is it possible to use a chart (page) as backgroud for a label cell in mainUI?
I would like to use a chart thats a bit more complex than just the trend line.
Thanks in advance,
Alex
Thanks in advance,
Alex
You can. Actually fairly easily. Just create the chart page using the page wizard and then copy the yaml code from the code tab of that chart. That code then goes in an oh-chart
component in the background
slot of the label card:
component: oh-label-cell
title: Label Cell
label: With a chart
footer: Demo
slots:
background:
- component: div
slots:
default:
- component: oh-chart
...pasted chart page code goes here
There’s a big caveat here, however. It’s going to take some work to get it to look pretty. The div
that I added in the example up there is not strictly necessary, but I suspect you’re going to want it because you’re gong to need to add a bunch of css styling to get the size, position, and look of the chart to work out. For example. I would probably fade the chart out some with:
- component: div
style:
opacity: .5
slots:
default:
Thank you!
