3Fclient_id%3DIOS_CGI_MYQ%26code_challenge%3DSSvQ1gje4Odo5Rr-Woj8z9wMm8Z4jWI-ZCu6Ui_8dAk%26code_challenge_method%3DS256%26redirect_uri%3Dcom.myqops%253A%252F%252Fios%26response_type%3Dcode%26scope%3DMyQ_Residential%2520offline_access
2021-09-11 22:12:12.989 [DEBUG] [q.internal.handler.MyQAccountHandler] - Redirect Login: Code 302 Response
2021-09-11 22:12:12.989 [DEBUG] [q.internal.handler.MyQAccountHandler] - location string /connect/authorize/callback?client_id=IOS_CGI_MYQ&code_challenge=SSvQ1gje4Odo5Rr-Woj8z9wMm8Z4jWI-ZCu6Ui_8dAk&code_challenge_method=S256&redirect_uri=com.myqops%3A%2F%2Fios&response_type=code&scope=MyQ_Residential%20offline_access
2021-09-11 22:12:13.037 [DEBUG] [q.internal.handler.MyQAccountHandler] - Redirect Login: Code 302 Response
2021-09-11 22:12:13.038 [DEBUG] [q.internal.handler.MyQAccountHandler] - location string com.myqops://ios?code=9566C1E37CF82AB28C3A8B813A26D6FEE3303953F1A6E76AD5BD96FCD711C3FF&scope=MyQ_Residential%20offline_access&iss=https%3A%2F%2Fpartner-identity.myq-cloud.com
2021-09-11 22:12:13.038 [DEBUG] [q.internal.handler.MyQAccountHandler] - Login Response URI com.myqops://ios?code=9566C1E37CF82AB28C3A8B813A26D6FEE3303953F1A6E76AD5BD96FCD711C3FF&scope=MyQ_Residential%20offline_access&iss=https%3A%2F%2Fpartner-identity.myq-cloud.com
2021-09-11 22:12:13.095 [DEBUG] [q.internal.handler.MyQAccountHandler] - Login Code 200 Response {"access_token":"","expires_in":3600,"token_type":"Bearer","refresh_token":"","scope":"MyQ_Residential offline_access"}
2021-09-11 22:12:13.096 [DEBUG] [q.internal.handler.MyQAccountHandler] - Login Token response {"access_token":"","expires_in":3600,"token_type":"Bearer","refresh_token":"","scope":"MyQ_Residential offline_access"}
2021-09-11 22:12:13.339 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'myq:account:77ab746642' changed from UNKNOWN to ONLINE
2021-09-11 22:13:24.467 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'myq:garagedoor:77ab746642:187da3b583' changed from UNINITIALIZED to INITIALIZING
2021-09-11 22:13:24.469 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'myq:garagedoor:77ab746642:187da3b583' changed from INITIALIZING to UNKNOWN
2021-09-11 22:17:49.405 [DEBUG] [nding.myq.internal.MyQHandlerFactory] - bundle org.openhab.binding.myq:3.2.0.202108311743 (275)[org.openhab.binding.myq.internal.MyQHandlerFactory(322)] : Querying state active
2021-09-11 22:17:49.405 [DEBUG] [nding.myq.internal.MyQHandlerFactory] - bundle org.openhab.binding.myq:3.2.0.202108311743 (275)[org.openhab.binding.myq.internal.MyQHandlerFactory(322)] : Deactivating component
2021-09-11 22:17:49.406 [DEBUG] [nding.myq.internal.MyQHandlerFactory] - bundle org.openhab.binding.myq:3.2.0.202108311743 (275)[org.openhab.binding.myq.internal.MyQHandlerFactory(322)] : registration change queue [unregistered]
2021-09-11 22:17:49.408 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'myq:garagedoor:77ab746642:187da3b583' changed from UNKNOWN to UNINITIALIZED
