Java Runtime Environment: which java platform is used and what version
openHAB version: 2.3.0
All was OK, but I tried another UIs. HABmin, HABpanel, and classic UI. After using Classic UI, after one reboot, Charts are not shown in Basic UI.
it is with this massage
javax.servlet.ServletException: Could not get chart provider.
I have read many topics, but I have no solution.
Martin
it is installated. it is RRD4J. In HABmin it works. I checked in PAPER ui - default persistence engine - it is rrd4j
Martin.
Problem accessing /chart. Reason:
Server Error
Caused by:
at org.eclipse.smarthome.ui.internal.chart.ChartServlet.doGet(ChartServlet.java:282)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:687)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:790)
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:848)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:584)
at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143)
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:226)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1180)
at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:284)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:512)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:185)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1112)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:134)
at org.eclipse.jetty.server.Server.handle(Server.java:534)
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:333)
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:251)
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:283)
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:108)
at org.eclipse.jetty.io.SelectChannelEndPoint$2.run(SelectChannelEndPoint.java:93)
at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.executeProduceConsume(ExecuteProduceConsume.java:303)
at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.produceConsume(ExecuteProduceConsume.java:148)
at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.run(ExecuteProduceConsume.java:136)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:671)
at org.eclipse.jetty.util.thread.QueuedThreadPool$2.run(QueuedThreadPool.java:589)
at java.lang.Thread.run(Thread.java:745)
I wrote in last message. The charts work in other UIs. This seems like broken link for chart provider. I have to reinstall something? is there any general workaround to fix it?
Martin
I’ m new to mysql … it was working fine, but haven’t seen any data on chart. This was the hint: Is the persistence engine you are using set as the default?
I had running mapdb as default. After the change to mqsql … data is on the chart!
Thx
