I get this exception in openhab.log after upgrading to openHAB 2.2.0 Build #1008:
2017-08-13 11:50:33.147 [ERROR] [ome.core.thing.internal.ThingManager] - Exception occurred while calling thing handler factory 'org.openhab.binding.yamahareceiver.internal.YamahaReceiverHandlerFactory@15
476a0': org.eclipse.smarthome.core.thing.internal.ThingImpl cannot be cast to org.eclipse.smarthome.core.thing.Bridge
java.lang.ClassCastException: org.eclipse.smarthome.core.thing.internal.ThingImpl cannot be cast to org.eclipse.smarthome.core.thing.Bridge
at org.openhab.binding.yamahareceiver.internal.YamahaReceiverHandlerFactory.createHandler(YamahaReceiverHandlerFactory.java:63)
at org.eclipse.smarthome.core.thing.binding.BaseThingHandlerFactory.registerHandler(BaseThingHandlerFactory.java:98)
at org.eclipse.smarthome.core.thing.internal.ThingManager.doRegisterHandler(ThingManager.java:606)
at org.eclipse.smarthome.core.thing.internal.ThingManager.registerHandler(ThingManager.java:583)
at org.eclipse.smarthome.core.thing.internal.ThingManager.registerAndInitializeHandler(ThingManager.java:1035)
Should be included if the build is not older than 7 days. Unfortunately the interface changed so you need to remove your Yamaha things and readd the new ones. If it is configured via text files, you need to declare a bridge and a main zone thing.
I added the new things via paper ui and then changed my items-file to use the new channels that were created, hence no need for a things-file, works like a charm
I tried doing as you instructed, but still am getting the following error, and my receiver is not auto discovered (also using #1008 build):
2017-08-14 19:13:42.024 [ERROR] [ome.core.thing.internal.ThingManager] - Exception occurred while calling thing handler factory 'org.openhab.binding.yamahareceiver.internal.YamahaReceiverHandlerFactory@2ed21241': org.eclipse.smarthome.core.thing.internal.ThingImpl cannot be cast to org.eclipse.smarthome.core.thing.Bridge
at org.openhab.binding.yamahareceiver.internal.YamahaReceiverHandlerFactory.createHandler(YamahaReceiverHandlerFactory.java:63)[185:org.openhab.binding.yamahareceiver:2.2.0.201708091334]
at org.eclipse.smarthome.core.thing.binding.BaseThingHandlerFactory.registerHandler(BaseThingHandlerFactory.java:98)[104:org.eclipse.smarthome.core.thing:0.9.0.201708041325]
at org.eclipse.smarthome.core.thing.internal.ThingManager.doRegisterHandler(ThingManager.java:606)[104:org.eclipse.smarthome.core.thing:0.9.0.201708041325]
at org.eclipse.smarthome.core.thing.internal.ThingManager.registerHandler(ThingManager.java:583)[104:org.eclipse.smarthome.core.thing:0.9.0.201708041325]
at org.eclipse.smarthome.core.thing.internal.ThingManager.registerAndInitializeHandler(ThingManager.java:1035)[104:org.eclipse.smarthome.core.thing:0.9.0.201708041325]
at org.eclipse.smarthome.core.thing.internal.ThingManager.thingAdded(ThingManager.java:464)[104:org.eclipse.smarthome.core.thing:0.9.0.201708041325]
at org.eclipse.smarthome.core.thing.internal.ThingRegistryImpl.notifyTrackers(ThingRegistryImpl.java:200)[104:org.eclipse.smarthome.core.thing:0.9.0.201708041325]
at org.eclipse.smarthome.core.thing.internal.ThingRegistryImpl.notifyListenersAboutAddedElement(ThingRegistryImpl.java:119)[104:org.eclipse.smarthome.core.thing:0.9.0.201708041325]
at org.eclipse.smarthome.core.thing.internal.ThingRegistryImpl.notifyListenersAboutAddedElement(ThingRegistryImpl.java:1)[104:org.eclipse.smarthome.core.thing:0.9.0.201708041325]
at org.eclipse.smarthome.core.common.registry.AbstractRegistry.addProvider(AbstractRegistry.java:284)[97:org.eclipse.smarthome.core:0.9.0.201708041325]
at org.eclipse.smarthome.core.common.registry.AbstractRegistry$ProviderTracker.addingService(AbstractRegistry.java:107)[97:org.eclipse.smarthome.core:0.9.0.201708041325]
at org.eclipse.smarthome.core.common.registry.AbstractRegistry$ProviderTracker.addingService(AbstractRegistry.java:1)[97:org.eclipse.smarthome.core:0.9.0.201708041325]
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:941)[org.osgi.core-6.0.0.jar:]
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:870)[org.osgi.core-6.0.0.jar:]
at org.osgi.util.tracker.AbstractTracked.trackAdding(AbstractTracked.java:256)[org.osgi.core-6.0.0.jar:]
at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:229)[org.osgi.core-6.0.0.jar:]
at org.osgi.util.tracker.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:901)[org.osgi.core-6.0.0.jar:]
