22:10:19.874 [WARN ] [org.apache.felix.fileinstall ] - Error while starting bundle: file:/usr/share/openhab2/addons/org.openhab.binding.chromecast-2.5.2-SNAPSHOT.jar
org.osgi.framework.BundleException: Could not resolve module: org.openhab.binding.chromecast [255]
Unresolved requirement: Import-Package: com.fasterxml.jackson.annotation; version="[2.9.0,3.0.0)"
at org.eclipse.osgi.container.Module.start(Module.java:444) ~[org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:383) ~[org.eclipse.osgi-3.12.100.jar:?]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.startBundle(DirectoryWatcher.java:1260) [bundleFile:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.startBundles(DirectoryWatcher.java:1233) [bundleFile:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.doProcess(DirectoryWatcher.java:520) [bundleFile:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.process(DirectoryWatcher.java:365) [bundleFile:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.run(DirectoryWatcher.java:316) [bundleFile:3.6.4]
sorry i forget to mention, i reinstalled 2.5.1 again… but i did already what u told me to do, uninstall the old one and put the new one in addon folder
guess what, i installed the audio group thing from paper UI and its online now, the audio group IP keeps changing between my two google mini… i have two google mini (192.168.0.20) & (192.168.0.21)… when i first installed the thing using the thing file, the primary ip for audio group thing was (192.168.0.21), now when i installed it from paper UI, it took (192.168.0.20) ip… port is the same… i hope if i kept it installed from paper UI, it will keep the sync… i think this is how audio group suppose to work, it will take one of the google mini’s IP as a primary one…
