When using the GUI to display the temperature from my Aeotec Garage Door Controller it gives me a number between 0 and 500. When I change the Type to Number:Temperature and Semantic Class to a Measurement with Property Temperature it displays the temperature as e.g. 172 as 172C. The temperature should be 17.2C. Where do I change how this is displayed in the new GUI. Does it have something to do with the Link Channel to Item section then creating an offset profile?
This is not a suitable topic for the Tutorials forum.
It’s a zwave device, right? The binding’s device database needs to be set up with correct info for the device. You need to link the created channels to the correct type of Item.
See -
Your example may be a different version to that.
