Hello.
Is it possible to change rollershutter up/down arrow icons to something else? I use rollershutter item to open regular window, not really related to blinds and opening/closing icons confuse other users. Even replacing icons with letters would do the job.
Welcome to the openHAB-Community @Ragnarre
This is a very specific issue… Hmm
I would suggest creating an Selection-Item with a mapping that suits your use-case.
But you will need to write a rule to make the selection do what you want.
For example see:
What do you think?
I currently use Openhab as MQTT front-end only.
Basically it will listen to MQTT topic for status (0=open and 100=closed),
and send commands to MQTT topic, UP=1, DOWN=0, STOP=2.
Sitemap: Default item=SuurTuba_Shutter label="Aken"
Item: Rollershutter SuurTuba_Shutter "Aken" <aken> (SuurTuba, gShutter) ["Rollershutter"] {channel=" mqtt:topic:59e350a1:Suuretoaaken"}
I use this in the sitemap for my zwave rollershutter:
Switch item=RS_RollerShutter_01 label="Rollo [(%d)]" mappings=[UP="▲", STOP="X", DOWN="▼", 25="≡"]
