I have a CCU2 wit actually firmware.
OH2 .2.4 in Docker.
Homematic binding 2.4.0
All works like a charm beside a Wall Mounted Thermostat
HM-TC-IT-WM-W-EU
It has no channels and in the Logs i got following errors:
2019-12-16 04:50:30.748 [WARN ] [ematic.handler.HomematicThingHandler] - Channel not found for datapoint 'MEQ0479491:2#ACTUAL_TEMPERATURE'
2019-12-16 04:50:30.749 [WARN ] [ematic.handler.HomematicThingHandler] - Channel not found for datapoint 'MEQ0479491:2#ACTUAL_HUMIDITY'
2019-12-16 04:50:30.750 [WARN ] [ematic.handler.HomematicThingHandler] - Channel not found for datapoint 'MEQ0479491:2#SET_TEMPERATURE'
2019-12-16 04:50:50.756 [WARN ] [ematic.handler.HomematicThingHandler] - Channel not found for datapoint 'MEQ0479491:1#TEMPERATURE'
2019-12-16 04:50:50.756 [WARN ] [ematic.handler.HomematicThingHandler] - Channel not found for datapoint 'MEQ0479491:1#HUMIDITY'
Anyone could help to fix it ?
