Cleaning specific room and zones with multi level map (roborock)
I finally got my vacuum (roborock) to accept the command to clean a specific room in a multi level environment.
Doing so, I had two problems:
  • I can only send the command to clean room 16, room 17 … As every floor has its own map starting with room 16, it is impossible to distinguish between “room 16” in ground floor and “room 16” in second floor
  • The binding do not tell which map it is using.
So in order to get this working you have to determine:
  1. on which floor is the vacuum
  2. on which floor is the “to be cleaned” room
  3. what is the correct room number
Task 1 is done using the method from here … so please check there in order to understand this part. Thanks to @tommycw10.
With the information from there you have to create a map file (in my case Rocky_Etage.map) with the information which ID of room 16 corresponds to which floor:
838001020681=EG
838001020689=UG
I named the different floors with two letters as e.g.
  • EG is ground floor (german: Erdgeschoss)
  • UG is cellar (german: Untergeschoss)
Additionally you have to find the room numbers for you room by try and error. Send a command over OpenHAB to clean a room and check in the App of the vacuum (not OpenHAB) which room is scheduled for cleaning.
With this information you have to fill the map-file. It will look like this:
838001020681=EG
838001020689=UG
EG_BU=19
EG_ES=21
EG_KU=18
The rooms also have two letter names as e.g.
  • BU is office (Büro)
  • ES is dining room (Esszimmer)
  • KU is kitchen (Küche)
Now you need to have
  • a switch for each room you want to clean
  • one group with all these switches
  • a string for the level where the vacuum really is
  • one proxy
Group:Switch:OR(ON,OFF)		   gSaugSwitches		"Group with one switch for each room"
Switch	RockyEtagensuche
String  Rocky_Etage "The current level"
Switch	HH_UG_GZ_Room1  (gSaugSwitches)
Switch	HH_UG_KE_Room2  (gSaugSwitches)
The switches have to be named as above:
  • HH is the name of the building (example)
  • UG is the name of the level (example)
  • GZ and KE are names for the rooms (examples)
  • everything after the third “_” is up to you
The rules are:
// this is to en- or disable  debugging of a specific set of rules.
val logName = "Rocky" // Name of the set of rules
var loggingInfo = true // if loggingInfo =true , this set of rules can be debugged without getting debug-messages from every rule.
var Timer Pause_Timer = null // the vacuum is sometimes slow and need a rest before getting new commands
rule "Vacuum should go to work"
	Member of gSaugSwitches  received command ON
	// For debugging: Set the name of this rule
	val ruleLogName = "Vacuum should go to work (" + triggeringItemName + ") "
	// This is how a debuglog looks like.... I also use this for documentation of the code
	if (loggingInfo == true ) logInfo(logName, ruleLogName )
	// This rule starts if one switch in the group receives the command to clean a specific room
	// If the current floor is know, the rule will skip a lot of steps
	if ( Rocky_State.state == "Charging"  ) {
		if (loggingInfo == true ) logInfo(logName, ruleLogName + "Vacuum in Dock => Level is known")
		Rocky_Etage.postUpdate("EG")
		return
	// Proxy to tell OpenHAB to check the current level. No Command (only update), as a command would directly trigger next rule. Using update, the next rule will be triggered after a map-update
	RockyEtagensuche.postUpdate(ON)
	// Start vacuum. The vacuum will automatically start positioning.
	// After positioning (or at least after starting cleaning) this will automatically result in a new map which will trigger next rule
	Rocky_VacuumOnOff.sendCommand(ON)
rule "A new map is available"
	Item Rocky_CleaningMap changed or // everytime the map changes (which is often)
	Item RockyEtagensuche received command ON // If want to know where the vacuum is.
	val ruleLogName = "A new map is available (" + triggeringItemName + ") "
	// A new map is available. I the floor has to be determined, we need the room_mapping.
