Just trying to get up an alert when a phone battery is getting low. I followed along from this thread (which I think is really awesome) and parsed the battery value from the owntracks mqtt data.
The rest item seems to be updating ok, but is a string type
Item is,
String mqttNWBattery “NW’s Battery [%s%%]”
Rule is,
rule "Battery Alert NW"
Item mqttNWBattery changed
if((mqttNWBattery.state) < 25){
sendMail("myemail@gmail.com", "NW battery <25%!", "")
I presume I need to change the string item to a decimal type before checking it in the rule math? Not sure how to do that bit.
Could someone point me in the right direction?
If it is an integer value (i.e. no decimal place) you can do this in your rule:
if(Integer::parseInt(mqttNWBattery.state) < 25)
If it does have a decimal point use Double::parseDouble() instead
However, if you make your Item a Number instead of a String OH should be able to parse the value for you, as long as the String is a parseable number (e.g. no leading or trailing spaces) it will convert it to a DecimalType for you. And if there is something a little off about it you can use a transform to fix it. Then you can do:
Thanks for your help, I added the line but it gives me an error when the rule is triggered.
Error:
2016-01-28 17:49:47.966 [ERROR] [o.o.c.s.ScriptExecutionThread ] - Error during the execution of rule ‘Battery Alert NW’: Could not invoke method: java.lang.Integer.parseInt(java.lang.String) on instance: null
Do I need to import anything at the top of the rules file?
if(Integer::parseInt(mqttNWBattery.state) < 25){
George, is there a reason that your item mqttNWBattery is not a Number item? Following from the other thread, if you define the item as a Number, and then in your mqttPositionPatrikRaw rule you
then your “Battery Alert NW” rule can look like this:
if ((mqttNWBattery.state as DecimalType) < 25) {
sendMail("myemail@gmail.com", "NW battery is " + mqttNWBattery.state.toString + "%", "")
