rule "Licht Alltag"
Item tradLicht changed to ALLTAG
tradLicht1Col.sendCommand (HSBType::fromRGB(255, 255, 255))
tradLicht1ColTmp.sendCommand(49)
tradLicht2Col.sendCommand (HSBType::fromRGB(255, 255, 255))
tradLicht2ColTmp.sendCommand(49)
tradLicht3Col.sendCommand (HSBType::fromRGB(255, 255, 255))
tradLicht3ColTmp.sendCommand(49)
Works fine via the BasicUI. But there seems to be no way to change for example from KINO to ALLTAG using Alexa. So, what do i have to do to be able to use Alexa for a change of light mode?
Yes, i already use Alexa for some things regarding OpenHAB. I just hoped someone found another way for this topic, another way to configure this in openhab to make it āvisibleā for Alexa.
There are tags for Alexa. I only posted the item i have a problem with.
I can turn a light on / off, for example. My problem is the string item i use as a switch in my Sitemap. How am i able to tell Alexa that it should switch my lights to kino, alltag, gemütlich mode? Is this possible at all? Switchable tag does not seem to work with this string. Alexa does not find the item.