	// The rule will ask for a room_mapping and another rule will wait for the result
	if  (RockyEtagensuche.state == ON ) {
		if (loggingInfo == true ) logInfo(logName, ruleLogName + "New Map and openhab should check for Level - I get the Floorplan")
		Rocky_ExecuteCommand.sendCommand("get_room_mapping")
		// The level-check should only be done once
		RockyEtagensuche.postUpdate(OFF)
rule "When room_mapping is available"
	Item Rocky_ExecuteCommand changed from get_room_mapping
	val ruleLogName = "room_mapping is available: "
	if (loggingInfo == true ) logInfo(logName, ruleLogName + "Triggered. The room_mapping is " + newState.toString)
	var String firstRoom = transform("JSONPATH", "$.result[0][0]", newState.toString)
	if (loggingInfo == true ) logInfo(logName, ruleLogName + "First room on room_mapping is " + firstRoom)
	// first room should be 16
	if (firstRoom == "16"){
		if (loggingInfo == true ) logInfo(logName, ruleLogName + "Check the ID of Room 16 (unique for each floor) and use map in order to find floor")
		var Etage = transform("MAP", "Rocky_Etage.map", transform("JSONPATH", "$.result[0][1]",newState.toString))
		Rocky_Etage.postUpdate(Etage)
	} else {
		Rocky_Etage.postUpdate("UNDEF")
rule "Go to your room"
	Item Rocky_Etage received update
	// We know the current floor - now we check if the room in in this floor and then go to this room
	val ruleLogName = "Go to your room "
	if (loggingInfo == true ) logInfo(logName, ruleLogName + "Triggered")
	// If there is a command to clean a room
	if (gSaugSwitches.state == ON) {
		// stop cleaning for new instructions
		Rocky_ControlVacuum.sendCommand("pause")
		if (loggingInfo == true ) logInfo(logName, ruleLogName + "Check which switch was used latest")
		val WelcherSaugSwitch = gSaugSwitches.members.filter[i|i.state==ON].sortBy[lastUpdate].last
		if (loggingInfo == true ) logInfo(logName, ruleLogName + "found: " + WelcherSaugSwitch.name)
		// get level and room from name of the switch
		val String SollEtage = WelcherSaugSwitch.name.toString.split('_').get(1)
		val String SollRaum = WelcherSaugSwitch.name.toString.split('_').get(2)
		if (loggingInfo == true ) logInfo(logName, ruleLogName + "Level: " + SollEtage + "; Room: " + SollRaum)
		// only do the cleaning once
		WelcherSaugSwitch.postUpdate(OFF)
		//if vacuum is in correct level
		if ( SollEtage != Rocky_Etage.state.toString ) {
			if (loggingInfo == true ) logInfo(logName, ruleLogName + "Falsche Etage. Ist= " + Rocky_Etage.state + ", Soll: " + SollEtage )
			Rocky_VacuumOnOff.sendCommand(OFF)
			return
		// get room ID from MAP
		val RaumNummer =  transform("MAP", "Rocky_Etage.map", SollEtage + "_" + SollRaum)
		Pause_Timer = createTimer( now.plusSeconds(3) ,[|
			if (loggingInfo == true ) logInfo(logName, ruleLogName + "Go to your room " + RaumNummer)
			Rocky_VacuumRoom.sendCommand(RaumNummer)
	} else {
		if (loggingInfo == true ) logInfo(logName, ruleLogName + "Vacuum - your fine... go on")
Thanks to everybody on this community. I learned everything here but I am not able to say where exactly.
Best regards
Peter
Updated the rules with more documentation
Hi PeterK,
first: Many thanks for the tutorial. I’ve replicated/adopted to my setup and it worked immediatly. Not yet tried with the second floor level - but the local floor is already working fine!
I’m sure, you are aware of the multi-room option already. If not, I’d like to add it here - just in case :wink:
(and for reference…)
I’ve simply put multiple rooms in my MAP-file for a single vacuum switch switch e.g. <...>_EG_Fliesen (notice the last two lines):
123456722020=OG
123456721998=EG
EG_Eingang=17
EG_Kueche=16
EG_WoZi=19
EG_BiBo=18
EG_Fliesen=16,17
EG_All=16,17,18,19
This concatenates multiple rooms in the ground floor.
Obvious intention is starting a combined cleaning of connected rooms, e.g. mopping the whole tiled floor in the kitchen and the entrance, while leaving out the wooden floor in the living rooms…
Hi PeterK,
I think I’ve spotted a little flaw in “A new map is available” rule…
I had some occasions, where the map changed to UNDEF after starting the vaccum. If we do a get_room_mapping in that case, we get an empty room list which let the room mapping fail.
