- Platform information:
- Hardware: Raspberry pi 4
- OS: openhabian
- Java Runtime Environment: 11.0.9
- openHAB version:3.0.1
- Issue of the topic:
Im trying to get the chart functionality to work in the ios openhab app.
I have my chart defined in my sitemap as per:
Chart item=Lounge_Temps label=“Internal Temperature” refresh=600 period=D legend=false
Where lounge temps is a group of temperatures.
This works fine in basic ui, but will not show up in the ios app.
If i remove one item, from the list (the setpoint temperature) it works correctly.
the only difference i can see between the ones that work and dont, is the category, the ones that work are temperature whereas the ones that don’t work are categorised as heating.
However if i then change this to :temperature on the ones that do not work, it still does not resolve the issue.
Is there anyway i can see exactly the differences between two items?