at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:109)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:914)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:862)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:801)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:127)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:225)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:464)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:886)[34:org.apache.felix.scr:2.0.6]
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:873)[34:org.apache.felix.scr:2.0.6]
at org.apache.felix.scr.impl.manager.RegistrationManager.changeRegistration(RegistrationManager.java:132)[34:org.apache.felix.scr:2.0.6]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.registerService(AbstractComponentManager.java:940)[34:org.apache.felix.scr:2.0.6]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:740)[34:org.apache.felix.scr:2.0.6]
at org.apache.felix.scr.impl.manager.DependencyManager$SingleStaticCustomizer.addedService(DependencyManager.java:1012)[34:org.apache.felix.scr:2.0.6]
at org.apache.felix.scr.impl.manager.DependencyManager$SingleStaticCustomizer.addedService(DependencyManager.java:968)[34:org.apache.felix.scr:2.0.6]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1215)[34:org.apache.felix.scr:2.0.6]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1136)[34:org.apache.felix.scr:2.0.6]
at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.trackAdding(ServiceTracker.java:945)[34:org.apache.felix.scr:2.0.6]
at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.track(ServiceTracker.java:881)[34:org.apache.felix.scr:2.0.6]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:1167)[34:org.apache.felix.scr:2.0.6]
at org.apache.felix.scr.impl.BundleComponentActivator$ListenerInfo.serviceChanged(BundleComponentActivator.java:127)[34:org.apache.felix.scr:2.0.6]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enableInternal(AbstractComponentManager.java:674)[34:org.apache.felix.scr:2.0.6]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enable(AbstractComponentManager.java:429)[34:org.apache.felix.scr:2.0.6]
at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.enableComponents(ConfigurableComponentHolder.java:657)[34:org.apache.felix.scr:2.0.6]
at org.apache.felix.scr.impl.BundleComponentActivator.initialEnable(BundleComponentActivator.java:341)[34:org.apache.felix.scr:2.0.6]
at org.apache.felix.scr.impl.Activator.loadComponents(Activator.java:403)[34:org.apache.felix.scr:2.0.6]
at org.apache.felix.scr.impl.Activator.access$200(Activator.java:54)[34:org.apache.felix.scr:2.0.6]
at org.apache.felix.scr.impl.Activator$ScrExtension.start(Activator.java:278)[34:org.apache.felix.scr:2.0.6]
at org.apache.felix.utils.extender.AbstractExtender.createExtension(AbstractExtender.java:259)[34:org.apache.felix.scr:2.0.6]
at org.apache.felix.utils.extender.AbstractExtender.modifiedBundle(AbstractExtender.java:232)[34:org.apache.felix.scr:2.0.6]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:482)[org.osgi.core-6.0.0.jar:]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:415)[org.osgi.core-6.0.0.jar:]
at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:232)[org.osgi.core-6.0.0.jar:]
at org.osgi.util.tracker.BundleTracker$Tracked.bundleChanged(BundleTracker.java:444)[org.osgi.core-6.0.0.jar:]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:902)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:165)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:75)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:67)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:102)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.container.Module.publishEvent(Module.java:466)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.container.Module.start(Module.java:457)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1582)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1562)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1533)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1476)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