2021-09-11 22:17:49.412 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'myq:garagedoor:77ab746642:187da3b583' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2021-09-11 22:17:49.414 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'myq:account:77ab746642' changed from ONLINE to UNINITIALIZED
2021-09-11 22:17:49.417 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'myq:account:77ab746642' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2021-09-11 22:17:49.417 [DEBUG] [nding.myq.internal.MyQHandlerFactory] - bundle org.openhab.binding.myq:3.2.0.202108311743 (275)[org.openhab.binding.myq.internal.MyQHandlerFactory(322)] : Querying state active
2021-09-11 22:17:49.418 [DEBUG] [nding.myq.internal.MyQHandlerFactory] - bundle org.openhab.binding.myq:3.2.0.202108311743 (275)[org.openhab.binding.myq.internal.MyQHandlerFactory(322)] : getting deactivate: deactivate
2021-09-11 22:17:49.418 [DEBUG] [nding.myq.internal.MyQHandlerFactory] - bundle org.openhab.binding.myq:3.2.0.202108311743 (275)[org.openhab.binding.myq.internal.MyQHandlerFactory(322)] : Locating method deactivate in class org.openhab.binding.myq.internal.MyQHandlerFactory
2021-09-11 22:17:49.418 [DEBUG] [nding.myq.internal.MyQHandlerFactory] - bundle org.openhab.binding.myq:3.2.0.202108311743 (275)[org.openhab.binding.myq.internal.MyQHandlerFactory(322)] : Declared Method org.openhab.binding.myq.internal.MyQHandlerFactory.deactivate([interface org.osgi.service.component.ComponentContext]) not found
2021-09-11 22:17:49.419 [DEBUG] [nding.myq.internal.MyQHandlerFactory] - bundle org.openhab.binding.myq:3.2.0.202108311743 (275)[org.openhab.binding.myq.internal.MyQHandlerFactory(322)] : Locating method deactivate in class org.openhab.core.thing.binding.BaseThingHandlerFactory
2021-09-11 22:17:49.419 [DEBUG] [nding.myq.internal.MyQHandlerFactory] - bundle org.openhab.binding.myq:3.2.0.202108311743 (275)[org.openhab.binding.myq.internal.MyQHandlerFactory(322)] : Found deactivate method: protected void org.openhab.core.thing.binding.BaseThingHandlerFactory.deactivate(org.osgi.service.component.ComponentContext)
2021-09-11 22:17:49.419 [DEBUG] [nding.myq.internal.MyQHandlerFactory] - bundle org.openhab.binding.myq:3.2.0.202108311743 (275)[org.openhab.binding.myq.internal.MyQHandlerFactory(322)] : invoking deactivate: deactivate: parameters [org.apache.felix.scr.impl.manager.ComponentContextImpl]
2021-09-11 22:17:49.420 [DEBUG] [nding.myq.internal.MyQHandlerFactory] - bundle org.openhab.binding.myq:3.2.0.202108311743 (275)[org.openhab.binding.myq.internal.MyQHandlerFactory(322)] : invoked deactivate: deactivate
2021-09-11 22:17:49.421 [DEBUG] [nding.myq.internal.MyQHandlerFactory] - bundle org.openhab.binding.myq:3.2.0.202108311743 (275)[org.openhab.binding.myq.internal.MyQHandlerFactory(322)] : DependencyManager: $001 close component unbinding from org.apache.felix.scr.impl.manager.ComponentContextImpl@27d3d7dd at tracking count 2 refpairs: [[RefPair: ref: [{org.openhab.core.auth.client.oauth2.OAuthFactory}={service.id=338, service.bundleid=157, service.scope=bundle, component.name=org.openhab.core.auth.oauth2client.internal.OAuthFactoryImpl, component.id=51}] service: [org.openhab.core.auth.oauth2client.internal.OAuthFactoryImpl@5ed65388]]]
