After working perfectly for years, the Chromecast binding seems broken with 2.3 release. It doesn’t function at all, and on starting the binding I get the following errors:
2018-06-29 23:36:27.684 [WARN ] [su.litvak.chromecast.api.v2.Channel ] - Error while reading |
20|java.net.SocketException: Socket closed |
20| at java.net.SocketInputStream.socketRead0(Native Method) ~[?:?] |
ja| at java.net.SocketInputStream.socketRead(SocketInputStream.java:116) [?:?] |
| at java.net.SocketInputStream.read(SocketInputStream.java:171) [?:?] |
| at java.net.SocketInputStream.read(SocketInputStream.java:141) [?:?] |
| at sun.security.ssl.InputRecord.readFully(InputRecord.java:465) [?:?] |
| at sun.security.ssl.InputRecord.read(InputRecord.java:503) [?:?] |
| at sun.security.ssl.SSLSocketImpl.readRecord(SSLSocketImpl.java:983) [?:?] |
| at sun.security.ssl.SSLSocketImpl.readDataRecord(SSLSocketImpl.java:940) [?:?] |
| at sun.security.ssl.AppInputStream.read(AppInputStream.java:105) [?:?] |
| at sun.security.ssl.AppInputStream.read(AppInputStream.java:71) [?:?] |
| at su.litvak.chromecast.api.v2.Channel.read(Channel.java:411) [211:org.openhab.binding.chromecast:2.3.0] |
| at su.litvak.chromecast.api.v2.Channel.access$200(Channel.java:50) [211:org.openhab.binding.chromecast:2.3.0] |
| at su.litvak.chromecast.api.v2.Channel$ReadThread.run(Channel.java:132) [211:org.openhab.binding.chromecast:2.3.0] |
|2018-06-29 23:36:27.686 [WARN ] [su.litvak.chromecast.api.v2.Channel ] - <-- null payload in message |
|2018-06-29 23:36:27.687 [WARN ] [su.litvak.chromecast.api.v2.Channel ] - Error while closing channel |
The Chromecast is definitely there and functioning, and the Things and Items files haven’t changed. Has anyone else seen this?
thanks,
Dan