> 2017-08-14 19:13:42.024 [ERROR] [ome.core.thing.internal.ThingManager] - Exception occurred while calling thing handler factory 'org.openhab.binding.yamahareceiver.internal.YamahaReceiverHandlerFactory@2ed21241': org.eclipse.smarthome.core.thing.internal.ThingImpl cannot be cast to org.eclipse.smarthome.core.thing.Bridge java.lang.ClassCastException: org.eclipse.smarthome.core.thing.internal.ThingImpl cannot be cast to org.eclipse.smarthome.core.thing.Bridge at org.openhab.binding.yamahareceiver.internal.YamahaReceiverHandlerFactory.createHandler(YamahaReceiverHandlerFactory.java:63)[185:org.openhab.binding.yamahareceiver:2.2.0.201708091334] at org.eclipse.smarthome.core.thing.binding.BaseThingHandlerFactory.registerHandler(BaseThingHandlerFactory.java:98)[104:org.eclipse.smarthome.core.thing:0.9.0.201708041325] at org.eclipse.smarthome.core.thing.internal.ThingManager.doRegisterHandler(ThingManager.java:606)[104:org.eclipse.smarthome.core.thing:0.9.0.201708041325] at org.eclipse.smarthome.core.thing.internal.ThingManager.registerHandler(ThingManager.java:583)[104:org.eclipse.smarthome.core.thing:0.9.0.201708041325] at org.eclipse.smarthome.core.thing.internal.ThingManager.registerAndInitializeHandler(ThingManager.java:1035)[104:org.eclipse.smarthome.core.thing:0.9.0.201708041325] at org.eclipse.smarthome.core.thing.internal.ThingManager.thingAdded(ThingManager.java:464)[104:org.eclipse.smarthome.core.thing:0.9.0.201708041325] at org.eclipse.smarthome.core.thing.internal.ThingRegistryImpl.notifyTrackers(ThingRegistryImpl.java:200)[104:org.eclipse.smarthome.core.thing:0.9.0.201708041325] at org.eclipse.smarthome.core.thing.internal.ThingRegistryImpl.notifyListenersAboutAddedElement(ThingRegistryImpl.java:119)[104:org.eclipse.smarthome.core.thing:0.9.0.201708041325] at org.eclipse.smarthome.core.thing.internal.ThingRegistryImpl.notifyListenersAboutAddedElement(ThingRegistryImpl.java:1)[104:org.eclipse.smarthome.core.thing:0.9.0.201708041325] at org.eclipse.smarthome.core.common.registry.AbstractRegistry.addProvider(AbstractRegistry.java:284)[97:org.eclipse.smarthome.core:0.9.0.201708041325] at org.eclipse.smarthome.core.common.registry.AbstractRegistry$ProviderTracker.addingService(AbstractRegistry.java:107)[97:org.eclipse.smarthome.core:0.9.0.201708041325] at org.eclipse.smarthome.core.common.registry.AbstractRegistry$ProviderTracker.addingService(AbstractRegistry.java:1)[97:org.eclipse.smarthome.core:0.9.0.201708041325] at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:941)[org.osgi.core-6.0.0.jar:] at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:870)[org.osgi.core-6.0.0.jar:] at org.osgi.util.tracker.AbstractTracked.trackAdding(AbstractTracked.java:256)[org.osgi.core-6.0.0.jar:] at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:229)[org.osgi.core-6.0.0.jar:] at org.osgi.util.tracker.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:901)[org.osgi.core-6.0.0.jar:] at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:109)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:] at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:914)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:] at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:] at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:] at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:862)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:] at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:801)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:] at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:127)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:] at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:225)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:] at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:464)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:] at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:886)[34:org.apache.felix.scr:2.0.6] at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:873)[34:org.apache.felix.scr:2.0.6] at org.apache.felix.scr.impl.manager.RegistrationManager.changeRegistration(RegistrationManager.java:132)[34:org.apache.felix.scr:2.0.6] at org.apache.felix.scr.impl.manager.AbstractComponentManager.registerService(AbstractComponentManager.java:940)[34:org.apache.felix.scr:2.0.6] at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:740)[34:org.apache.felix.scr:2.0.6] at org.apache.felix.scr.impl.manager.DependencyManager$SingleStaticCustomizer.addedService(DependencyManager.java:1012)[34:org.apache.felix.scr:2.0.6] at