Since I upgraded to openHAB 2.2, charts with only one item don’t show the legend when viewed from the iOS client. Charts with more than one item (groups) show it and everything works ok from the web browser. Also, lots of times, when the iOS client loads a chart, I get an exception.
Am I doing anything wrong?
I’m pasting below an example of item and chart definitios and an exception dump.
Thanks.
Number ConsumoElectrico "Consumo eléctrico [%.2f Wh]" <energy>
2018-01-18 13:02:50.173 [WARN ] [eclipse.jetty.servlet.ServletHandler] - /chart
javax.imageio.IIOException: I/O error writing PNG file!
at com.sun.imageio.plugins.png.PNGImageWriter.write(PNGImageWriter.java:1168) [?:?]
at javax.imageio.ImageWriter.write(ImageWriter.java:615) [?:?]
at javax.imageio.ImageIO.doWrite(ImageIO.java:1612) [?:?]
at javax.imageio.ImageIO.write(ImageIO.java:1492) [?:?]
at org.eclipse.smarthome.ui.internal.chart.ChartServlet.doGet(ChartServlet.java:302) [155:org.eclipse.smarthome.ui:0.10.0.b1]
at javax.servlet.http.HttpServlet.service(HttpServlet.java:687) [31:javax.servlet-api:3.1.0]
at javax.servlet.http.HttpServlet.service(HttpServlet.java:790) [31:javax.servlet-api:3.1.0]
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:848) [88:org.eclipse.jetty.servlet:9.3.22.v20171030]
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:584) [88:org.eclipse.jetty.servlet:9.3.22.v20171030]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71) [191:org.ops4j.pax.web.pax-web-jetty:6.0.7]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548) [85:org.eclipse.jetty.security:9.3.22.v20171030]
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:226) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1180) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:284) [191:org.ops4j.pax.web.pax-web-jetty:6.0.7]
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:512) [88:org.eclipse.jetty.servlet:9.3.22.v20171030]
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:185) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1112) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80) [191:org.ops4j.pax.web.pax-web-jetty:6.0.7]
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:134) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.eclipse.jetty.server.Server.handle(Server.java:534) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:333) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:251) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:283) [79:org.eclipse.jetty.io:9.3.22.v20171030]
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:108) [79:org.eclipse.jetty.io:9.3.22.v20171030]
at org.eclipse.jetty.io.SelectChannelEndPoint$2.run(SelectChannelEndPoint.java:93) [79:org.eclipse.jetty.io:9.3.22.v20171030]
at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.executeProduceConsume(ExecuteProduceConsume.java:303) [90:org.eclipse.jetty.util:9.3.22.v20171030]
at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.produceConsume(ExecuteProduceConsume.java:148) [90:org.eclipse.jetty.util:9.3.22.v20171030]
at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.run(ExecuteProduceConsume.java:136) [90:org.eclipse.jetty.util:9.3.22.v20171030]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:671) [90:org.eclipse.jetty.util:9.3.22.v20171030]
at org.eclipse.jetty.util.thread.QueuedThreadPool$2.run(QueuedThreadPool.java:589) [90:org.eclipse.jetty.util:9.3.22.v20171030]
Caused by: org.eclipse.jetty.io.EofException
at org.eclipse.jetty.io.ChannelEndPoint.flush(ChannelEndPoint.java:199) ~[79:org.eclipse.jetty.io:9.3.22.v20171030]
at org.eclipse.jetty.io.WriteFlusher.flush(WriteFlusher.java:420) ~[79:org.eclipse.jetty.io:9.3.22.v20171030]
at org.eclipse.jetty.io.WriteFlusher.write(WriteFlusher.java:313) ~[79:org.eclipse.jetty.io:9.3.22.v20171030]
at org.eclipse.jetty.io.AbstractEndPoint.write(AbstractEndPoint.java:147) ~[79:org.eclipse.jetty.io:9.3.22.v20171030]
at org.eclipse.jetty.server.HttpConnection$SendCallback.process(HttpConnection.java:739) ~[87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.eclipse.jetty.util.IteratingCallback.processing(IteratingCallback.java:241) ~[90:org.eclipse.jetty.util:9.3.22.v20171030]
at org.eclipse.jetty.util.IteratingCallback.iterate(IteratingCallback.java:224) ~[90:org.eclipse.jetty.util:9.3.22.v20171030]
at org.eclipse.jetty.server.HttpConnection.send(HttpConnection.java:519) ~[87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.eclipse.jetty.server.HttpChannel.sendResponse(HttpChannel.java:750) ~[87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.eclipse.jetty.server.HttpChannel.write(HttpChannel.java:801) ~[87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.eclipse.jetty.server.HttpOutput.write(HttpOutput.java:235) ~[87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.eclipse.jetty.server.HttpOutput.write(HttpOutput.java:219) ~[87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.eclipse.jetty.server.HttpOutput.flush(HttpOutput.java:355) ~[87:org.eclipse.jetty.server:9.3.22.v20171030]
at javax.imageio.stream.FileCacheImageOutputStream.flushBefore(FileCacheImageOutputStream.java:258) ~[?:?]
at com.sun.imageio.plugins.png.ChunkStream.finish(PNGImageWriter.java:140) ~[?:?]
at com.sun.imageio.plugins.png.PNGImageWriter.writeIEND(PNGImageWriter.java:951) ~[?:?]
at com.sun.imageio.plugins.png.PNGImageWriter.write(PNGImageWriter.java:1164) ~[?:?]
