I have several light fixtures in my house with two or more Philips Hue Lamps.
So what I have tested is to
- create Things for all the lamps that belongs to a specific fixture
- Create an “Equipment” from one of the lamps
- I open the “Color Point” that belongs to that equipment and from there i add Channel Links to the rest of the lamps belonging to that physical light fixture (as per below screenshot)
That works perfectly fine, and I can now control all lamps from one color selector widget.
But now I want to add a “Brightness Slider” linking to the color channel
If I create a new Point under the same Equipment, I thought I was going to be able to add channel links via the UI, but channel link selection is nowhere to be found.
I guess I am doing (or thinking) something wrong here…
Can anyone advise?