Therefore I added a second condition && Rocky_CleaningMap != UNDEF before asking for the mapping:
	if  (RockyEtagensuche.state == ON && Rocky_CleaningMap != UNDEF ) {
Seems, that this solved it… :wink:
EDIT: I found another situation which was not yet covered and lead to unwanted results. I made some more modifications on your rules. I’m going to share those here, once I have tested them more …
I will later try both inputs. They are very interesting.
I already programmed the rules to do also zones as e.g. “under the table” or “where the small one eats cookies because she thinks I don’t know.”.
I did not have the time to do documentation, but as soon as I am ready, I will post the new rules and also put your suggestions in it
BR
Peter
I’ve sent you a PM with my latest rule code. Meanwhile it’s tested even with trying to trigger some corner cases:
  • loading the wrong map through the app
  • closed doors
  • starting from dock with wrong map selected
The UNDEF-map is now handled properly I think. For now, I’m quite happy with the set of rules.
Let me know, if you want to check the provided code first and probably merge with your latest additions and then updating your starting post.
Don’t want to confuse with my rules in your tutorial thread :wink:
My last post has been lost due to the forum’s upgrade issue… I will re-post asap.
The new rules do have the possibilitiy to clean segments and/or room
BR PeterK
the new rules are now able to do
  • room-cleaning,
  • multi-room cleaning,
  • zone cleaning and
  • multi-zone cleaning.
The method to find the current floor is adapted from here:
The method for the zone cleaning is from here:
In order to use the rule, you need newest binding. You can upgrade with karaf using
update org.openhab.binding.miio https://ci.openhab.org/job/openHAB-Addons/lastSuccessfulBuild/artifact/bundles/org.openhab.binding.miio/target/org.openhab.binding.miio-3.1.0-SNAPSHOT.jar
You need the map file holding the roomID of room 16 and the mapping of the single rooms as described in the first post. Additionally you can now add zones by defining:
  • meters from the dock to the starting point of the zone
  • dimension of the zone in meters.
The map file will then look like:
838001020681=EG
838001020689=UG
838001020686=E1
EG_BU=19
EG_FL=24
EG_ES=21
EG_KU=18
EG_GT=17
EG_SA=16
EG_BUFLGT=19,24,17
esstisch=-8.9,2.2,2.8,2.5,1
arbeitsflaeche=-4.2,1.3,4.2,1.3,1
grundreinigung=esstisch,arbeitsflaeche
=NULL
Example how to find the values of above zone “esstisch” using the original App:
  • draw your zone and you will see the dimensions in the App. In this case 2,8x2,5m
  • draw another zone starting from the dock just to the starting point. The app shows the values in meter of the the starting point. In this case 8,9x2,2m
This results in
as seen in the map-file. The last number is to control the number of repeats. If you want to clean twice, it is
esstisch=-8.9,2.2,2.8,2.5,2
You will need these items
Switch Rocky_VacuumOnOff  		// linked to :actions#vacuum
String Rocky_State 						// linked to :status#state
String Rocky_ExecuteCommand 				// linked to :actions#rpc
Switch Rocky_RobotLocating					// linked to :status#is_locating
Image Rocky_CleaningMap
String Vacuum_Zone "The zone to clean"
String Rocky_Saugbefehle "Please clean..."
Please check the first post for the naming convention of the switches and details how to find the different IDs.
Additionally you can now also have switches for zones as e.g. HH_EG_ZO_arbeitsflaeche in the group. The “ZO” will be recognized as Zone and the following string “arbeitsfläche” will then be used as zone.
The string Rocky_Saugbefehle is optional. The single switches are best for e.g. alexa but in a UI it is sometimes nicer to have one single item controlling all rooms and zones. In order to have this, you have to configure (in the UI) stateDescription & Command options es .e.g.
EG_KU=Küche
EG_EZ=Esszimmer
EG_FL=Eingang
EG_GT=Gästetoilette
EG_BU=Büro
SP_UT=Unterm Tisch
EG_ZO_esstisch=unterm Tisch
EG_ZO_arbeitsflaeche=Küchenzeile
You will then have a one Item with a nice drop-down in the UI. Using the drop down will trigger a rule which finds the correct switch => If you do not need the drop-down, the rules will work without it.