2021-09-11 22:17:49.421 [DEBUG] [nding.myq.internal.MyQHandlerFactory] - bundle org.openhab.binding.myq:3.2.0.202108311743 (275)[org.openhab.binding.myq.internal.MyQHandlerFactory(322)] : DependencyManager: $000 close component unbinding from org.apache.felix.scr.impl.manager.ComponentContextImpl@27d3d7dd at tracking count 1 refpairs: [[RefPair: ref: [{org.openhab.core.io.net.http.HttpClientFactory, org.openhab.core.io.net.http.WebSocketFactory}={service.id=267, service.bundleid=177, service.scope=bundle, component.name=org.openhab.core.io.net.http.internal.WebClientFactoryImpl, component.id=135}] service: [org.openhab.core.io.net.http.internal.WebClientFactoryImpl@431420dd]]]
2021-09-11 22:17:49.421 [DEBUG] [nding.myq.internal.MyQHandlerFactory] - bundle org.openhab.binding.myq:3.2.0.202108311743 (275)[org.openhab.binding.myq.internal.MyQHandlerFactory(322)] : Unset and deconfigured implementation object for component in deleteComponent for reason Unspecified
2021-09-11 22:17:49.422 [DEBUG] [nding.myq.internal.MyQHandlerFactory] - bundle org.openhab.binding.myq:3.2.0.202108311743 (275)[org.openhab.binding.myq.internal.MyQHandlerFactory(322)] : Changed state from active to satisfied
2021-09-11 22:17:49.429 [DEBUG] [nding.myq.internal.MyQHandlerFactory] - bundle org.openhab.binding.myq:3.2.0.202108311743 (275)[org.openhab.binding.myq.internal.MyQHandlerFactory(322)] : Deactivating dependency managers
2021-09-11 22:17:49.432 [DEBUG] [nding.myq.internal.MyQHandlerFactory] - bundle org.openhab.binding.myq:3.2.0.202108311743 (275)[org.openhab.binding.myq.internal.MyQHandlerFactory(322)] : Disabling dependency managers
2021-09-11 22:17:49.437 [DEBUG] [nding.myq.internal.MyQHandlerFactory] - bundle org.openhab.binding.myq:3.2.0.202108311743 (275)[org.openhab.binding.myq.internal.MyQHandlerFactory(322)] : unregistering service listener for dependency $000
2021-09-11 22:17:49.438 [DEBUG] [nding.myq.internal.MyQHandlerFactory] - bundle org.openhab.binding.myq:3.2.0.202108311743 (275)[org.openhab.binding.myq.internal.MyQHandlerFactory(322)] : unregistering service listener for dependency $001
2021-09-11 22:17:49.438 [DEBUG] [nding.myq.internal.MyQHandlerFactory] - bundle org.openhab.binding.myq:3.2.0.202108311743 (275)[org.openhab.binding.myq.internal.MyQHandlerFactory(322)] : Querying state satisfied
2021-09-11 22:17:49.439 [DEBUG] [nding.myq.internal.MyQHandlerFactory] - bundle org.openhab.binding.myq:3.2.0.202108311743 (275)[org.openhab.binding.myq.internal.MyQHandlerFactory(322)] : Changed state from satisfied to disposed
2021-09-11 22:17:49.439 [DEBUG] [nding.myq.internal.MyQHandlerFactory] - bundle org.openhab.binding.myq:3.2.0.202108311743 (275)[org.openhab.binding.myq.internal.MyQHandlerFactory(322)] : Disposing component (reason: 6)
2021-09-11 22:17:49.450 [DEBUG] [nding.myq.internal.MyQHandlerFactory] - bundle org.openhab.binding.myq:3.2.0.202108311743 (275)[org.openhab.binding.myq.internal.MyQHandlerFactory] : BundleComponentActivator : ComponentHolder created.
