I am trying to get HABPanel running on an ebook reader (Kobo Aura). The browser is not full featured and things like dialog window or menu do not work well. I managed to have a default panel loaded so I solved the dialog box problem but the default theme is white on black which does not look really good on such display.
I could I change the default theme, maybe in the “Panel registry JSON” in paper UI ? so I get around the bug to select a theme on the reader browser ?
Thanks !
