I have used the karaf console with putty “ssh -p 8101 openhab@localhost” and the “log:tail” and have get following result after a reboot of the system:
openhab> log:tail
07:29:00.725 [INFO ] [smarthome.event.BindingEvent ] - org.openhab.bindi ng.zwave.event.BindingEvent@16b81725
07:29:02.471 [INFO ] [ig.discovery.internal.PersistentInbox] - Added new thing ' zwave:device:f5679b52:node2' to inbox.
07:29:02.472 [INFO ] [smarthome.event.InboxAddedEvent ] - Discovery Result with UID 'zwave:device:f5679b52:node2' has been added.
07:29:02.515 [INFO ] [ig.discovery.internal.PersistentInbox] - Added new thing ' zwave:device:f5679b52:node3' to inbox.
07:29:02.517 [INFO ] [smarthome.event.InboxAddedEvent ] - Discovery Result with UID 'zwave:device:f5679b52:node3' has been added.
07:29:02.535 [INFO ] [ig.discovery.internal.PersistentInbox] - Added new thing ' zwave:device:f5679b52:node4' to inbox.
07:29:02.537 [INFO ] [smarthome.event.InboxAddedEvent ] - Discovery Result with UID 'zwave:device:f5679b52:node4' has been added.
07:29:02.558 [INFO ] [ig.discovery.internal.PersistentInbox] - Added new thing ' zwave:device:f5679b52:node5' to inbox.
07:29:02.560 [INFO ] [smarthome.event.InboxAddedEvent ] - Discovery Result with UID 'zwave:device:f5679b52:node5' has been added.
07:29:02.574 [WARN ] [zwave.discovery.ZWaveDiscoveryService] - NODE 6: Device di scovery could not resolve to a thingType! Manufacturer data not known.
07:29:05.987 [INFO ] [smarthome.event.InboxRemovedEvent ] - Discovery Result with UID 'zwave:device:f5679b52:node2' has been removed.
07:29:06.017 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'zwave:device:f56 79b52:node2' changed from UNINITIALIZED to INITIALIZING
07:29:06.029 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'zwave:device:f56 79b52:node2' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller i s offline
07:29:06.034 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'zwave:device:f56 79b52:node2' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONL INE
07:29:06.154 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing 'zwave:devi ce:f5679b52:node2' has been updated.
07:29:06.220 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing 'zwave:devi ce:f5679b52:node2' has been updated.
07:29:06.299 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing 'zwave:devi ce:f5679b52:node2' has been updated.
07:29:06.361 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing 'zwave:devi ce:f5679b52:node2' has been updated.
07:29:06.367 [INFO ] [smarthome.event.ConfigStatusInfoEvent] - ConfigStatusInfo [configStatusMessages=[]]
07:29:08.220 [INFO ] [smarthome.event.InboxRemovedEvent ] - Discovery Result with UID 'zwave:device:f5679b52:node3' has been removed.
07:29:08.293 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'zwave:device:f56 79b52:node3' changed from UNINITIALIZED to INITIALIZING
07:29:08.325 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'zwave:device:f56 79b52:node3' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller i s offline
07:29:08.331 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'zwave:device:f56 79b52:node3' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONL INE
07:29:08.500 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing 'zwave:devi ce:f5679b52:node3' has been updated.
07:29:08.550 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing 'zwave:devi ce:f5679b52:node3' has been updated.
07:29:08.617 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing 'zwave:devi ce:f5679b52:node3' has been updated.
07:29:08.700 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing 'zwave:devi ce:f5679b52:node3' has been updated.
07:29:08.706 [INFO ] [smarthome.event.ConfigStatusInfoEvent] - ConfigStatusInfo [configStatusMessages=[]]
07:29:10.358 [INFO ] [smarthome.event.InboxRemovedEvent ] - Discovery Result with UID 'zwave:device:f5679b52:node4' has been removed.
