was keen to try out the CHATGPT binding but following the binding info and then running a script against the chat item I get:
2023-08-08 23:45:18.773 [INFO ] [openhab.event.ItemCommandEvent ] - Item ‘OpenAI_Account_Chat1’ received command Current time is 7am
2023-08-08 23:45:18.998 [ERROR] [ding.chatgpt.internal.ChatGPTHandler] - ChatGPT request resulted in HTTP 429 with message: Too Many Requests
what did I miss?
OK to answer this - API usage is only available on a paid account. On top of this you can omly use an API key ONCE you have signed up, ones before this wont work
OK anoher problem the doco says you can create multiple channels for different configurations but when I try to do this I get an errot 400 bad request returned from the API.
Ive logged this on Github but does anyone know if you can change a channel property in a rule easily? via DSL
