I just installed two Aeon energy meters – one 1st gen meter (DSB09) and one gen 5 meter (ZW095). I’m not seeing the power (watt) and energy (kWH) channels being updated when reports are received from the gen 1 meter.
Before I dig too much deeper into this, in the log viewer snippets below, the node where the channels are updating correctly show STATE UPDATE
after the receipt of each report, versus the other node, which is not showing STATE UPDATE
in the viewer. Is this the expected behavior?
This system is using the zwave binding from a recent 2.2 snapshot version (i.e. not the dev version of the zwave binding).
Aeon ZW095, node 67
- Gen 5 Aeon energy meter
- installed on feed from electric utility
- channels seem to be updating correctly
- snippet from log viewer below (not sure why the log viewer is not reporting the correct time
Aeon DSB09 Energy Meter, node 68
- First generation Aeon energy meter
- installed on feed from backup generator
- channels do not appear to be updating
Here’s a snippet of the debug log for the node whose channels are not updating.
15-Oct-2017 14:19:20.887 [DEBUG] [tocol.serialmessage.ApplicationCommandMessageClass] - NODE 68: Application Command Request (ALIVE:DONE)
15-Oct-2017 14:19:20.887 [DEBUG] [protocol.initialization.ZWaveNodeInitStageAdvancer] - NODE 68: Starting initialisation from DONE
15-Oct-2017 14:19:20.887 [DEBUG] [ab.binding.zwave.internal.protocol.ZWaveController] - Event Listener org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer@2fa5f63c already registered
15-Oct-2017 14:19:20.887 [DEBUG] [tocol.serialmessage.ApplicationCommandMessageClass] - NODE 68: Incoming command class BATTERY
15-Oct-2017 14:19:20.887 [DEBUG] [nal.protocol.commandclass.ZWaveBatteryCommandClass] - NODE 68: Received Battery Request
15-Oct-2017 14:19:20.888 [DEBUG] [nal.protocol.commandclass.ZWaveBatteryCommandClass] - NODE 68: Battery report value = 100
15-Oct-2017 14:19:20.888 [DEBUG] [ab.binding.zwave.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveCommandClassValueEvent
15-Oct-2017 14:19:20.888 [DEBUG] [tocol.serialmessage.ApplicationCommandMessageClass] - NODE 58: Transaction not completed: node address inconsistent. lastSent=58, incoming=255
15-Oct-2017 14:19:25.848 [DEBUG] [wave.handler.ZWaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0E 00 04 00 44 08 31 05 04 64 00 07 48 B0 12
15-Oct-2017 14:19:25.849 [DEBUG] [ab.binding.zwave.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
15-Oct-2017 14:19:25.850 [DEBUG] [nhab.binding.zwave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0E 00 04 00 44 08 31 05 04 64 00 07 48 B0 12
15-Oct-2017 14:19:25.851 [DEBUG] [ab.binding.zwave.internal.protocol.ZWaveController] - Process Message = 01 0E 00 04 00 44 08 31 05 04 64 00 07 48 B0 12
15-Oct-2017 14:19:25.851 [DEBUG] [ab.binding.zwave.internal.protocol.ZWaveController] - Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 44 08 31 05 04 64 00 07 48 B0
15-Oct-2017 14:19:25.852 [DEBUG] [tocol.serialmessage.ApplicationCommandMessageClass] - NODE 68: Application Command Request (ALIVE:DONE)
15-Oct-2017 14:19:25.852 [DEBUG] [protocol.initialization.ZWaveNodeInitStageAdvancer] - NODE 68: Starting initialisation from DONE
15-Oct-2017 14:19:25.853 [DEBUG] [ab.binding.zwave.internal.protocol.ZWaveController] - Event Listener org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer@2fa5f63c already registered
15-Oct-2017 14:19:25.853 [DEBUG] [tocol.serialmessage.ApplicationCommandMessageClass] - NODE 68: Incoming command class SENSOR_MULTILEVEL
15-Oct-2017 14:19:25.853 [DEBUG] [col.commandclass.ZWaveMultiLevelSensorCommandClass] - NODE 68: Received COMMAND_CLASS_SENSOR_MULTILEVEL command V2
15-Oct-2017 14:19:25.853 [DEBUG] [col.commandclass.ZWaveMultiLevelSensorCommandClass] - NODE 68: Sensor Multi Level REPORT received
15-Oct-2017 14:19:25.853 [DEBUG] [col.commandclass.ZWaveMultiLevelSensorCommandClass] - NODE 68: Sensor Type = Power(4), Scale = 0
15-Oct-2017 14:19:25.854 [DEBUG] [col.commandclass.ZWaveMultiLevelSensorCommandClass] - NODE 68: Sensor Value = 477.36
