Chromecast rule question
Maybe it’s a more question about rules in general
This is working:
if (E1chromecast_appId.state == "CA5E8412") {
    sendCommand(E1chromecast_control, PAUSE)  }
And this is not working:
if (E1chromecast_appId.state == "CA5E8412" && E1chromecast_control.state == "PLAY") {
E1Lachter1_Switch.sendCommand(ON)}
I think the question is, How can i find the correct state (name) of E1chromecast_control.state
Is it PLAY or PLAYING or somthing else?
Openhab 2.2 end chromecast binding 2.2
I trigger the rule with a xiaomi switch
Remove the quote.
if (E1chromecast_appId.state == "CA5E8412" && E1chromecast_control.state == PLAY) {
You can compare a string against another string, if that’s the case, you can also do this
if (E1chromecast_appId.state == "CA5E8412" && E1chromecast_control.state.toString == "PLAY") {
Thanks luckymallari,
Removing the quotation marks is the trick.