07:29:10.392 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'zwave:device:f56 79b52:node4' changed from UNINITIALIZED to INITIALIZING
07:29:10.400 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'zwave:device:f56 79b52:node4' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller i s offline
07:29:10.418 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'zwave:device:f56 79b52:node4' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to OFF LINE (COMMUNICATION_ERROR): Node is not communicating with controller
07:29:10.523 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing 'zwave:devi ce:f5679b52:node4' has been updated.
07:29:10.586 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing 'zwave:devi ce:f5679b52:node4' has been updated.
07:29:10.651 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing 'zwave:devi ce:f5679b52:node4' has been updated.
07:29:10.706 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing 'zwave:devi ce:f5679b52:node4' has been updated.
07:29:10.708 [INFO ] [smarthome.event.ConfigStatusInfoEvent] - ConfigStatusInfo [configStatusMessages=[]]
07:29:14.517 [INFO ] [smarthome.event.InboxRemovedEvent ] - Discovery Result with UID 'zwave:device:f5679b52:node5' has been removed.
07:29:14.549 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'zwave:device:f56 79b52:node5' changed from UNINITIALIZED to INITIALIZING
07:29:14.559 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'zwave:device:f56 79b52:node5' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller i s offline
07:29:14.562 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'zwave:device:f56 79b52:node5' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONL INE
07:29:14.666 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing 'zwave:devi ce:f5679b52:node5' has been updated.
07:29:14.743 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing 'zwave:devi ce:f5679b52:node5' has been updated.
07:29:14.827 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing 'zwave:devi ce:f5679b52:node5' has been updated.
07:29:14.909 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing 'zwave:devi ce:f5679b52:node5' has been updated.
07:29:14.912 [INFO ] [smarthome.event.ConfigStatusInfoEvent] - ConfigStatusInfo [configStatusMessages=[]]
07:29:21.902 [WARN ] [.sitemap.internal.SitemapProviderImpl] - Filename `Wohnung .sitemap` does not match the name `Wohung` of the sitemap - please fix this as y ou might see unexpected behavior otherwise.
07:29:21.914 [WARN ] [.sitemap.internal.SitemapProviderImpl] - Filename `Wohnung .sitemap` does not match the name `Wohung` of the sitemap - please fix this as y ou might see unexpected behavior otherwise.
07:29:21.918 [WARN ] [.sitemap.internal.SitemapProviderImpl] - Filename `Wohnung .sitemap` does not match the name `Wohung` of the sitemap - please fix this as y ou might see unexpected behavior otherwise.
07:29:22.964 [WARN ] [.sitemap.internal.SitemapProviderImpl] - Filename `Wohnung .sitemap` does not match the name `Wohung` of the sitemap - please fix this as y ou might see unexpected behavior otherwise.
07:29:51.573 [INFO ] [smarthome.event.ItemStateChangedEvent] - Wohn_Temp_Ist changed from NULL to 22.91
07:29:51.654 [INFO ] [smarthome.event.ItemStateChangedEvent] - Wohn_Temp_Soll changed from NULL to 16
07:29:51.725 [INFO ] [smarthome.event.ItemStateChangedEvent] - Wohn_Temp_Batterie changed from NULL to 90
07:29:53.278 [WARN ] [.sitemap.internal.SitemapProviderImpl] - Filename `Wohnung.sitemap` does not match the name `Wohung` of the sitemap - please fix this as you might see unexpected behavior otherwise.
07:29:53.289 [WARN ] [.sitemap.internal.SitemapProviderImpl] - Filename `Wohnung.sitemap` does not match the name `Wohung` of the sitemap - please fix this as you might see unexpected behavior otherwise.
07:29:53.296 [WARN ] [.sitemap.internal.SitemapProviderImpl] - Filename `Wohnung.sitemap` does not match the name `Wohung` of the sitemap - please fix this as you might see unexpected behavior otherwise.
07:29:54.335 [WARN ] [.sitemap.internal.SitemapProviderImpl] - Filename `Wohnung.sitemap` does not match the name `Wohung` of the sitemap - please fix this as you might see unexpected behavior otherwise.
