I just went through the blog again with a fine tooth comb and no luck. I think the only changes that need to be made are adding the cloud.jar file to the addons folder AND adding the new lines to the openhab.cfg. I broke the link between IFTTT/openhab and re authenticated. Everything works in openhab…I see the notifications, I’m online, and I can hit the open/close button. I always get the 'No options found" instead of the garagedoorswitch when I use the applet maker.
I followed the same tutorial as zeenon. I’m also unable to see any openhab commands in IFTTT anymore. I added the openhabcloud.jar file, removed the myopenhab.jar file and updated openhab.cfg. Is this all that is required?
I’m getting garagedoor related notifications (manual & openhab), but GarageDoorSwitch isn’t listed under items. I’m able to open/close the garage door via http://192.168.x.xx:8080/openhab.app.
Good Day, I am new as well to the Alexa Christmas item and was wondering with the new cloud connector if there are additional clarification documentation. All is communicating except no notifications yet.
I got it working also. I almost certain the openhabcloud:expose=GarageDoorSwitch in openhab.cfg fixed the issue.
Although watch out, I copied the line direct from wemustbegeeks which is garagedoorswitch and it still was not working then I said to myself let me try caps - GarageDoorSwitch and it started working within 30 secs.