org.apache.felix.scr.impl.manager.DependencyManager$SingleStaticCustomizer.addedService(DependencyManager.java:968)[34:org.apache.felix.scr:2.0.6] at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1215)[34:org.apache.felix.scr:2.0.6] at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1136)[34:org.apache.felix.scr:2.0.6] at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.trackAdding(ServiceTracker.java:945)[34:org.apache.felix.scr:2.0.6] at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.track(ServiceTracker.java:881)[34:org.apache.felix.scr:2.0.6] at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:1167)[34:org.apache.felix.scr:2.0.6] at org.apache.felix.scr.impl.BundleComponentActivator$ListenerInfo.serviceChanged(BundleComponentActivator.java:127)[34:org.apache.felix.scr:2.0.6] at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:109)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:] at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:914)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:] at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:] at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:] at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:862)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:] at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:801)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:] at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:127)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:] at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:225)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:] at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:464)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:] at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:886)[34:org.apache.felix.scr:2.0.6] at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:873)[34:org.apache.felix.scr:2.0.6] at org.apache.felix.scr.impl.manager.RegistrationManager.changeRegistration(RegistrationManager.java:132)[34:org.apache.felix.scr:2.0.6] at org.apache.felix.scr.impl.manager.AbstractComponentManager.registerService(AbstractComponentManager.java:940)[34:org.apache.felix.scr:2.0.6] at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:740)[34:org.apache.felix.scr:2.0.6] at org.apache.felix.scr.impl.manager.AbstractComponentManager.enableInternal(AbstractComponentManager.java:674)[34:org.apache.felix.scr:2.0.6] at org.apache.felix.scr.impl.manager.AbstractComponentManager.enable(AbstractComponentManager.java:429)[34:org.apache.felix.scr:2.0.6] at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.enableComponents(ConfigurableComponentHolder.java:657)[34:org.apache.felix.scr:2.0.6] at org.apache.felix.scr.impl.BundleComponentActivator.initialEnable(BundleComponentActivator.java:341)[34:org.apache.felix.scr:2.0.6] at org.apache.felix.scr.impl.Activator.loadComponents(Activator.java:403)[34:org.apache.felix.scr:2.0.6] at org.apache.felix.scr.impl.Activator.access$200(Activator.java:54)[34:org.apache.felix.scr:2.0.6] at org.apache.felix.scr.impl.Activator$ScrExtension.start(Activator.java:278)[34:org.apache.felix.scr:2.0.6] at org.apache.felix.utils.extender.AbstractExtender.createExtension(AbstractExtender.java:259)[34:org.apache.felix.scr:2.0.6] at org.apache.felix.utils.extender.AbstractExtender.modifiedBundle(AbstractExtender.java:232)[34:org.apache.felix.scr:2.0.6] at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:482)[org.osgi.core-6.0.0.jar:] at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:415)[org.osgi.core-6.0.0.jar:] at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:232)[org.osgi.core-6.0.0.jar:] at org.osgi.util.tracker.BundleTracker$Tracked.bundleChanged(BundleTracker.java:444)[org.osgi.core-6.0.0.jar:] at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:902)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:] at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:] at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:] at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:165)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:] at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:75)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:] at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:67)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:] at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:102)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:] at