I’d like to combine all rollershutters of a floor in a list card and not make separate rollershutter cards per item. However, the oh-list-card is too narrow. It look awful. How can I increase the width to have icon, title and the controls in one line?
the oh-list-card itself uses 100% of the available width. The elements might overflow the card, depending on the location where you insert your card inside the OH page-grid.
You could use the Column Options inside your page settings to assign the widget a wider area depending for the different screen sizes.
I have to correct myself: I only searched in the “masonry” area so far. Now, when poking around the block area I also find column options… Not I need to figure out what the difference between masonry and block is and when to use them correctly.
I have exactly the same problem. I see that there is a oh-masonry component where the config parameter cols allow to adjust the number of cards to be presented on a particular screen width. Setting the parameter cols to desired values would solve my issue, but I did not figure out how this is connected to the oh-block component where my widgets are inserted. So I have:
