rule "Vaillant_status"
Item VaillantVRT39239200DisplayedRoomTempDisplayedRoomTemp received update or Item VaillantVRT39239200ActualRoomTempDesiredHc1ActualRoomTempDesiredHc1 received update or Item VaillantVRT39239200Hc1OPModeHc1OPMode received update
if(VaillantVRT39239200Hc1OPModeHc1OPMode.state == 2 ){
var String VRTstatus = "AUTO"
logInfo("FILE", "AUTOOOOO")
}else if (VaillantVRT39239200Hc1OPModeHc1OPMode.state == 1 ){
var String VRTstatus = "MANUAL"
logInfo("FILE", "MANUALLLLL")
}else{
var String VRTstatus = "OFF"
logInfo("FILE", "OFFFFF")
Vaillant_status.postUpdate(VaillantVRT39239200ActualRoomTempDesiredHc1ActualRoomTempDesiredHc1.state.toString + "°C/" + VaillantVRT39239200DisplayedRoomTempDisplayedRoomTemp.state.toString + "°C/" + VRTstatus.state.toString)
ERROR
10:13:44.498 [INFO ] [del.core.internal.ModelRepositoryImpl] - Validation issues found in configuration model 'test.rules', using it anyway:
The value of the local variable VRTstatus is not used
10:14:44.329 [ERROR] [untime.internal.engine.RuleEngineImpl] - Rule 'Vaillant_status': 'state' is not a member of 'java.lang.String'; line 1042, column 201, length 15
By way of explanation, the var exists only within the { } block, and vanishes at the closing }
By defining the var outside the block, it continues to exist before, during, and after the { } block.