org.eclipse.osgi.container.Module.publishEvent(Module.java:466)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:] at org.eclipse.osgi.container.Module.start(Module.java:457)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:] at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1582)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:] at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1562)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:] at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1533)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:] at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1476)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:] at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:] at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:] at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
I am only using paperUI, no text files. To provide you with the information, I uninstalled the yamaha binding in addons and restarted OH. I also deleted logs and had no errors re the yamaha binding after restart. Then I installed binding again via paperUI, and immediately go these errors (notice that it seems like paperUI had a quick crash as well):
2017-08-15 22:19:40.959 [INFO ] [ternal.scheduler.WeatherJobScheduler] - Disabling weather locationId 'home', no binding available
2017-08-15 22:26:58.090 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Stopped Paper UI
2017-08-15 22:26:58.158 [INFO ] [basic.internal.servlet.WebAppServlet] - Stopped Basic UI
2017-08-15 22:26:59.088 [ERROR] [ome.core.thing.internal.ThingManager] - Exception occurred while calling thing handler factory 'org.openhab.binding.yamahareceiver.internal.YamahaReceiverHandlerFactory@707f51c7': org.eclipse.smarthome.core.thing.internal.ThingImpl cannot be cast to org.eclipse.smarthome.core.thing.Bridge
at org.eclipse.smarthome.core.thing.internal.ThingManager.lambda$2(ThingManager.java:1018)
at java.util.concurrent.CopyOnWriteArrayList.forEach(CopyOnWriteArrayList.java:890)[:1.8.0_144]
at java.util.concurrent.CopyOnWriteArraySet.forEach(CopyOnWriteArraySet.java:404)[:1.8.0_144]
at org.eclipse.smarthome.core.thing.internal.ThingManager.lambda$1(ThingManager.java:1015)
at java.util.stream.ForEachOps$ForEachOp$OfRef.accept(ForEachOps.java:184)[:1.8.0_144]
at java.util.stream.ReferencePipeline$2$1.accept(ReferencePipeline.java:175)[:1.8.0_144]
at java.util.Spliterators$ArraySpliterator.forEachRemaining(Spliterators.java:948)[:1.8.0_144]
at java.util.stream.AbstractPipeline.copyInto(AbstractPipeline.java:481)[:1.8.0_144]
at java.util.stream.AbstractPipeline.wrapAndCopyInto(AbstractPipeline.java:471)[:1.8.0_144]
at java.util.stream.ForEachOps$ForEachOp.evaluateSequential(ForEachOps.java:151)[:1.8.0_144]
at java.util.stream.ForEachOps$ForEachOp$OfRef.evaluateSequential(ForEachOps.java:174)[:1.8.0_144]
at java.util.stream.AbstractPipeline.evaluate(AbstractPipeline.java:234)[:1.8.0_144]
at java.util.stream.ReferencePipeline.forEach(ReferencePipeline.java:418)[:1.8.0_144]
at org.eclipse.smarthome.core.thing.internal.ThingManager.handleThingHandlerFactoryAddition(ThingManager.java:1014)
at org.eclipse.smarthome.core.thing.internal.ThingManager.addReadyMarker(ThingManager.java:1000)
at sun.reflect.GeneratedMethodAccessor5.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)[:1.8.0_144]
at java.lang.reflect.Method.invoke(Method.java:498)[:1.8.0_144]
at org.apache.felix.scr.impl.inject.BaseMethod.invokeMethod(BaseMethod.java:224)
at org.apache.felix.scr.impl.inject.BaseMethod.access$500(BaseMethod.java:39)
at org.apache.felix.scr.impl.inject.BaseMethod$Resolved.invoke(BaseMethod.java:617)
at org.apache.felix.scr.impl.inject.BaseMethod.invoke(BaseMethod.java:501)
at org.apache.felix.scr.impl.inject.BindMethod.invoke(BindMethod.java:655)
at org.apache.felix.scr.impl.manager.DependencyManager.doInvokeBindMethod(DependencyManager.java:1722)
at org.apache.felix.scr.impl.manager.DependencyManager.invokeBindMethod(DependencyManager.java:1699)
at org.apache.felix.scr.impl.manager.SingleComponentManager.invokeBindMethod(SingleComponentManager.java:371)
at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.addedService(DependencyManager.java:320)
at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.addedService(DependencyManager.java:291)
at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:482)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.smarthome.core.service.ReadyUtil.markAsReady(ReadyUtil.java:40)[97:org.eclipse.smarthome.core:0.9.0.201708041325]
