- Platform information:
- Hardware: Raspberry Ppi 3 B+
- OS: Raspbian GNU/Linux 10 (buster) - K: Linux 5.10.11-v7+
- Java Runtime Environment: build 11.0.10+9-LTS
- openHAB version: 3.0.1-2
Days ago, I began to notice that if I restarted the RPi, openhab sometimes did not start, when I executed the command sudo systemctl restart openhab
I got this:
Warning: The unit file, source configuration file or drop-ins of openhab.service changed on disk. Run 'systemctl daemon-reload' to reload units.
After running openhab started with the same message…
I was investigating a little more with journalctl -u openhab.service -b
feb 18 09:58:34 openhabian systemd[1]: Started openHAB instance, reachable at http://openhabian:8080.
feb 18 09:58:35 openhabian systemd[1]: Stopping openHAB instance, reachable at http://openhabian:8080...
feb 18 09:58:45 openhabian karaf[662]: Can't connect to the container. The container is not running.
feb 18 09:58:45 openhabian systemd[1]: openhab.service: Control process exited, code=exited, status=1/FAILURE
feb 18 09:58:45 openhabian systemd[1]: openhab.service: Failed with result 'exit-code'.
feb 18 09:58:45 openhabian systemd[1]: Stopped openHAB instance, reachable at http://openhabian:8080.
feb 18 10:42:09 openhabian karaf[1353]: WARNING: An illegal reflective access operation has occurred
feb 18 10:42:09 openhabian karaf[1353]: WARNING: Illegal reflective access by com.google.gson.internal.bind.ReflectiveTypeAdapterFactory (file:/var/lib/openhab/cach
feb 18 10:42:09 openhabian karaf[1353]: WARNING: Please consider reporting this to the maintainers of com.google.gson.internal.bind.ReflectiveTypeAdapterFactory
feb 18 10:42:09 openhabian karaf[1353]: WARNING: Use --illegal-access=warn to enable warnings of further illegal reflective access operations
feb 18 10:42:09 openhabian karaf[1353]: WARNING: All illegal access operations will be denied in a future release
feb 18 15:27:18 openhabian systemd[1]: Stopping openHAB instance, reachable at http://openhabian:8080...
feb 18 15:27:31 openhabian systemd[1]: openhab.service: Succeeded.
feb 18 15:27:31 openhabian systemd[1]: Stopped openHAB instance, reachable at http://openhabian:8080.
feb 18 15:27:31 openhabian systemd[1]: Started openHAB instance, reachable at http://openhabian:8080.
feb 18 15:33:03 openhabian systemd[1]: Stopping openHAB instance, reachable at http://openhabian:8080...
feb 18 15:33:10 openhabian karaf[9486]: org.osgi.framework.BundleException: Unable to acquire the state change lock for the module: osgi.identity; type="osgi.bundle
feb 18 15:33:10 openhabian karaf[9486]: at org.eclipse.osgi.container.Module.lockStateChange(Module.java:337)
feb 18 15:33:10 openhabian karaf[9486]: at org.eclipse.osgi.internal.framework.EquinoxBundle$SystemBundle$EquinoxSystemModule.asyncStop(EquinoxBundle.java:1
feb 18 15:33:10 openhabian karaf[9486]: at org.eclipse.osgi.internal.framework.EquinoxBundle$SystemBundle.stop(EquinoxBundle.java:262)
feb 18 15:33:10 openhabian karaf[9486]: at org.eclipse.osgi.internal.framework.EquinoxBundle$SystemBundle.stop(EquinoxBundle.java:267)
feb 18 15:33:10 openhabian karaf[9486]: at org.eclipse.osgi.launch.Equinox.stop(Equinox.java:123)
feb 18 15:33:10 openhabian karaf[9486]: at org.apache.karaf.main.Main$2.run(Main.java:354)
feb 18 15:33:10 openhabian karaf[9486]: Caused by: java.util.concurrent.TimeoutException: Timeout after waiting 5 seconds to acquire the lock.
feb 18 15:33:10 openhabian karaf[9486]: at org.eclipse.osgi.container.Module.lockStateChange(Module.java:334)
feb 18 15:33:10 openhabian karaf[9486]: ... 5 more
feb 18 15:33:16 openhabian systemd[1]: openhab.service: Succeeded.
feb 18 15:33:16 openhabian systemd[1]: Stopped openHAB instance, reachable at http://openhabian:8080.
feb 18 15:33:16 openhabian systemd[1]: Started openHAB instance, reachable at http://openhabian:8080.
feb 18 15:41:43 openhabian karaf[10016]: WARNING: An illegal reflective access operation has occurred
feb 18 15:41:43 openhabian karaf[10016]: WARNING: Illegal reflective access by com.google.gson.internal.bind.ReflectiveTypeAdapterFactory (file:/var/lib/openhab/cac
feb 18 15:41:43 openhabian karaf[10016]: WARNING: Please consider reporting this to the maintainers of com.google.gson.internal.bind.ReflectiveTypeAdapterFactory
feb 18 15:41:43 openhabian karaf[10016]: WARNING: Use --illegal-access=warn to enable warnings of further illegal reflective access operations
feb 18 15:41:43 openhabian karaf[10016]: WARNING: All illegal access operations will be denied in a future release
After sudo shutdown -r now
● openhab.service - openHAB instance, reachable at http://openhabian:8080
Loaded: loaded (/lib/systemd/system/openhab.service; enabled; vendor preset: enabled)
Drop-In: /etc/systemd/system/openhab.service.d
└─override.conf
Active: failed (Result: exit-code) since Thu 2021-02-18 15:57:12 -03; 9min ago
Docs: https://www.openhab.org/docs/
https://community.openhab.org
Process: 528 ExecStart=/usr/share/openhab/runtime/bin/karaf ${OPENHAB_STARTMODE} (code=exited, status=143)
Process: 585 ExecStop=/usr/share/openhab/runtime/bin/karaf stop (code=exited, status=1/FAILURE)
Main PID: 528 (code=exited, status=143)
feb 18 15:57:02 openhabian systemd[1]: Started openHAB instance, reachable at http://openhabian:8080.
feb 18 15:57:02 openhabian systemd[1]: Stopping openHAB instance, reachable at http://openhabian:8080...
feb 18 15:57:12 openhabian karaf[585]: Can't connect to the container. The container is not running.
feb 18 15:57:12 openhabian systemd[1]: openhab.service: Control process exited, code=exited, status=1/FAILURE
feb 18 15:57:12 openhabian systemd[1]: openhab.service: Failed with result 'exit-code'.
feb 18 15:57:12 openhabian systemd[1]: Stopped openHAB instance, reachable at http://openhabian:8080
I really don’t know what might be causing this (I thought it was spotify binding so I disabled it but the problem persists).
I find it important to note that it was a clean installation of oh3.
Any ideas? Thanks!