2021-09-11 22:17:49.451 [DEBUG] [nding.myq.internal.MyQHandlerFactory] - bundle org.openhab.binding.myq:3.2.0.202108311743 (275)[org.openhab.binding.myq.internal.MyQHandlerFactory] : Dependency Manager created $000interface=org.openhab.core.io.net.http.HttpClientFactory, filter=null, policy=static, cardinality=1..1, bind=null, unbind=null, updated=null, field=null, field-option=null, collection-type=null, parameter=0
2021-09-11 22:17:49.451 [DEBUG] [nding.myq.internal.MyQHandlerFactory] - bundle org.openhab.binding.myq:3.2.0.202108311743 (275)[org.openhab.binding.myq.internal.MyQHandlerFactory] : Dependency Manager created $001interface=org.openhab.core.auth.client.oauth2.OAuthFactory, filter=null, policy=static, cardinality=1..1, bind=null, unbind=null, updated=null, field=null, field-option=null, collection-type=null, parameter=1
2021-09-11 22:17:49.451 [DEBUG] [nding.myq.internal.MyQHandlerFactory] - bundle org.openhab.binding.myq:3.2.0.202108311743 (275)[org.openhab.binding.myq.internal.MyQHandlerFactory] : Component created: DS=DS14, implementation=org.openhab.binding.myq.internal.MyQHandlerFactory, immediate=false, default-enabled=true, factory=null, configuration-policy=optional, activate=activate, deactivate=deactivate, modified=null configuration-pid=[binding.myq]
2021-09-11 22:17:49.451 [DEBUG] [nding.myq.internal.MyQHandlerFactory] - bundle org.openhab.binding.myq:3.2.0.202108311743 (275)[org.openhab.binding.myq.internal.MyQHandlerFactory] : Component Services: scope=singleton, services=[org.openhab.core.thing.binding.ThingHandlerFactory]
2021-09-11 22:17:49.451 [DEBUG] [nding.myq.internal.MyQHandlerFactory] - bundle org.openhab.binding.myq:3.2.0.202108311743 (275)[org.openhab.binding.myq.internal.MyQHandlerFactory] : Component Properties: {}
2021-09-11 22:17:49.452 [DEBUG] [nding.myq.internal.MyQHandlerFactory] - bundle org.openhab.binding.myq:3.2.0.202108311743 (275)[org.openhab.binding.myq.internal.MyQHandlerFactory] : Querying state disabled
2021-09-11 22:17:49.452 [DEBUG] [nding.myq.internal.MyQHandlerFactory] - bundle org.openhab.binding.myq:3.2.0.202108311743 (275)[org.openhab.binding.myq.internal.MyQHandlerFactory] : Component can not be activated since it is in state disabled
2021-09-11 22:17:49.453 [DEBUG] [nding.myq.internal.MyQHandlerFactory] - bundle org.openhab.binding.myq:3.2.0.202108311743 (275)[org.openhab.binding.myq.internal.MyQHandlerFactory] : Querying state disabled
2021-09-11 22:17:49.453 [DEBUG] [nding.myq.internal.MyQHandlerFactory] - bundle org.openhab.binding.myq:3.2.0.202108311743 (275)[org.openhab.binding.myq.internal.MyQHandlerFactory(329)] : Updating target filters
2021-09-11 22:17:49.453 [DEBUG] [nding.myq.internal.MyQHandlerFactory] - bundle org.openhab.binding.myq:3.2.0.202108311743 (275)[org.openhab.binding.myq.internal.MyQHandlerFactory(329)] : No change in target property for dependency $000: currently registered: false
2021-09-11 22:17:49.453 [DEBUG] [nding.myq.internal.MyQHandlerFactory] - bundle org.openhab.binding.myq:3.2.0.202108311743 (275)[org.openhab.binding.myq.internal.MyQHandlerFactory(329)] : No existing service listener to unregister for dependency $000
