Hello community!
Setup:
jdk1.8.0_201
openhab 2.4.0 (Windows 10)
Problem:
Currently I’m working on a binding for Studer inverters. I took the Fronius binding as a template because I’m very new to binding development. Unfortunately I’m stuck with a problem which is, from what I have seen, pretty common but I can’t find a solution out there.
I need to cast a Thing to Bridge but it always throws a ClassCastException:
org.eclipse.smarthome.core.thing.internal.ThingImpl cannot be cast to org.eclipse.smarthome.core.thing.Bridge
Here is my bridge.xml
<?xml version="1.0" encoding="UTF-8"?> <thing:thing-descriptions bindingId="studerbinding" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:thing="http://eclipse.org/smarthome/schemas/thing-description/v1.0.0" xsi:schemaLocation="http://eclipse.org/smarthome/schemas/thing-description/v1.0.0 http://eclipse.org/smarthome/schemas/thing-description-1.0.0.xsd"> <!-- Sample Thing Type --> <bridge-type id="bridge"> <label>Studer bridge</label> <description>Bridge to connect to Studer inverters</description> <config-description> <parameter name="usr" type="text" required="true"> <label>Username</label> <description>Please enter your username here.</description> </parameter> <parameter name="pwd" type="text" required="true"> <label>Password</label> <description>Please enter your password here.</description> </parameter> <parameter name="refreshintv" type="integer" min="2"> <label>Refresh interval</label> <description>Specifies the refresh interval in seconds</description> <default>10</default> </parameter> </config-description> </bridge-type> </thing:thing-descriptions>
My thing-types.xml
<?xml version="1.0" encoding="UTF-8"?> <thing:thing-descriptions bindingId="studerbinding" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:thing="http://eclipse.org/smarthome/schemas/thing-description/v1.0.0" xsi:schemaLocation="http://eclipse.org/smarthome/schemas/thing-description/v1.0.0 http://eclipse.org/smarthome/schemas/thing-description-1.0.0.xsd"> <!-- Sample Thing Type --> <thing-type id="inverter"> <supported-bridge-type-refs> <bridge-type-ref id="bridge" /> </supported-bridge-type-refs> <label>Studer inverter</label> <description>No description.</description> <channels> <channel id="socharge" typeId="state_of_charge" /> <!-- 3007 --> <channel id="ipower" typeId="input_power" /> <!-- 3138 --> <channel id="opower" typeId="output_power" /> <!-- 3139 --> </channels> <config-description> <parameter name="deviceid" type="integer" required="true"> <label>Device ID</label> <description>Unique Device ID</description> </parameter> </config-description> </thing-type> <!-- Sample Channel Type --> <channel-type id="state_of_charge"> <item-type>Number</item-type> <label>State of Charge</label> <description>Actual state of charge of the batteries in percent.</description> <state pattern="%f" readOnly="true"></state> </channel-type> <channel-type id="input_power"> <item-type>Number</item-type> <label>Input power</label> <description>Input power in kVA</description> <state pattern="%f kVA" readOnly="true"></state> </channel-type> <channel-type id="output_power"> <item-type>Number</item-type> <label>Output Power</label> <description>Output power in kVA</description> <state pattern="%f kVA" readOnly="true"></state> </channel-type> </thing:thing-descriptions>
And HandlerFactory where it throws the exception:
/** * Copyright (c) 2014,2019 by the respective copyright holders. * * See the NOTICE file(s) distributed with this work for additional * information regarding copyright ownership. * * This program and the accompanying materials are made available under the * terms of the Eclipse Public License 2.0 which is available at * http://www.eclipse.org/legal/epl-2.0 * * SPDX-License-Identifier: EPL-2.0 */ package org.openhab.binding.studerbinding.internal; import static org.openhab.binding.studerbinding.internal.StuderBindingConstants.*; import java.util.HashSet; import java.util.Set; import org.eclipse.jdt.annotation.NonNullByDefault; import org.eclipse.jdt.annotation.Nullable; import org.eclipse.smarthome.core.thing.Bridge; import org.eclipse.smarthome.core.thing.Thing; import org.eclipse.smarthome.core.thing.ThingTypeUID; import org.eclipse.smarthome.core.thing.binding.BaseThingHandlerFactory; import org.eclipse.smarthome.core.thing.binding.ThingHandler; import org.eclipse.smarthome.core.thing.binding.ThingHandlerFactory; import org.openhab.binding.studerbinding.internal.handler.StuderBridgeHandler; import org.openhab.binding.studerbinding.internal.handler.StuderInverterHandler; import org.osgi.service.component.annotations.Component; /** * The {@link StuderHandlerFactory} is responsible for creating things and thing * handlers. * * @author Markus Kern - Initial contribution */ @NonNullByDefault @Component(configurationPid = "binding.studerbinding", service = ThingHandlerFactory.class) public class StuderHandlerFactory extends BaseThingHandlerFactory { private static final Set<ThingTypeUID> SUPPORTED_THING_TYPES_UIDS = new HashSet<ThingTypeUID>() { private static final long serialVersionUID = 1L; { add(THING_TYPE_INVERTER); add(THING_TYPE_BRIDGE); } }; @Override public boolean supportsThingType(ThingTypeUID thingTypeUID) { return SUPPORTED_THING_TYPES_UIDS.contains(thingTypeUID); } @Override protected @Nullable ThingHandler createHandler(Thing thing) { ThingTypeUID thingTypeUID = thing.getThingTypeUID(); if (thingTypeUID.equals(THING_TYPE_INVERTER)) { return new StuderInverterHandler(thing); } else if (thingTypeUID.equals(THING_TYPE_BRIDGE)) { return new StuderBridgeHandler((Bridge) thing); } return null; } }
Let me know if you need more information.
I hope someone can help me.
Greetings,
m4k3r
