i had two different charts working fine. Yesterday my raspi 3 hang up, so i had to reboot it. Now my charts only show the old data (gathered before the hang up) but no more new data are shown. Any idea?
Christian H.
Christian H.
Hi Christian
It seems that your persistence is not working correctly, as no new data is being logged.
Some ideas:
HI,
i found the following messages in the log:
[19:10:41] pi@openHABianPi:~$ more /var/log/openhab2/openhab.log | grep rrd4j
2017-04-15 21:49:32.879 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'rrd4j.persist'
2017-04-15 21:49:32.924 [ERROR] [.core.internal.folder.FolderObserver] - Error handling update of file '/etc/openhab2/persistence/rrd4j.persist': Value must be between 0 and 100.
2017-04-15 21:49:32.928 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'rrd4j.persist'
2017-04-15 21:49:32.967 [ERROR] [.core.internal.folder.FolderObserver] - Error handling update of file '/etc/openhab2/persistence/rrd4j.persist': Value must be between 0 and 100.
2017-04-16 16:52:07.801 [ERROR] [sistence.rrd4j.internal.RRD4jService] - Could not create rrd4j database file '/var/lib/openhab2/persistence/rrd4j/gHMRoll.rrd': sync failed
But i had empty charts the days before.
RRD4J should be running, i deinstalled it and installed it again. It is directly running on the pi.
hope that helps.
Christian
It seems something you have in your rrd4j.persist file is not being accepted by openHAB. Could you show the contents of that file?
Does this info help: http://docs.openhab.org/addons/persistence/rrd4j/readme.html#troubleshooting
here is the content of rrd4j.persist (so it worked fine before the RPI restart):
// persistence strategies have a name and a definition and are referred to in the "Items" section
Strategies {
// for rrd charts, we need a cron strategy
everyMinute : "0 * * * * ?"
Items {
HelligkeitOst : strategy = everyMinute, restoreOnStartup
HelligkeitSued : strategy = everyMinute, restoreOnStartup
HelligkeitWest : strategy = everyMinute, restoreOnStartup
HelligkeitNord : strategy = everyMinute, restoreOnStartup
Temperatur : strategy = everyMinute, restoreOnStartup
TemperaturN : strategy = everyMinute, restoreOnStartup
// persist all items on every change and restore them from the MapDB at startup
* : strategy = everyChange, restoreOnStartup
Hmm… I cannot help you any further…