2021-09-11 22:17:49.453 [DEBUG] [nding.myq.internal.MyQHandlerFactory] - bundle org.openhab.binding.myq:3.2.0.202108311743 (275)[org.openhab.binding.myq.internal.MyQHandlerFactory(329)] : Setting target property for dependency $000 to null
2021-09-11 22:17:49.453 [DEBUG] [nding.myq.internal.MyQHandlerFactory] - bundle org.openhab.binding.myq:3.2.0.202108311743 (275)[org.openhab.binding.myq.internal.MyQHandlerFactory(329)] : New service tracker for $000, initial active: false, previous references: {}, classFilter: (objectClass=org.openhab.core.io.net.http.HttpClientFactory), initialReferenceFilter (objectClass=org.openhab.core.io.net.http.HttpClientFactory)
2021-09-11 22:17:49.454 [DEBUG] [nding.myq.internal.MyQHandlerFactory] - bundle org.openhab.binding.myq:3.2.0.202108311743 (275)[org.openhab.binding.myq.internal.MyQHandlerFactory(329)] : dm $000 tracker reset (closed)
2021-09-11 22:17:49.454 [DEBUG] [nding.myq.internal.MyQHandlerFactory] - bundle org.openhab.binding.myq:3.2.0.202108311743 (275)[org.openhab.binding.myq.internal.MyQHandlerFactory(329)] : dm $000 tracking 1 SingleStatic added {org.openhab.core.io.net.http.HttpClientFactory, org.openhab.core.io.net.http.WebSocketFactory}={service.id=267, service.bundleid=177, service.scope=bundle, component.name=org.openhab.core.io.net.http.internal.WebClientFactoryImpl, component.id=135} (enter)
2021-09-11 22:17:49.454 [DEBUG] [nding.myq.internal.MyQHandlerFactory] - bundle org.openhab.binding.myq:3.2.0.202108311743 (275)[org.openhab.binding.myq.internal.MyQHandlerFactory(329)] : dm $000 tracking 1 SingleStatic active: false trackerOpened: false optional: false
2021-09-11 22:17:49.455 [DEBUG] [nding.myq.internal.MyQHandlerFactory] - bundle org.openhab.binding.myq:3.2.0.202108311743 (275)[org.openhab.binding.myq.internal.MyQHandlerFactory(329)] : dm $000 tracking 1 SingleStatic added {org.openhab.core.io.net.http.HttpClientFactory, org.openhab.core.io.net.http.WebSocketFactory}={service.id=267, service.bundleid=177, service.scope=bundle, component.name=org.openhab.core.io.net.http.internal.WebClientFactoryImpl, component.id=135} (exit)
2021-09-11 22:17:49.455 [DEBUG] [nding.myq.internal.MyQHandlerFactory] - bundle org.openhab.binding.myq:3.2.0.202108311743 (275)[org.openhab.binding.myq.internal.MyQHandlerFactory(329)] : dm $000 tracker opened
2021-09-11 22:17:49.455 [DEBUG] [nding.myq.internal.MyQHandlerFactory] - bundle org.openhab.binding.myq:3.2.0.202108311743 (275)[org.openhab.binding.myq.internal.MyQHandlerFactory(329)] : registering service listener for dependency $000
2021-09-11 22:17:49.455 [DEBUG] [nding.myq.internal.MyQHandlerFactory] - bundle org.openhab.binding.myq:3.2.0.202108311743 (275)[org.openhab.binding.myq.internal.MyQHandlerFactory(329)] : No change in target property for dependency $001: currently registered: false
2021-09-11 22:17:49.455 [DEBUG] [nding.myq.internal.MyQHandlerFactory] - bundle org.openhab.binding.myq:3.2.0.202108311743 (275)[org.openhab.binding.myq.internal.MyQHandlerFactory(329)] : No existing service listener to unregister for dependency $001
2021-09-11 22:17:49.456 [DEBUG] [nding.myq.internal.MyQHandlerFactory] - bundle org.openhab.binding.myq:3.2.0.202108311743 (275)[org.openhab.binding.myq.internal.MyQHandlerFactory(329)] : Setting target property for dependency $001 to null