I have corrected the “Wohung” to “Wohnung”, but this make no different. Has anybody another idea?
I have restarted the system again and deleted all persistence files, please find below the new log file, the warning is now gone.
07:29:11.397 [INFO ] [thome.event.ItemChannelLinkAddedEvent] - Link ‘Steck1_Schalter-tplinksmarthome:hs110:892D8F:switch’ has been added.
07:29:11.402 [INFO ] [thome.event.ItemChannelLinkAddedEvent] - Link ‘Steck1_Verbrauch-tplinksmarthome:hs110:892D8F:energyUsage’ has been added.
07:29:11.404 [INFO ] [thome.event.ItemChannelLinkAddedEvent] - Link ‘Ess_Radio_Power-bosesoundtouch:20:68C90B2C9195:power’ has been added.
07:29:11.406 [INFO ] [thome.event.ItemChannelLinkAddedEvent] - Link ‘Schlaf_Temp_Soll-zwave:device:f5679b52:node4:thermostat_setpoint_heating’ has been added.
07:29:11.415 [INFO ] [thome.event.ItemChannelLinkAddedEvent] - Link ‘Steck1_Power-tplinksmarthome:hs110:892D8F:power’ has been added.
07:29:11.420 [INFO ] [thome.event.ItemChannelLinkAddedEvent] - Link ‘Ess_Temp_Ist-zwave:device:947cd532:node3:sensor_temperature’ has been added.
07:29:11.422 [INFO ] [thome.event.ItemChannelLinkAddedEvent] - Link ‘Steckdose1_Switch-tplinksmarthome:hs110:892D8F:switch’ has been added.
07:29:11.720 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - ‘astro:sun:home’ changed from UNINITIALIZED to INITIALIZING
07:29:11.770 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - ‘astro:sun:home’ changed from INITIALIZING to ONLINE
07:29:12.101 [INFO ] [rthome.binding.astro.internal.job.Job] - Scheduled Astro event-jobs for thing astro:sun:home
07:29:12.141 [INFO ] [smarthome.event.ItemStateChangedEvent] - Sunrise_Time changed from NULL to 2019-07-23T05:29:00.000+0200
07:29:12.152 [INFO ] [smarthome.event.ItemStateChangedEvent] - Sunset_Time changed from NULL to 2019-07-23T21:32:00.000+0200
07:29:12.216 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - ‘zwave:device:f5679b52:node4’ changed from UNINITIALIZED to UNINITIALIZED (HANDLER_CONFIGURATION_PENDING)
07:29:12.223 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - ‘zwave:device:f5679b52:node5’ changed from UNINITIALIZED to UNINITIALIZED (HANDLER_CONFIGURATION_PENDING)
07:29:12.235 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - ‘zwave:device:f5679b52:node2’ changed from UNINITIALIZED to UNINITIALIZED (HANDLER_CONFIGURATION_PENDING)
07:29:12.243 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - ‘zwave:device:f5679b52:node3’ changed from UNINITIALIZED to UNINITIALIZED (HANDLER_CONFIGURATION_PENDING)
07:29:12.653 [WARN ] [core.common.registry.AbstractRegistry] - Cannot add “ThingImpl” with key “zwave:device:f5679b52:node5”. It exists already from provider “GenericThingProvider”! Failed to add a second with the same UID from provider “ManagedThingProvider”!
07:29:12.656 [WARN ] [core.common.registry.AbstractRegistry] - Cannot add “ThingImpl” with key “zwave:device:f5679b52:node2”. It exists already from provider “GenericThingProvider”! Failed to add a second with the same UID from provider “ManagedThingProvider”!
07:29:12.660 [WARN ] [core.common.registry.AbstractRegistry] - Cannot add “ThingImpl” with key “zwave:device:f5679b52:node4”. It exists already from provider “GenericThingProvider”! Failed to add a second with the same UID from provider “ManagedThingProvider”!