... 32 more
Caused by: java.io.IOException: Broken pipe
at sun.nio.ch.FileDispatcherImpl.writev0(Native Method) ~[?:?]
at sun.nio.ch.SocketDispatcher.writev(SocketDispatcher.java:51) ~[?:?]
at sun.nio.ch.IOUtil.write(IOUtil.java:148) ~[?:?]
at sun.nio.ch.SocketChannelImpl.write(SocketChannelImpl.java:504) ~[?:?]
at org.eclipse.jetty.io.ChannelEndPoint.flush(ChannelEndPoint.java:179) ~[79:org.eclipse.jetty.io:9.3.22.v20171030]
... 32 more
2018-01-18 13:02:50.197 [WARN ] [org.eclipse.jetty.server.HttpChannel] - //myopenhab.org/chart?random=910&period=h&items=ConsumoElectrico
javax.servlet.ServletException: javax.imageio.IIOException: I/O error writing PNG file!
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:88) [191:org.ops4j.pax.web.pax-web-jetty:6.0.7]
Caused by: javax.imageio.IIOException: I/O error writing PNG file!
at com.sun.imageio.plugins.png.PNGImageWriter.write(PNGImageWriter.java:1168) ~[?:?]
at javax.imageio.ImageWriter.write(ImageWriter.java:615) ~[?:?]
at javax.imageio.ImageIO.doWrite(ImageIO.java:1612) ~[?:?]
at javax.imageio.ImageIO.write(ImageIO.java:1492) ~[?:?]
at org.eclipse.smarthome.ui.internal.chart.ChartServlet.doGet(ChartServlet.java:302) ~[?:?]
at javax.servlet.http.HttpServlet.service(HttpServlet.java:687) ~[?:?]
at javax.servlet.http.HttpServlet.service(HttpServlet.java:790) ~[?:?]
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:848) ~[?:?]
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:584) ~[?:?]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71) ~[?:?]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143) ~[?:?]
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548) ~[?:?]
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:226) ~[?:?]
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1180) ~[?:?]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:284) ~[?:?]
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:512) ~[?:?]
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:185) ~[?:?]
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1112) ~[?:?]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141) ~[?:?]
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80) ~[?:?]
... 13 more
at org.eclipse.jetty.io.ChannelEndPoint.flush(ChannelEndPoint.java:199) ~[?:?]
at org.eclipse.jetty.io.WriteFlusher.flush(WriteFlusher.java:420) ~[?:?]
at org.eclipse.jetty.io.WriteFlusher.write(WriteFlusher.java:313) ~[?:?]
at org.eclipse.jetty.io.AbstractEndPoint.write(AbstractEndPoint.java:147) ~[?:?]
at org.eclipse.jetty.server.HttpConnection$SendCallback.process(HttpConnection.java:739) ~[?:?]
at org.eclipse.jetty.util.IteratingCallback.processing(IteratingCallback.java:241) ~[?:?]
at org.eclipse.jetty.util.IteratingCallback.iterate(IteratingCallback.java:224) ~[?:?]
at org.eclipse.jetty.server.HttpConnection.send(HttpConnection.java:519) ~[?:?]
at org.eclipse.jetty.server.HttpChannel.sendResponse(HttpChannel.java:750) ~[?:?]
at org.eclipse.jetty.server.HttpChannel.write(HttpChannel.java:801) ~[?:?]
at org.eclipse.jetty.server.HttpOutput.write(HttpOutput.java:235) ~[?:?]
at org.eclipse.jetty.server.HttpOutput.write(HttpOutput.java:219) ~[?:?]
at org.eclipse.jetty.server.HttpOutput.flush(HttpOutput.java:355) ~[?:?]
... 13 more
at org.eclipse.jetty.io.ChannelEndPoint.flush(ChannelEndPoint.java:179) ~[?:?]
... 13 more
2018-01-18 13:03:06.762 [WARN ] [io.openhabcloud.internal.CloudClient] - Jetty request 516273 failed: null
It’s getting worse. Now, from the iOS client, when connecting though myopenhab.org (it doesn’t happen when connecting from my LAN to my server), charts with only one element don’t show the legend or the graph:
And I’m getting these errors and exceptions in the log:
2018-01-24 09:15:16.108 [WARN ] [io.openhabcloud.internal.CloudClient] - Jetty request 408628 failed: null
2018-01-24 09:15:26.621 [WARN ] [io.openhabcloud.internal.CloudClient] - Jetty request 408665 failed: null
2018-01-24 09:15:26.626 [WARN ] [io.openhabcloud.internal.CloudClient] - Jetty request 408663 failed: null
2018-01-24 09:15:26.703 [WARN ] [eclipse.jetty.servlet.ServletHandler] - /chart
at com.sun.imageio.plugins.png.IDATOutputStream.finishChunk(PNGImageWriter.java:196) ~[?:?]
at com.sun.imageio.plugins.png.IDATOutputStream.finish(PNGImageWriter.java:254) ~[?:?]
at com.sun.imageio.plugins.png.PNGImageWriter.write_IDAT(PNGImageWriter.java:945) ~[?:?]
at com.sun.imageio.plugins.png.PNGImageWriter.write(PNGImageWriter.java:1158) ~[?:?]
... 32 more
... 32 more
2018-01-24 09:15:26.762 [WARN ] [org.eclipse.jetty.server.HttpChannel] - //myopenhab.org/chart?
... 13 more
... 13 more
... 13 more
2018-01-24 09:15:26.781 [WARN ] [eclipse.jetty.servlet.ServletHandler] - /chart
... 32 more
... 32 more
2018-01-24 09:15:26.964 [WARN ] [org.eclipse.jetty.server.HttpChannel] - //myopenhab.org/chart?random=85&period=D&items=DespachoHumedad
Also, many dynamic icons don’t work when on the app and through myopenhab.org.
When using the app at home against the server they work ok.
When using the browser at home or through myopenhab.org, they work ok.