2021-09-11 22:17:49.456 [DEBUG] [nding.myq.internal.MyQHandlerFactory] - bundle org.openhab.binding.myq:3.2.0.202108311743 (275)[org.openhab.binding.myq.internal.MyQHandlerFactory(329)] : New service tracker for $001, initial active: false, previous references: {}, classFilter: (objectClass=org.openhab.core.auth.client.oauth2.OAuthFactory), initialReferenceFilter (objectClass=org.openhab.core.auth.client.oauth2.OAuthFactory)
2021-09-11 22:17:49.456 [DEBUG] [nding.myq.internal.MyQHandlerFactory] - bundle org.openhab.binding.myq:3.2.0.202108311743 (275)[org.openhab.binding.myq.internal.MyQHandlerFactory(329)] : dm $001 tracker reset (closed)
2021-09-11 22:17:49.457 [DEBUG] [nding.myq.internal.MyQHandlerFactory] - bundle org.openhab.binding.myq:3.2.0.202108311743 (275)[org.openhab.binding.myq.internal.MyQHandlerFactory(329)] : dm $001 tracking 2 SingleStatic added {org.openhab.core.auth.client.oauth2.OAuthFactory}={service.id=338, service.bundleid=157, service.scope=bundle, component.name=org.openhab.core.auth.oauth2client.internal.OAuthFactoryImpl, component.id=51} (enter)
2021-09-11 22:17:49.457 [DEBUG] [nding.myq.internal.MyQHandlerFactory] - bundle org.openhab.binding.myq:3.2.0.202108311743 (275)[org.openhab.binding.myq.internal.MyQHandlerFactory(329)] : dm $001 tracking 2 SingleStatic active: false trackerOpened: false optional: false
2021-09-11 22:17:49.457 [DEBUG] [nding.myq.internal.MyQHandlerFactory] - bundle org.openhab.binding.myq:3.2.0.202108311743 (275)[org.openhab.binding.myq.internal.MyQHandlerFactory(329)] : dm $001 tracking 2 SingleStatic added {org.openhab.core.auth.client.oauth2.OAuthFactory}={service.id=338, service.bundleid=157, service.scope=bundle, component.name=org.openhab.core.auth.oauth2client.internal.OAuthFactoryImpl, component.id=51} (exit)
2021-09-11 22:17:49.457 [DEBUG] [nding.myq.internal.MyQHandlerFactory] - bundle org.openhab.binding.myq:3.2.0.202108311743 (275)[org.openhab.binding.myq.internal.MyQHandlerFactory(329)] : dm $001 tracker opened
2021-09-11 22:17:49.458 [DEBUG] [nding.myq.internal.MyQHandlerFactory] - bundle org.openhab.binding.myq:3.2.0.202108311743 (275)[org.openhab.binding.myq.internal.MyQHandlerFactory(329)] : registering service listener for dependency $001
2021-09-11 22:17:49.458 [DEBUG] [nding.myq.internal.MyQHandlerFactory] - bundle org.openhab.binding.myq:3.2.0.202108311743 (275)[org.openhab.binding.myq.internal.MyQHandlerFactory(329)] : Changed state from disabled to unsatisfiedReference
2021-09-11 22:17:49.458 [DEBUG] [nding.myq.internal.MyQHandlerFactory] - bundle org.openhab.binding.myq:3.2.0.202108311743 (275)[org.openhab.binding.myq.internal.MyQHandlerFactory(329)] : Component enabled
2021-09-11 22:17:49.458 [DEBUG] [nding.myq.internal.MyQHandlerFactory] - bundle org.openhab.binding.myq:3.2.0.202108311743 (275)[org.openhab.binding.myq.internal.MyQHandlerFactory(329)] : ActivateInternal
2021-09-11 22:17:49.458 [DEBUG] [nding.myq.internal.MyQHandlerFactory] - bundle org.openhab.binding.myq:3.2.0.202108311743 (275)[org.openhab.binding.myq.internal.MyQHandlerFactory(329)] : Querying state unsatisfiedReference
2021-09-11 22:17:49.459 [DEBUG] [nding.myq.internal.MyQHandlerFactory] - bundle org.openhab.binding.myq:3.2.0.202108311743 (275)[org.openhab.binding.myq.internal.MyQHandlerFactory(329)] : Activating component from state unsatisfiedReference