The rules
val Dockfloor = "EG" // Floor where the docking station is. This will assume that the correct map is loaded when vacuum is in dock. This can speed up things, but might produce error if someone chages map in app.  Set to "NO" to disable
// Function to calculate from m to values the vacuum understands
// see https://community.openhab.org/t/xiaomi-roborock-zone-cleanup-rule/55138/2?u=peterk
val Functions$Function1<String, String> getZoneCoordinates =
[zone |
  var parameters = zone.split(',')
  // Docking point start position
  val double x = 25500.0;
  val double y = 25500.0;
  // Bottom (y) left (x)
  val double b = Double::parseDouble(parameters.get(0)) * 1000.0 + x
  val double l = Double::parseDouble(parameters.get(1)) * 1000.0 + y
  // Top (y) right (x)
  val double t = b + Double::parseDouble(parameters.get(2)) * 1000.0
  val double r = l + Double::parseDouble(parameters.get(3)) * 1000.0
  // Build zone coordinates (and number of times to scan)
  val coordinates = String::format("[%.0f,%.0f,%.0f,%.0f,%s]", b, l, t, r, parameters.get(4));
  coordinates
// The rules to check for the floor each time when positioning is done
// The idea is from here https://community.openhab.org/t/xiaomi-roborock-room-clean-multi-level-map/108850/13
// when a  new map is available, the rule will request a floorplan
	Item Rocky_RobotLocating changed to OFF or // vacuum stops searchin
	Item Rocky_CleaningMap changed from UNDEF // if Rocky_RobotLocating is buggy
		if (loggingInfo == true ) logInfo(logName, ruleLogName + "Drumroll... we present you the new floor: " + Etage)
		Rocky_Etage.sendCommand(Etage)
	} else {
		// If the check is not succesfull, the floor will be set to UNDEF
		Rocky_Etage.sendCommand("UNDEF")
// The rules to control the vacuum
	// Check if floor is already known
	if (( Rocky_State.state == "Charging"  )  && (  Rocky_Etage.state == Dockfloor ) && (  Dockfloor != "NO" ) ) {
		// If the current floor is know, dont wait for new map-update.This will be wrong if someone changed the map in the app and did not start cleaning (which would have updated Rocky_Etage).
		Rocky_Etage.sendCommand(Dockfloor)
	} else {
		if (loggingInfo == true ) logInfo(logName, ruleLogName + "Vacuum not in Dock => Start cleaning and positioning")
		// No Command (only update), as a command would directly trigger next rule. Using update, the next rule will be triggered after a map-update
// When the "check the floor" is done
	Item Rocky_Etage received command
		if  ( (Rocky_ControlVacuum.state != "pause" ) &&  (Rocky_ControlVacuum.state != "dock" ) ) {
		if (loggingInfo == true ) logInfo(logName, ruleLogName + "Floor: " + SollEtage + "; Room: " + SollRaum)
		//if vacuum is in correct floor. If floor is UNDEF, this will stop the vacuum and exit
			return
		if (loggingInfo == true ) logInfo(logName, ruleLogName + "Etage OK")
		// if Zonecleaning was activated go to this rule and exit
		if ( SollRaum ==  "ZO" ) {
			val String SollZone = WelcherSaugSwitch.name.toString.split('_').get(3)
			if (loggingInfo == true ) logInfo(logName, ruleLogName + "Zonenreinigung von " + SollZone)
			Vacuum_Zone.sendCommand(SollZone)
			return
		if (loggingInfo == true ) logInfo(logName, ruleLogName + "Raumreinigung")
		// OK... Roomcleaning it is
			// Finally.... send the room
	} else {
		if (loggingInfo == true ) logInfo(logName, ruleLogName + "Thank you for the information of the current floor, but I just keep cleaning")
rule "Vacuum Zone control"
  Item Vacuum_Zone received command
	// From https://community.openhab.org/t/xiaomi-roborock-zone-cleanup-rule/55138/2?u=peterk
	if (loggingInfo == true ) logInfo(logName, ruleLogName + "Vacuum command: "+ receivedCommand.toString)
	// The final command send to the vacuum
	var String command = ""
	// Get zone coordinates