07:29:12.663 [WARN ] [core.common.registry.AbstractRegistry] - Cannot add “ThingImpl” with key “zwave:device:f5679b52:node3”. It exists already from provider “GenericThingProvider”! Failed to add a second with the same UID from provider “ManagedThingProvider”!
07:29:12.817 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - ‘zwave:serial_zstick:f5679b52’ changed from UNINITIALIZED to INITIALIZING
07:29:12.865 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - ‘zwave:serial_zstick:f5679b52’ changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
07:29:12.870 [INFO ] [ding.zwave.handler.ZWaveSerialHandler] - Connecting to serial port ‘/dev/ttyACM0’
07:29:13.008 [INFO ] [ding.zwave.handler.ZWaveSerialHandler] - Serial port is initialized
07:29:13.055 [INFO ] [ave.internal.protocol.ZWaveController] - Starting ZWave controller
07:29:13.057 [INFO ] [ave.internal.protocol.ZWaveController] - ZWave timeout is set to 5000ms. Soft reset is false.
07:29:13.388 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - ‘astro:sun:4b0273d7’ changed from UNINITIALIZED to INITIALIZING
07:29:13.391 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - ‘astro:sun:4b0273d7’ changed from INITIALIZING to ONLINE
07:29:13.546 [INFO ] [rthome.binding.astro.internal.job.Job] - Scheduled Astro event-jobs for thing astro:sun:4b0273d7
07:29:13.620 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - ‘tplinksmarthome:hs110:892D8F’ changed from UNINITIALIZED to INITIALIZING
07:29:13.671 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - ‘tplinksmarthome:hs110:892D8F’ changed from INITIALIZING to UNKNOWN
07:29:13.817 [WARN ] [core.common.registry.AbstractRegistry] - Cannot add “NumberItem” with key “Ess_Temp_Ist”. It exists already from provider “GenericItemProvider”! Failed to add a second with the same UID from provider “ManagedItemProvider”!
07:29:13.927 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - ‘bosesoundtouch:20:68C90B2C9195’ changed from UNINITIALIZED to INITIALIZING
07:29:14.030 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - ‘tplinksmarthome:hs110:892D8F’ changed from UNKNOWN to ONLINE
07:29:14.110 [INFO ] [smarthome.event.ItemStateChangedEvent] - Steckdose1_Switch changed from NULL to ON
07:29:14.141 [INFO ] [smarthome.event.ItemStateChangedEvent] - Steck1_Schalter changed from NULL to ON
07:29:14.149 [INFO ] [smarthome.event.ItemStateChangedEvent] - Steck1_Power changed from NULL to 1.825
07:29:14.154 [INFO ] [smarthome.event.ItemStateChangedEvent] - Steck1_Verbrauch changed from NULL to 0.001
07:29:14.719 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - ‘bosesoundtouch:20:68C90B2C9195’ changed from INITIALIZING to ONLINE
07:29:15.033 [INFO ] [smarthome.event.ItemStateChangedEvent] - Ess_Radio_Power changed from NULL to OFF
07:29:15.258 [INFO ] [i.dashboard.internal.DashboardService] - Started Dashboard at http://192.168.178.99:8080
07:29:15.263 [INFO ] [i.dashboard.internal.DashboardService] - Started Dashboard at https://192.168.178.99:8443
07:29:16.047 [INFO ] [marthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
07:29:17.683 [ERROR] [ave.internal.protocol.ZWaveController] - NODE 6: Restore from config: Error deserialising XML file. com.thoughtworks.xstream.mapper.CannotResolveClassException: thing-descriptions
07:29:20.854 [INFO ] [weather.internal.common.WeatherConfig] - ProviderConfig[providerName=FORECASTIO,apiKey=2438947c8b1cd826f1d6279002b4ab4a]
07:29:20.861 [INFO ] [weather.internal.common.WeatherConfig] - LocationConfig[providerName=FORECASTIO,language=de,updateInterval=10,latitude=53.06174938591016,longitude=8.804022813691002,woeid=,locationId=home,name=]
07:29:23.968 [INFO ] [nternal.scheduler.WeatherJobScheduler] - Starting and scheduling weatherJob-home with interval of 10 minutes
07:29:27.414 [INFO ] [smarthome.event.ItemStateChangedEvent] - Temp_Outside changed from NULL to 16.48
07:29:31.514 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - ‘zwave:serial_zstick:f5679b52’ changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
07:29:31.558 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing ‘zwave:serial_zstick:f5679b52’ has been updated.