2021-09-11 22:17:49.459 [DEBUG] [nding.myq.internal.MyQHandlerFactory] - bundle org.openhab.binding.myq:3.2.0.202108311743 (275)[org.openhab.binding.myq.internal.MyQHandlerFactory(329)] : Querying state unsatisfiedReference
2021-09-11 22:17:49.459 [DEBUG] [nding.myq.internal.MyQHandlerFactory] - bundle org.openhab.binding.myq:3.2.0.202108311743 (275)[org.openhab.binding.myq.internal.MyQHandlerFactory(329)] : Changed state from unsatisfiedReference to satisfied
2021-09-11 22:17:49.459 [DEBUG] [nding.myq.internal.MyQHandlerFactory] - bundle org.openhab.binding.myq:3.2.0.202108311743 (275)[org.openhab.binding.myq.internal.MyQHandlerFactory(329)] : registration change queue [registered]
2021-09-11 22:17:49.460 [DEBUG] [nding.myq.internal.MyQHandlerFactory] - bundle org.openhab.binding.myq:3.2.0.202108311743 (275)[org.openhab.binding.myq.internal.MyQHandlerFactory(329)] : Checking constructor public org.openhab.binding.myq.internal.MyQHandlerFactory(org.openhab.core.io.net.http.HttpClientFactory,org.openhab.core.auth.client.oauth2.OAuthFactory)
2021-09-11 22:17:49.460 [DEBUG] [nding.myq.internal.MyQHandlerFactory] - bundle org.openhab.binding.myq:3.2.0.202108311743 (275)[org.openhab.binding.myq.internal.MyQHandlerFactory(329)] : getReferenceClass: Looking for interface class org.openhab.core.io.net.http.HttpClientFactory through loader of org.openhab.binding.myq.internal.MyQHandlerFactory
2021-09-11 22:17:49.460 [DEBUG] [nding.myq.internal.MyQHandlerFactory] - bundle org.openhab.binding.myq:3.2.0.202108311743 (275)[org.openhab.binding.myq.internal.MyQHandlerFactory(329)] : getParameterClass: Found class org.openhab.core.io.net.http.HttpClientFactory
2021-09-11 22:17:49.460 [DEBUG] [nding.myq.internal.MyQHandlerFactory] - bundle org.openhab.binding.myq:3.2.0.202108311743 (275)[org.openhab.binding.myq.internal.MyQHandlerFactory(329)] : getReferenceClass: Looking for interface class org.openhab.core.auth.client.oauth2.OAuthFactory through loader of org.openhab.binding.myq.internal.MyQHandlerFactory
2021-09-11 22:17:49.461 [DEBUG] [nding.myq.internal.MyQHandlerFactory] - bundle org.openhab.binding.myq:3.2.0.202108311743 (275)[org.openhab.binding.myq.internal.MyQHandlerFactory(329)] : getParameterClass: Found class org.openhab.core.auth.client.oauth2.OAuthFactory
2021-09-11 22:17:49.461 [DEBUG] [nding.myq.internal.MyQHandlerFactory] - bundle org.openhab.binding.myq:3.2.0.202108311743 (275)[org.openhab.binding.myq.internal.MyQHandlerFactory(329)] : Found constructor with 2 arguments : public org.openhab.binding.myq.internal.MyQHandlerFactory(org.openhab.core.io.net.http.HttpClientFactory,org.openhab.core.auth.client.oauth2.OAuthFactory)
2021-09-11 22:17:49.461 [DEBUG] [nding.myq.internal.MyQHandlerFactory] - bundle org.openhab.binding.myq:3.2.0.202108311743 (275)[org.openhab.binding.myq.internal.MyQHandlerFactory(329)] : This thread collected dependencies
2021-09-11 22:17:49.461 [DEBUG] [nding.myq.internal.MyQHandlerFactory] - bundle org.openhab.binding.myq:3.2.0.202108311743 (275)[org.openhab.binding.myq.internal.MyQHandlerFactory(329)] : getService (single component manager) dependencies collected.