	var String zone = transform("MAP", "Rocky_Etage.map", receivedCommand.toString)
	// We still don't know if this is single or multiple zone
	try {
	  // Single zone only have numbers
	  command = getZoneCoordinates.apply(zone)
	} catch (Throwable t) {
	  // This is multi zone
	  parameters.forEach[string z|
		zone = transform("MAP", "Rocky_Etage.map.map", z)
		command = command + getZoneCoordinates.apply(zone) + ","
	  // Remove last ','
	  command = command.substring(0, command.length - 1)
	command = String::format("[%s]", command)
	if (loggingInfo == true ) logInfo(logName, ruleLogName + "Clean {} zone coordinates {}", receivedCommand.toString, command)
	Rocky_ExecuteCommand.sendCommand('app_zoned_clean' + command)
// The sinlge switches are nice if you use e.g. Alexa. In the UI, it is nicer to have one string with command options
// This rlule will get the correct switch from the string command
rule "Saugbefehl generieren aus String"
	Item Rocky_Saugbefehle received command
	val ruleLogName = "Saugbefehl generieren aus String (" + receivedCommand + ") "
	if (loggingInfo == true ) logInfo(logName, ruleLogName + "suche HH_" + receivedCommand + "*")
	val SaugbefehlItem = gSaugSwitches.members.filter[s| s.name.startsWith("HH_" + receivedCommand)].head as SwitchItem
	if (loggingInfo == true ) logInfo(logName, ruleLogName + "Item gefunden: " + SaugbefehlItem.name)
	SaugbefehlItem.sendCommand(ON)
As said earlier… my original post was lost - I hope this one covers all.
BR
PeterK
Can you share the exact response your vacuum is giving to the get_room_mapping command… or rather do you know the structure and meanining.
I understand it is a roomID and some numeric code. Can the code be translated to the coordinates to be send?
Is in the MiHome app the possibility to specify a specific floor & room? Does it show you which floor it is on?
Do you see readable room names in the mihome app? (meaning it has some command to map from room to roomID)
My vacuum does not have such functionality. Maybe that can help implementing something in the binding. I certainly can add a channel for the room mappings if that helps, so it gets refreshed with each regular refresh of the data.
On one map i send the command twice:
Item 'Rocky_ExecuteCommand' changed from get_room_mapping to {"code":0,"exe_time":2,"id":96,"otlocalts":1612988004148910,"result":[[16,"838001020681"],[17,"838001020684"],[18,"838001020664"],[19,"838001020685"],[21,"838001020717"],[24,"838001020683"]]}
Item 'Rocky_ExecuteCommand' changed from get_room_mapping to {"code":0,"exe_time":3,"id":113,"otlocalts":1612988068925085,"result":[[16,"838001020681"],[17,"838001020684"],[18,"838001020664"],[19,"838001020685"],[21,"838001020717"],[24,"838001020683"]]}
I then changed the map in the App:
Item 'Rocky_CleaningMap' changed from raw type (image/jpeg): 48897 bytes to raw type (image/jpeg): 30242 bytes
and send the command twice again:
Item 'Rocky_ExecuteCommand' changed from get_room_mapping to {"code":0,"exe_time":1,"id":131,"otlocalts":1612988183068802,"result":[[16,"838001020686"],[18,"838001020687"],[20,"838001020682"]]}
Item 'Rocky_ExecuteCommand' changed from get_room_mapping to {"code":0,"exe_time":2,"id":143,"otlocalts":1612988229385109,"result":[[16,"838001020686"],[18,"838001020687"],[20,"838001020682"]]}
For me it just looks like that every room has a unique ID and I use this to check if the floor changed. I assume that the IDs will change if I change the rooms in the map… but I most likely will never do that.
In the App I can choose the floor and I see names of the rooms (Picture will follow to you directly). I don’t know if the room names are readable or stored in the cloud.
When the robot starts cleaning, he sometimes start positioning (driving around and comparing the LIDAR-data to the stored maps) and chooses the correct map himself.