I have used te command from opus, but have get no result in the karaf console, so i have uninstalled the persistence and and installed it new. After this a had also no rsult with this comment, but with log:tail i had a warining, 06:39:46.910 [WARN ] [rthome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found., so I have restarted openhab. After the resart the comment log:set DEBUG org.openhab.persistence.rrd4j also gives no feedback. I have added again the log files below:
07:05:53.627 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'zwave:device:f5679b52:node3' changed from REMOVING to REMOVED
07:05:53.653 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'zwave:device:f5679b52:node3' changed from REMOVED to UNINITIALIZED
07:05:53.687 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'zwave:device:f5679b52:node3' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
07:05:57.152 [INFO ] [smarthome.event.BindingEvent ] - org.openhab.binding.zwave.event.BindingEvent@1f5ebd5e
07:05:59.163 [INFO ] [ig.discovery.internal.PersistentInbox] - Added new thing 'zwave:device:f5679b52:node2' to inbox.
07:05:59.165 [INFO ] [smarthome.event.InboxAddedEvent ] - Discovery Result with UID 'zwave:device:f5679b52:node2' has been added.
07:05:59.207 [INFO ] [ig.discovery.internal.PersistentInbox] - Added new thing 'zwave:device:f5679b52:node3' to inbox.
07:05:59.209 [INFO ] [smarthome.event.InboxAddedEvent ] - Discovery Result with UID 'zwave:device:f5679b52:node3' has been added.
07:05:59.228 [INFO ] [ig.discovery.internal.PersistentInbox] - Added new thing 'zwave:device:f5679b52:node4' to inbox.
07:05:59.230 [INFO ] [smarthome.event.InboxAddedEvent ] - Discovery Result with UID 'zwave:device:f5679b52:node4' has been added.
07:05:59.251 [INFO ] [ig.discovery.internal.PersistentInbox] - Added new thing 'zwave:device:f5679b52:node5' to inbox.
07:05:59.253 [INFO ] [smarthome.event.InboxAddedEvent ] - Discovery Result with UID 'zwave:device:f5679b52:node5' has been added.
07:05:59.268 [WARN ] [zwave.discovery.ZWaveDiscoveryService] - NODE 6: Device discovery could not resolve to a thingType! Manufacturer data not known.
07:06:01.682 [INFO ] [smarthome.event.InboxRemovedEvent ] - Discovery Result with UID 'zwave:device:f5679b52:node2' has been removed.
07:06:01.729 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'zwave:device:f5679b52:node2' changed from UNINITIALIZED to INITIALIZING
07:06:01.737 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'zwave:device:f5679b52:node2' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
07:06:01.743 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'zwave:device:f5679b52:node2' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
07:06:01.809 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing 'zwave:device:f5679b52:node2' has been updated.
07:06:01.854 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing 'zwave:device:f5679b52:node2' has been updated.
07:06:01.928 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing 'zwave:device:f5679b52:node2' has been updated.
07:06:02.014 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing 'zwave:device:f5679b52:node2' has been updated.
07:06:02.048 [INFO ] [smarthome.event.ConfigStatusInfoEvent] - ConfigStatusInfo [configStatusMessages=[]]
07:06:03.719 [INFO ] [smarthome.event.InboxRemovedEvent ] - Discovery Result with UID 'zwave:device:f5679b52:node3' has been removed.
