Yes possible
1 thing to look out for is on/off items like dimmers may be 0 or 100 as off/on
if you have altered the description metadata displayState maybe better
not sure - but not home to check if bgColor is correct or just color
bgColor: "=(items[props.item].state === 'ON') ? green : white"
Is missing one piece. Because it is an expression, it is treating green and white as variables, which you haven’t defined. So no matter what the state of the item, this expression returns undefined. In order for it to return the strings 'green' or 'white' which the property expects, you have to place quotes around them.
@JustinG
Can you also specify an RGB color using that syntax?
This does not work:
bgColor: “=(items[props.item].state === ‘ON’) ? ‘green’ : ‘rgb(211,211,211)’”
or
bgColor: “=(items[props.item].state === ‘ON’) ? ‘green’ : rgb(211,211,211)”
The property bgColor is tied to the property of the underlying f7 element. The f7 bg-color property only accepts a limited number of named color options:
If you want to use something that is not in that list then you will have to do it using css and the style property (and use the expression version with the quotes).
P.S. html uses a different color for ‘green’ than f7 does, so you’ll have to use the link I put above to get the color code for f7 green and use that in the expression if you want it to match exactly what you had before.