2021-09-11 22:17:49.461 [DEBUG] [nding.myq.internal.MyQHandlerFactory] - bundle org.openhab.binding.myq:3.2.0.202108311743 (275)[org.openhab.binding.myq.internal.MyQHandlerFactory(329)] : Querying state satisfied
2021-09-11 22:17:49.462 [DEBUG] [nding.myq.internal.MyQHandlerFactory] - bundle org.openhab.binding.myq:3.2.0.202108311743 (275)[org.openhab.binding.myq.internal.MyQHandlerFactory(329)] : Querying state satisfied
2021-09-11 22:17:49.462 [DEBUG] [nding.myq.internal.MyQHandlerFactory] - bundle org.openhab.binding.myq:3.2.0.202108311743 (275)[org.openhab.binding.myq.internal.MyQHandlerFactory(329)] : For dependency $000, optional: false; to bind: [[RefPair: ref: [{org.openhab.core.io.net.http.HttpClientFactory, org.openhab.core.io.net.http.WebSocketFactory}={service.id=267, service.bundleid=177, service.scope=bundle, component.name=org.openhab.core.io.net.http.internal.WebClientFactoryImpl, component.id=135}] service: [null]]]
2021-09-11 22:17:49.462 [DEBUG] [nding.myq.internal.MyQHandlerFactory] - bundle org.openhab.binding.myq:3.2.0.202108311743 (275)[org.openhab.binding.myq.internal.MyQHandlerFactory(329)] : For dependency $001, optional: false; to bind: [[RefPair: ref: [{org.openhab.core.auth.client.oauth2.OAuthFactory}={service.id=338, service.bundleid=157, service.scope=bundle, component.name=org.openhab.core.auth.oauth2client.internal.OAuthFactoryImpl, component.id=51}] service: [null]]]
2021-09-11 22:17:49.462 [DEBUG] [nding.myq.internal.MyQHandlerFactory] - bundle org.openhab.binding.myq:3.2.0.202108311743 (275)[org.openhab.binding.myq.internal.MyQHandlerFactory(329)] : getting activate: activate
2021-09-11 22:17:49.462 [DEBUG] [nding.myq.internal.MyQHandlerFactory] - bundle org.openhab.binding.myq:3.2.0.202108311743 (275)[org.openhab.binding.myq.internal.MyQHandlerFactory(329)] : Locating method activate in class org.openhab.binding.myq.internal.MyQHandlerFactory
2021-09-11 22:17:49.463 [DEBUG] [nding.myq.internal.MyQHandlerFactory] - bundle org.openhab.binding.myq:3.2.0.202108311743 (275)[org.openhab.binding.myq.internal.MyQHandlerFactory(329)] : Declared Method org.openhab.binding.myq.internal.MyQHandlerFactory.activate([interface org.osgi.service.component.ComponentContext]) not found
2021-09-11 22:17:49.463 [DEBUG] [nding.myq.internal.MyQHandlerFactory] - bundle org.openhab.binding.myq:3.2.0.202108311743 (275)[org.openhab.binding.myq.internal.MyQHandlerFactory(329)] : Locating method activate in class org.openhab.core.thing.binding.BaseThingHandlerFactory
2021-09-11 22:17:49.463 [DEBUG] [nding.myq.internal.MyQHandlerFactory] - bundle org.openhab.binding.myq:3.2.0.202108311743 (275)[org.openhab.binding.myq.internal.MyQHandlerFactory(329)] : Found activate method: protected void org.openhab.core.thing.binding.BaseThingHandlerFactory.activate(org.osgi.service.component.ComponentContext)
2021-09-11 22:17:49.463 [DEBUG] [nding.myq.internal.MyQHandlerFactory] - bundle org.openhab.binding.myq:3.2.0.202108311743 (275)[org.openhab.binding.myq.internal.MyQHandlerFactory(329)] : invoking activate: activate: parameters [org.apache.felix.scr.impl.manager.ComponentContextImpl]
2021-09-11 22:17:49.463 [DEBUG] [nding.myq.internal.MyQHandlerFactory] - bundle org.openhab.binding.myq:3.2.0.202108311743 (275)[org.openhab.binding.myq.internal.MyQHandlerFactory(329)] : invoked activate: activate
2021-09-11 22:17:49.464 [DEBUG] [nding.myq.internal.MyQHandlerFactory] - bundle org.openhab.binding.myq:3.2.0.202108311743 (275)[org.openhab.binding.myq.internal.MyQHandlerFactory(329)] : Set implementation object for component
2021-09-11 22:17:49.464 [DEBUG] [nding.myq.internal.MyQHandlerFactory] - bundle org.openhab.binding.myq:3.2.0.202108311743 (275)[org.openhab.binding.myq.internal.MyQHandlerFactory(329)] : Changed state from satisfied to active
2021-09-11 22:17:49.471 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'myq:account:77ab746642' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
2021-09-11 22:17:49.474 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'myq:account:77ab746642' changed from INITIALIZING to UNKNOWN
2021-09-11 22:17:49.476 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'myq:garagedoor:77ab746642:187da3b583' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
2021-09-11 22:17:49.477 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'myq:garagedoor:77ab746642:187da3b583' changed from INITIALIZING to UNKNOWN
2021-09-11 22:17:49.530 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'myq:account:77ab746642' changed from UNKNOWN to ONLINE
