Before you had a white chart while using a dark theme, which was not what the user expects. This was changed when themes were added to charts in [UI] Charts Enhancements: Themes, DPI, legend hiding by hreichert · Pull Request #4291 · eclipse-archived/smarthome · GitHub. The client side change to request those themes was Make use of eclipse/smarthome#4291 by mueller-ma · Pull Request #386 · openhab/openhab-android · GitHub.
In the latest beta (2.1.9) there is a setting to change the chart scaling.
The solution ? Conclusion? it is solved?
Martin
halloween
(Hallo Ween)
43
I´m on snapshots and yes, now it works. You can configure charts in paper ui and inside habdroid (openhab android app).
