Running new Openhabian install of openHAB 2.5.1-2 on a Raspberry Pi 2 (buster).
I still like to use the Classic UI occasionally from a couple of my desktops but it has quit working. When I try to launch it I get:
Problem accessing /classicui/app. Reason:
Server Error
Caused by:
javax.servlet.ServletException: javax.servlet.ServletException: Sitemap 'hsh.sitemap' could not be found
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:88)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:127)
at org.eclipse.jetty.server.Server.handle(Server.java:494)
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:374)
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:268)
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311)
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:103)
at org.eclipse.jetty.io.ChannelEndPoint$2.run(ChannelEndPoint.java:117)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:336)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:313)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:171)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:129)
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:367)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:782)
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:918)
at java.lang.Thread.run(Thread.java:748)
Caused by: javax.servlet.ServletException: Sitemap 'hsh.sitemap' could not be found
at org.openhab.ui.classic.internal.servlet.WebAppServlet.service(WebAppServlet.java:204)
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:852)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:544)
at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143)
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:536)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:235)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1581)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:233)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1307)
at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:293)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:188)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:482)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1549)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:186)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1204)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80)
... 15 more
Caused by: org.openhab.ui.classic.internal.render.RenderException: Sitemap 'hsh.sitemap' could not be found
at org.openhab.ui.classic.internal.servlet.WebAppServlet.service(WebAppServlet.java:165)
... 33 more
But if I check the openhab.log file when openHAB is started I get:
2020-01-21 17:29:46.631 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'hsh.sitemap'
2020-01-21 17:29:47.034 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'influxdb.persist'
2020-01-21 17:29:47.382 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'hsh.items'
2020-01-21 17:30:07.665 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Location set to.......
And my iPhone UI looks fine so the sitemap is OK. Why can’t Classic UI find it?
I checked the Classic UI service configuration in Paper UI and hsh.sitemap is shown as the default sitemap.
Any help appreciated.
