CivilDusk Time Offset
Thank you, Greg. I hadn’t understood the concept of the range event. I’ve configured it and expect it will work fine this evening.
One question: The offset appears to apply to the range event for any rules which use it. For instance, if I have two rules and I want one to fire 30 minutes before sunset and one to fire 15 minutes after sunset, I wouldn’t be able to do that, since there is only one range event from astro:sun:local. I don’t suppose it’s possible to create a second instance of asto:sun:local or something?
Is my mental model accurate?
Thank you, again.