The functionality was added to a lot of older vacuums too… Perhaps you got the feature too without realizing.
Having a channel for the ID of room 16 would already be nice. Every time this ID changes, the rule to map the floor can be triggered… perhaps using a profile would be possible. In this case one would directly get the floor.
Br
PeterK
If someone has time and has a v6 type of model could you try these commands and share the responses from the vacuum
get_camera_status []
get_timer_summary []
get_timer_detail []
get_prop []
get_map []
get_map_v2 []
get_clean_record_map_v2 []
get_carpet_mode []
get_fw_features []
get_fresh_map []
get_persist_map []
get_recover_maps []
get_recover_map []
get_map_status []
get_segment_status []
get_network_info []
get_led_status []
get_customize_clean_mode []
get_multi_maps_list []
get_multi_map  []
the get_segment_status prob needs the segment id between the brackets
note: Not all of them are related to the map list, but may help the development of the robot specific features in the binding.
Item 'Rocky_ExecuteCommand' changed from get_camera_status to {"code":0,"exe_time":77,"id":14098,"otlocalts":1613064379290759,"result":[3461]}
Item 'Rocky_ExecuteCommand' changed from get_timer_summary to {"code":0,"exe_time":1,"id":14110,"otlocalts":1613064431199644,"result":[]}
get_timer_detail → Nothing
get_prop → Nothing
On "Erdgeschoss"
Item 'Rocky_ExecuteCommand' changed from get_map to {"code":0,"exe_time":2,"id":14143,"otlocalts":1613064579899600,"result":["roboroommap%2F322134263%2F10"]}
On "Keller" (tried three times)
Item 'Rocky_ExecuteCommand' changed from get_map to {"code":0,"exe_time":2,"id":545,"otlocalts":1613069178529137,"result":["roboroommap%2F322134263%2F14"]}
Item 'Rocky_ExecuteCommand' changed from get_map to {"code":0,"exe_time":2,"id":552,"otlocalts":1613069226522861,"result":["roboroommap%2F322134263%2F16"]}
Item 'Rocky_ExecuteCommand' changed from get_map to {"code":0,"exe_time":2,"id":558,"otlocalts":1613069239112651,"result":["roboroommap%2F322134263%2F0"]}
Item 'Rocky_ExecuteCommand' changed from get_map_v2 to {"code":0,"id":14149,"otlocalts":1613064614370327,"result":"unknown_method"}
get_clean_record_map_v2 → Nothing
Item 'Rocky_ExecuteCommand' changed from get_carpet_mode to {"code":0,"exe_time":3,"id":14162,"otlocalts":1613064662985121,"result":[{"current_high":500,"current_integral":450,"current_low":400,"enable":1,"stall_time":10}]}
Item 'Rocky_ExecuteCommand' changed from get_fw_features to {"code":0,"exe_time":2,"id":14169,"otlocalts":1613064686220393,"result":[111,112,113,114,115,116,117,118,119,120,121,122,123,124,125]}
Item 'Rocky_ExecuteCommand' changed from get_fresh_map to {"code":0,"exe_time":1,"id":14176,"otlocalts":1613064715584676,"result":"unknown_method"}
Item 'Rocky_ExecuteCommand' changed from get_persist_map to {"code":0,"exe_time":1,"id":14177,"otlocalts":1613064734820496,"result":"unknown_method"}
Item 'Rocky_ExecuteCommand' changed from get_recover_maps to {"code":0,"exe_time":3,"id":14183,"otlocalts":1613064753962541,"result":[[1,1611430630],[2,1611430708],[3,1611430817]]}
get_recover_map → Nothing
Item 'Rocky_ExecuteCommand' changed from get_map_status to {"code":0,"id":14191,"otlocalts":1613064794680825,"result":[1]}
Item 'Rocky_ExecuteCommand' changed from get_segment_status to {"code":0,"exe_time":2,"id":14197,"otlocalts":1613064829989360,"result":[1]}
Item 'Rocky_ExecuteCommand' changed from get_network_info to {"code":0,"exe_time":59,"id":14204,"otlocalts":1613064851128826,"result":{"bssid":"xx:xx:xx:xx:xx:xx","ip":"192.168.xxx.xx","mac":"xx:xx:xx:xx:xx:xx","rssi":-51,"ssid":"xxxx"}} (This one is censored... the real values were visible)