at org.eclipse.smarthome.config.xml.osgi.XmlDocumentBundleTracker.registerReadyMarker(XmlDocumentBundleTracker.java:348)[96:org.eclipse.smarthome.config.xml:0.9.0.201708041325]
at org.eclipse.smarthome.config.xml.osgi.XmlDocumentBundleTracker.finishBundle(XmlDocumentBundleTracker.java:300)[96:org.eclipse.smarthome.config.xml:0.9.0.201708041325]
at org.eclipse.smarthome.config.xml.osgi.XmlDocumentBundleTracker.processBundle(XmlDocumentBundleTracker.java:321)[96:org.eclipse.smarthome.config.xml:0.9.0.201708041325]
at org.eclipse.smarthome.config.xml.osgi.XmlDocumentBundleTracker.lambda$0(XmlDocumentBundleTracker.java:292)[96:org.eclipse.smarthome.config.xml:0.9.0.201708041325]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)[:1.8.0_144]
at java.util.concurrent.FutureTask.run(FutureTask.java:266)[:1.8.0_144]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180)[:1.8.0_144]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293)[:1.8.0_144]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)[:1.8.0_144]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)[:1.8.0_144]
at java.lang.Thread.run(Thread.java:748)[:1.8.0_144]
2017-08-15 22:26:59.169 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
There might be a bug. Would you volunteer and use a more recent version? If so, please uninstall the yamaha binding and drop the following jar to your OH/addons directory:
Oh, one question, how new is your receiver? What is the year of build? The binding supports only AVRs up to about 2014. Yamaha changed the protocol for newer receivers, could that be the case here?
It’s a V679 which was released in 2015 AFAIK. In OH 2.0.0 the binding was still working, I could turn it on and off and get updates when that happened. Not sure what else was working though. Never had any errors in openhab,log, I am sure about that.
Ah it’s a RX-V model. That should work, yes. The discovery process is the same like in OH2.0, so you should at least see your AVR.
If that never worked for you, Yamaha might have changed the way, their devices announces themselves on the network. I developed the binding for UPnP capable Yamaha receivers, you already have a MusicCast capable device.
As said, everything worked fine in 2.0.0 (including discovery of all functions) and broke with 2.2.0. In other words, it’s not a compatibility problem, but rather a regression issue (or possible problem with my setup).
I just did a quick check, will need to spend more time on this tomorrow. But for now I can say that the port was 49154 instead of 80. I quickly changed this and now I could at least power the receiver on/off. I will need to swap out the jar you provided and run through discovery again, will do that tomorrow. I have a feeling that we are definitely on the right track here. Many thanks so far
Ok, I have tried your new jar. Same problem, binding adds receiver with wrong port (49154 instead of 80), so discovery doesn’t work. Do I have to delete cache or something first (don’t want to screw up my setup though)?
@automatic I checked how it works on my installation OH2.2-SNAPSHOT:
Deleted all yamaha things (RX-S601D Main_Zone & Yamaha Receiver RX-S601D)
Ran discovery again:
First added the Yamaha Receiver RX-S601D
Secondly added RX-S601D Main_Zone
As a result the Yamaha Receiver RX-S601D thing is assigned port 80. Everything works fine.
I am not familiar with the discovery process and specifically with any caching involved, but examining the code we may need to force port 80 upon discovery. For instance if the root cause is caching then on my env the port 80 is being cached, while on your environment it might cache 49154.
That said, once you assign port 80 (in the way I described earlier) do you still have any issues?
Also, what do you mean by ? Can you be more specific please?
The new binding allows you to configure the port separately, it’s not part of the host configuration anymore. The discovery will not fill out the port configuration parameter (because it reports a wrong port, as you have already experienced).
Therefore the discovery cannot be the culprit here. It is probably because you didn’t remove the Yamaha thing before swapping the jars. You need to manually remove the wrong port information (and port 80, the default will be used) from your Yamaha bridge thing and everything should work.
