I had setup a rule to change the panel over to view an ip camera motion JPEG feed when a pir sensor detects motion. Seems to work but it crashes safari on the iPad habpanel is running on almost every time. If I change the panel to swap to when the pir detects movement (for testing) to one that doesn’t have the motion JPEG it doesn’t crash - any one have any ideas?
bump?