Item 'Rocky_ExecuteCommand' changed from get_led_status to {"code":0,"exe_time":3,"id":14211,"otlocalts":1613064880545279,"result":[1]}
Item 'Rocky_ExecuteCommand' changed from get_customize_clean_mode to {"code":0,"exe_time":1,"id":14218,"otlocalts":1613064904587312,"result":[{"fan_power":102,"segment":16,"water_box_mode":203},{"fan_power":102,"segment":17,"water_box_mode":203},{"fan_power":102,"segment":18,"water_box_mode":203},{"fan_power":101,"segment":22,"water_box_mode":201},{"fan_power":101,"segment":23,"water_box_mode":201},{"fan_power":101,"segment":20,"water_box_mode":201},{"fan_power":104,"segment":19,"water_box_mode":201},{"fan_power":104,"segment":21,"water_box_mode":203},{"fan_power":104,"segment":24,"water_box_mode":202}]}
Item 'Rocky_ExecuteCommand' changed from get_multi_maps_list to {"code":0,"exe_time":4,"id":14225,"otlocalts":1613064936112662,"result":[{"map_info":[{"add_time":1613030910,"bak_maps":[],"length":11,"mapFlag":0,"name":"Erdgeschoss"},{"add_time":1611430630,"bak_maps":[],"length":8,"mapFlag":1,"name":"1. Etage"},{"add_time":1611430708,"bak_maps":[],"length":6,"mapFlag":2,"name":"Keller"},{"add_time":1611430817,"bak_maps":[],"length":8,"mapFlag":3,"name":"2. Etage"}],"max_bak_map":0,"max_multi_map":4,"multi_map_count":4}]}
get_multi_map → Nothing
The get_multi_maps_list is interesting.
I can imagine the response of get_multi_map [1] or so with the name give some more details
Item 'Rocky_ExecuteCommand' changed from get_multi_map [1] to {"code":0,"exe_time":145,"id":1057,"otlocalts":1613071961310518,"result":["roboroommap%2F322134263%2F20"]}
This is unfortunate… I was hoping for a list of room names… but this points to a robo map instead.
A channel always presenting the ID of room 16 would already help. AFAIK a profile can be used to map this to the current floor using map-transformation.
In my case “Rocky_Etage” would be updated automatically and this would make two of the rules above obsolete.
What do you think?
Yes, of you don’t mind making a GitHub issue/request for it I’ll add a channel for it when I have a chance
Done
BTW… Thanks for your great work.
PR for this has been submitted
Thanks for sharing this list. Some commands seem to be new compared to this list (or I just didn’t find the commands in there):
https://github.com/marcelrv/XiaomiRobotVacuumProtocol
Would it be possible to share a full list of all commands you know? Is the linked list also comming from you?
I’m searching for a command to select/restore a map from a level. I have a Roborock S6. The command get_multi_maps_list works and returns:
[{'max_multi_map': 4, 'max_bak_map': 0, 'multi_map_count': 2, 'map_info': [{'mapFlag': 0, 'add_time': 1610144299, 'length': 11, 'name': 'Erdgeschoss', 'bak_maps': []}, {'mapFlag': 1, 'add_time': 1613669204, 'length': 12, 'name': 'Obergeschoss', 'bak_maps': []}]}]
Very interesting and exactly the map description I see in the Android App from Xiaomi.
With the help of your list, I found a new command through try and error, which might help to recover a dedicated map of a floor/level:
recover_multi_map []
It seems to be a valid method, but I could not figure out which parameters I have to provide. I called the commands with the mirobo tool in a Debian console (mirobo --ip 192.168.x.x --token xxxxx raw-command recover_multi_map). Responses of command:
recover_multi_map -> Error: No response from device
recover_multi_map 1 -> Error: {'code': -10005, 'message': 'Params is not an Array'}
recover_multi_map [1] -> Error: {'code': -10005, 'message': 'First element in array is not an object'}
Maybe this helps somebody to come to new ideas and we finally directly get the information which map is loaded and load the map we want.
