marcofabb
(marcofabb)
January 31, 2016, 1:03pm
#1
how can I show “Temperature” and Tout" in 1 chart?
I add Temperature and Tout in a group “Temperatures” in .Item but if I replace to Temperature, The chart is not visible
Text label=“Grafici” icon=“temperature” {
Switch item=Chart_Period label="" mappings=[1=“Day”, 2=“Week”, 3=“Month”, 4=“4 Months” ]
Chart item=Temperature period=D refresh=30000 visibility=[Chart_Period==1, Chart_Period==“Uninitialized”]
Chart item=Temperature period=W refresh=21600000 visibility=[Chart_Period==2] //week
Chart item=Temperature period=M refresh=21600000 visibility=[Chart_Period==3] //month
Chart item=Temperature period=4M refresh=86400000 visibility=[Chart_Period==4]//4 month
Chart item=Tout period=D refresh=30000 visibility=[Chart_Period==1, Chart_Period=="Uninitialized"]
Chart item=Tout period=W refresh=21600000 visibility=[Chart_Period==2] //week
Chart item=Tout period=M refresh=21600000 visibility=[Chart_Period==3] //month
Chart item=Tout period=4M refresh=86400000 visibility=[Chart_Period==4]//4 month
Mpower
(M)
January 31, 2016, 1:34pm
#2
Maybe csn u show the parts of your.items
marcofabb
(marcofabb)
January 31, 2016, 2:37pm
#3
my full .item
sitemap test label=“Relase 0.1”
Frame {
Switch item=CANCELLINO mappings=[ON="APRI"] icon=door-closed
Switch item=PORTONE mappings=[ON="APRI"] icon=door-closed
Text item=Temperature
Text item=Umidita
Text item=Tout
Text item=Uout
Colorpicker item=RGB
Text label="Grafici" icon="temperature" {
Switch item=Chart_Period label="" mappings=[1="Day", 2="Week", 3="Month", 4="4 Months" ]
Chart item=Temperature period=D refresh=30000 visibility=[Chart_Period==1, Chart_Period=="Uninitialized"]
Chart item=Umidita period=D refresh=30000 visibility=[Chart_Period==1, Chart_Period=="Uninitialized"]
Chart item=Umidita period=W refresh=21600000 visibility=[Chart_Period==2] //week
Chart item=Umidita period=M refresh=21600000 visibility=[Chart_Period==3] //month
Chart item=Umidita period=4M refresh=86400000 visibility=[Chart_Period==4]//4month
Chart item=Uout period=D refresh=30000 visibility=[Chart_Period==1, Chart_Period=="Uninitialized"]
Chart item=Uout period=W refresh=21600000 visibility=[Chart_Period==2] //week
Chart item=Uout period=M refresh=21600000 visibility=[Chart_Period==3] //month
Chart item=Uout period=4M refresh=86400000 visibility=[Chart_Period==4]//4month
end full .sitemap
Group All
Group gD (All)
Group Node0 (All)
Group Node1 (All)
Group Node2 (All)
Group Ingresso (All)
Group Cucina (All)
Group temperatures (All)
Group humiditys (All)
Switch CANCELLINO “CANCELLINO” (Ingresso, Node0) {souliss=“T11:0:2”, autoupdate=false}
Switch PORTONE “PORTONE” (Ingresso, Node0) {souliss=“T11:0:3”, autoupdate=false}
Number Temperature “Temperatura P.Terra [%.1f °C]” (temperatures, Node0) {souliss=“T52:0:4”}
Number Umidita “Umidità P.Terra[%.1f %%]” (humiditys, Node0) {souliss=“T53:0:6”}
Number Tout “Temperatura Fuori [%.1f °C]” (temperatures, Node1) {souliss=“T52:1:0”}
Number Uout “Umidità Fuori [%.1f %%]” (humiditys, Node1) {souliss=“T53:1:2”}
Color RGB “RGB” (Cucina,Node2) {souliss=“T16:2:0”, autoupdate=false}
Number HEALTHNodo0 “Health Node 0 [%1d]” (Diagnostic, TechnicView_Node0, Health) {souliss=“D98:0:998”}
String TIMESTAMP_Nodo0 “Update Node 0 [%1$td.%1$tm.%1$tY %1$tk:%1$tM:%1$tS]” (Diagnostic, TechnicView_Node0) {souliss=“D99:0:999”}
Number Chart_Period “Chart Period”
Mpower
(M)
January 31, 2016, 5:40pm
#4
I don’t see a chart in your sitemap where you do a chart with your group “temperatures” there is just “Temperature”
marcofabb
(marcofabb)
February 1, 2016, 1:30pm
#5
ok I can see 1 temperature im 1 chart.
if I use this sitemap i don t see nothing (no graphic no line)
Frame {
Text item=Umidita
Text item=Tout
Text item=Uout
Chart item=Temperatures period=D refresh=30000 visibility=[Chart_Period==1, Chart_Period=="Uninitialized"]
Chart item=Temperatures period=W refresh=21600000 visibility=[Chart_Period==2] //week
Chart item=Temperatures period=M refresh=21600000 visibility=[Chart_Period==3] //month
Chart item=Temperatures period=4M refresh=86400000 visibility=[Chart_Period==4]//4 month
Chart item=humiditys period=D refresh=30000 visibility=[Chart_Period==1, Chart_Period=="Uninitialized"]
Chart item=humiditys period=W refresh=21600000 visibility=[Chart_Period==2] //week
Chart item=humiditys period=M refresh=21600000 visibility=[Chart_Period==3] //month
Chart item=humiditysperiod=4M refresh=86400000 visibility=[Chart_Period==4]//4month
Mpower
(M)
February 1, 2016, 3:12pm
#6
And how is your persistence settings?
Check also How to display charts in sitemaps? where the same topic is discussed
marcofabb
(marcofabb)
February 1, 2016, 3:50pm
#7
my rrd4j.persist
// persistence strategies have a name and a definition and are referred to in the “Items” section
Strategies {
// for rrd charts, we need a cron strategy
everyMinute : “0 * * * * ?”
Items {
Temperature : strategy = everyMinute
Umidita : strategy = everyMinute
Tout: strategy = everyMinute
Uout : strategy = everyMinute
Mpower
(M)
February 1, 2016, 4:25pm
#8
I think you need to put in a persistence value for “Temperatures”
// persist all items once a day and on every change and restore them from the db at startup
* : strategy = everyChange, everyDay, restoreOnStartup
would be good
sihui
(SiHui)
February 1, 2016, 4:32pm
#9
Please have in mind that rrd4j only works reliable with everyMinute
