Thank you @rlkoshak for your prompt answer!
Unfortunately something it’s still not working right. The values of setpoint are not updated in sitemap. A refresh page it’s needed, after the values of the setpoint are updated:
My configuration is now:
Items:
Group:Number gSetPoint
Number SetPointContainer “Temperatura dorita: [%.1f °C]” (gSetPoint) // Birou Mircea
Number SetPointHala “Temperatura dorita: [%.1f °C]” (gSetPoint) // Sufragerie
Number SetPointAngelescu “Temperatura dorita: [%.1f °C]” (gSetPoint) // Birou Angelescu
Number SetPointFerolli “Temperatura dorita: [%.1f °C]” (gSetPoint) // Birou Ferolli
Number SetPointBirouri “Temperatura dorita: [%.1f °C]” (gSetPoint) // Zona Birouri
Rule:
rule “WeekDays Temp to 18”
when Item tst changed from OFF to ON //Time cron “0 0 6 ? * MON-FRI *”
gSetPoint.sendCommand(18)
logInfo(“info”,“all setpoint to 18”)
sitemap:
sitemap hvac label=“Incalzire”
Frame label=“test” {
Switch item=tst
Frame label=“Birou Mircea” visibility=[Modul_Ales==2]{
Text item=ShellyHT_Mircea_Temp label=“Temperatura Actuala”
Setpoint item=SetPointContainer step=0.5 minValue=15 maxValue=27
Text item=StareIncalzireContainer valuecolor=[==“ON”=“red”,==“OFF”=“blue”]
Logview Messages:
2021-02-23 18:43:32.631 [ome.event.ItemCommandEvent] - Item 'tst' received command ON
2021-02-23 18:43:32.644 [vent.ItemStateChangedEvent] - tst changed from OFF to ON
2021-02-23 18:43:38.748 [INFO ] [.eclipse.smarthome.model.script.info] - all setpoint to 21
2021-02-23 18:43:38.759 [ome.event.ItemCommandEvent] - Item 'gSetPoint' received command 18
2021-02-23 18:43:38.769 [ome.event.ItemCommandEvent] - Item 'SetPointContainer' received command 18
2021-02-23 18:43:38.776 [ome.event.ItemCommandEvent] - Item 'SetPointHala' received command 18
2021-02-23 18:43:38.787 [ome.event.ItemCommandEvent] - Item 'SetPointAngelescu' received command 18
2021-02-23 18:43:38.792 [ome.event.ItemCommandEvent] - Item 'SetPointFerolli' received command 18
2021-02-23 18:43:38.798 [ome.event.ItemCommandEvent] - Item 'SetPointBirouri' received command 18
2021-02-23 18:43:38.824 [GroupItemStateChangedEvent] - gSetPoint changed from 18 to UNDEF through SetPointContainer
2021-02-23 18:43:38.829 [vent.ItemStateChangedEvent] - SetPointHala changed from 21 to 18
2021-02-23 18:43:38.834 [vent.ItemStateChangedEvent] - SetPointAngelescu changed from 21 to 18
2021-02-23 18:43:38.838 [vent.ItemStateChangedEvent] - SetPointFerolli changed from 21 to 18
2021-02-23 18:43:38.842 [vent.ItemStateChangedEvent] - SetPointBirouri changed from 21 to 18
2021-02-23 18:43:38.855 [GroupItemStateChangedEvent] - gSetPoint changed from UNDEF to 18 through SetPointBirouri
2021-02-23 18:43:38.862 [ome.event.ItemCommandEvent] - Item 'LED3_Hala' received command OFF
2021-02-23 18:43:38.875 [ome.event.ItemCommandEvent] - Item 'LED2_Angelescu' received command OFF
2021-02-23 18:43:38.899 [vent.ItemStateChangedEvent] - StareIncalzireHala changed from ON to OFF
2021-02-23 18:43:38.912 [vent.ItemStateChangedEvent] - LED3_Hala changed from ON to OFF
2021-02-23 18:43:38.930 [ome.event.ItemCommandEvent] - Item 'LED4_Ferolli' received command OFF
2021-02-23 18:43:38.943 [ome.event.ItemCommandEvent] - Item 'LED5_Birouri' received command OFF
2021-02-23 18:43:38.956 [ome.event.ItemCommandEvent] - Item 'LED6_Main' received command OFF
2021-02-23 18:43:38.964 [vent.ItemStateChangedEvent] - LED6_Main changed from ON to OFF