15-Oct-2017 14:19:25.854 [DEBUG] [ab.binding.zwave.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveMultiLevelSensorValueEvent
15-Oct-2017 14:19:25.854 [DEBUG] [tocol.serialmessage.ApplicationCommandMessageClass] - NODE 58: Transaction not completed: node address inconsistent. lastSent=58, incoming=255
15-Oct-2017 14:19:25.890 [DEBUG] [wave.handler.ZWaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 14 00 04 00 44 0E 32 02 21 74 00 07 48 B0 00 00 00 00 00 00 3F
15-Oct-2017 14:19:25.892 [DEBUG] [ab.binding.zwave.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
15-Oct-2017 14:19:25.893 [DEBUG] [nhab.binding.zwave.internal.protocol.SerialMessage] - Assembled message buffer = 01 14 00 04 00 44 0E 32 02 21 74 00 07 48 B0 00 00 00 00 00 00 3F
15-Oct-2017 14:19:25.894 [DEBUG] [ab.binding.zwave.internal.protocol.ZWaveController] - Process Message = 01 14 00 04 00 44 0E 32 02 21 74 00 07 48 B0 00 00 00 00 00 00 3F
15-Oct-2017 14:19:25.895 [DEBUG] [ab.binding.zwave.internal.protocol.ZWaveController] - Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 44 0E 32 02 21 74 00 07 48 B0 00 00 00 00 00 00
15-Oct-2017 14:19:25.895 [DEBUG] [tocol.serialmessage.ApplicationCommandMessageClass] - NODE 68: Application Command Request (ALIVE:DONE)
15-Oct-2017 14:19:25.895 [DEBUG] [protocol.initialization.ZWaveNodeInitStageAdvancer] - NODE 68: Starting initialisation from DONE
15-Oct-2017 14:19:25.896 [DEBUG] [ab.binding.zwave.internal.protocol.ZWaveController] - Event Listener org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer@2fa5f63c already registered
15-Oct-2017 14:19:25.896 [DEBUG] [tocol.serialmessage.ApplicationCommandMessageClass] - NODE 68: Incoming command class METER
15-Oct-2017 14:19:25.896 [DEBUG] [ernal.protocol.commandclass.ZWaveMeterCommandClass] - NODE 68: Received METER command V2
15-Oct-2017 14:19:25.896 [DEBUG] [ernal.protocol.commandclass.ZWaveMeterCommandClass] - NODE 68: Meter: Type=Electric(1), Scale=W(2), Value=477.36
15-Oct-2017 14:19:25.897 [DEBUG] [ab.binding.zwave.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveMeterValueEvent
15-Oct-2017 14:19:25.897 [DEBUG] [tocol.serialmessage.ApplicationCommandMessageClass] - NODE 58: Transaction not completed: node address inconsistent. lastSent=58, incoming=255
15-Oct-2017 14:19:25.989 [DEBUG] [wave.handler.ZWaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 14 00 04 00 44 0E 32 02 21 64 00 00 00 00 02 D0 00 00 00 00 02
15-Oct-2017 14:19:25.990 [DEBUG] [ab.binding.zwave.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
15-Oct-2017 14:19:25.990 [DEBUG] [nhab.binding.zwave.internal.protocol.SerialMessage] - Assembled message buffer = 01 14 00 04 00 44 0E 32 02 21 64 00 00 00 00 02 D0 00 00 00 00 02
15-Oct-2017 14:19:25.991 [DEBUG] [ab.binding.zwave.internal.protocol.ZWaveController] - Process Message = 01 14 00 04 00 44 0E 32 02 21 64 00 00 00 00 02 D0 00 00 00 00 02
15-Oct-2017 14:19:25.991 [DEBUG] [ab.binding.zwave.internal.protocol.ZWaveController] - Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 44 0E 32 02 21 64 00 00 00 00 02 D0 00 00 00 00
15-Oct-2017 14:19:25.991 [DEBUG] [tocol.serialmessage.ApplicationCommandMessageClass] - NODE 68: Application Command Request (ALIVE:DONE)
15-Oct-2017 14:19:25.991 [DEBUG] [protocol.initialization.ZWaveNodeInitStageAdvancer] - NODE 68: Starting initialisation from DONE
15-Oct-2017 14:19:25.992 [DEBUG] [ab.binding.zwave.internal.protocol.ZWaveController] - Event Listener org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer@2fa5f63c already registered
15-Oct-2017 14:19:25.992 [DEBUG] [tocol.serialmessage.ApplicationCommandMessageClass] - NODE 68: Incoming command class METER
15-Oct-2017 14:19:25.992 [DEBUG] [ernal.protocol.commandclass.ZWaveMeterCommandClass] - NODE 68: Received METER command V2
15-Oct-2017 14:19:25.992 [DEBUG] [ernal.protocol.commandclass.ZWaveMeterCommandClass] - NODE 68: Meter: Type=Electric(1), Scale=kWh(0), Value=0E+1
15-Oct-2017 14:19:25.992 [DEBUG] [ab.binding.zwave.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveMeterValueEvent
