Ok, I finally have the ecobee binding working! I’ve read through the documentation, and it looks like there’s some great tools! I’m seeing items to set a desired temperature, and to set a hold on a comfort setting, but I’m not seeing a way to actually change a comfort setting. Is this not doable with the binding?
For example, I have my basement suite on Airbnb. My comfort setting on the ecobee currently turn down the temperature when I’m at work, and at night shortly before bed. But Airbnb guests don’t like the house as cold as I do. I’d like to simply activate/deactivate a “guest mode” to automatically change the “Away” and “Sleep” comfort settings, rather than using holds to override the comfort settings. Is that possible?
Thanks!
