I’ve got a sitemap with some standard charts which use persistence (jdbc persistence on a MariaDB server). These are working fine.
Except when they’re not.
When OH starts running the charts display as they should. Sometime later I’m getting the ‘image not found’ icon in the sitemap, and they won’t display again unless i restart OH.
Does anyone have any suggestions for how I can cure this please?
Stating what Kind of persistence Service is used and if you are using the standard Charts (and ont Grafana) would help lopcating the problem.
Any log-entries when during such call would also help!
I’ve got three charts on the page. The number of those error lines appears to match the number of charts which failed to display (just one failed to display on the first refresh, the others failed on subsequent refreshes).
This error was reported lately by users of an openhabian installation and could be solved by installing fontconfig (read here). However since you are seing this only sometimes, this might not fit.