07:06:03.773 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'zwave:device:f5679b52:node3' changed from UNINITIALIZED to INITIALIZING
07:06:03.788 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'zwave:device:f5679b52:node3' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
07:06:03.792 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'zwave:device:f5679b52:node3' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
07:06:03.831 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing 'zwave:device:f5679b52:node3' has been updated.
07:06:03.866 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing 'zwave:device:f5679b52:node3' has been updated.
07:06:03.898 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing 'zwave:device:f5679b52:node3' has been updated.
07:06:03.936 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing 'zwave:device:f5679b52:node3' has been updated.
07:06:03.938 [INFO ] [smarthome.event.ConfigStatusInfoEvent] - ConfigStatusInfo [configStatusMessages=[]]
07:06:05.258 [INFO ] [smarthome.event.InboxRemovedEvent ] - Discovery Result with UID 'zwave:device:f5679b52:node4' has been removed.
07:06:05.297 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'zwave:device:f5679b52:node4' changed from UNINITIALIZED to INITIALIZING
07:06:05.300 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'zwave:device:f5679b52:node4' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
07:06:05.317 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'zwave:device:f5679b52:node4' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
07:06:05.347 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing 'zwave:device:f5679b52:node4' has been updated.
07:06:05.374 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing 'zwave:device:f5679b52:node4' has been updated.
07:06:05.402 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing 'zwave:device:f5679b52:node4' has been updated.
07:06:05.434 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing 'zwave:device:f5679b52:node4' has been updated.
07:06:05.436 [INFO ] [smarthome.event.ConfigStatusInfoEvent] - ConfigStatusInfo [configStatusMessages=[]]
07:06:07.868 [INFO ] [smarthome.event.InboxRemovedEvent ] - Discovery Result with UID 'zwave:device:f5679b52:node5' has been removed.
07:06:07.893 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'zwave:device:f5679b52:node5' changed from UNINITIALIZED to INITIALIZING
07:06:07.902 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'zwave:device:f5679b52:node5' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
07:06:07.909 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'zwave:device:f5679b52:node5' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
07:06:07.949 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing 'zwave:device:f5679b52:node5' has been updated.
07:06:07.976 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing 'zwave:device:f5679b52:node5' has been updated.
07:06:08.011 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing 'zwave:device:f5679b52:node5' has been updated.
07:06:08.047 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing 'zwave:device:f5679b52:node5' has been updated.
07:06:08.048 [INFO ] [smarthome.event.ConfigStatusInfoEvent] - ConfigStatusInfo [configStatusMessages=[]]
07:07:27.171 [INFO ] [smarthome.event.ItemStateChangedEvent] - Temp_Outside changed from 22.48 to 22.66
I think my post was not detailed enough. The command posted above should RAISE the log level, it will not Display any message! In order to see log messages on the console the command “log:tail” is always needed!
If you get the WARN about missing a persitence Service and you don’t see any rrd4j related messages on Startup all I could assume is that you DO NOT have a persistence service installed. You did have it installed while you were doing the REST call (some posts above) and receiving Zero entries in the database.
Could it be that you have the rrd4j.cfg and rrd4j.persist created but the persistence service is actually not installed?
I you do not know, please check the output of bundle:list on the karaf console for any line with rrd4j.
Sorry for the late reply, but i was on the way and had no access to my server.
I have checked in the console the command " bundle:list" and have found only one entry with rrd4j: 253 │ Active │ 80 │ 1.13.0 │ openHAB RRD4j Persistence Bund
Is this correct?
In the last days I have installed a new Java Version (1.8.0_241) and Openhab 2.5, so I tried again to use a persistence.
I use again the rrd4j persistence and now it worked. I can see my graph, but the axes from the chart are not lettered correctly, please see attached picture:
Does someone has an Idea, why I can’t see the temperature and the time?
Yes it’s from a sitemap, and it is the same in a Windows PC or the open hab App at the android smartphone.
What do you mean with could? It is displayed with a “chart” in the sitemap. The scaling is automatically, if the temp rise the scale will automatically changed.
