Cleaning up the startup process / renaming rules (windows possible)
I’ve run in some issues with the current startup process. Everything is starting at once which leads to several exceptions, errors and other problems. In my case the most annoying problem is the Homematic-Channel not found-problem.
According to my opinion, a reason is the triggering of rules during startup which leads to timing problems and other race conditions which then lead to further problems after startup.
I often read about moving or renaming the rules and copying back after startup, so the idea is not from me. But i never saw a solution which does all the stuff in the background, without manual interference, once it has been installed.
I know, this is rather a workaround than a solution and it also just works for a linux installation, but it may help some people possibly. If not, it helps me. :wink:
In the discussion some alternatives emerged. All alternatives work similar and share the same bash-script.
I hope, this helps somebody. If you have any further questions, feel free to ask.
My prefered variant
This is the most simple alternative, but just works with linux and systemd (e.g. openhabian). Thanks to @ptweety for this variant.
Simply create the file `/etc/systemd/system/openhab2.service.d/override.conf. This overrides the standard startup script where applicable.
If you are on stretch-based openhabian, you may use sudo systemctl edit openhab2.service, otherwise you have to use sudo nano /etc/systemd/system/openhab2.service.d/override.conf
[Service]
ExecStartPre=-/bin/bash -c '/usr/bin/find ${OPENHAB_CONF} -name "*.rules" -exec /usr/bin/rename.ul .rules .rules_away {} \\;'
ExecStartPre=-/bin/bash -c '/usr/bin/find ${OPENHAB_CONF} -name "*.script" -exec /usr/bin/rename.ul .script .script_away {} \\;'
ExecStartPost=/bin/sleep 240
ExecStartPost=-/bin/bash -c '/usr/bin/find ${OPENHAB_CONF} -name "*.script_away" -exec /usr/bin/rename.ul .script_away .script {} \\;'
ExecStartPost=-/bin/bash -c '/usr/bin/find ${OPENHAB_CONF} -name "*.rules_away" -exec /usr/bin/rename.ul .rules_away .rules {} \\;'
TimeoutStartSec=360
That’s it.
Common for all other alternatives
The bash script (all my bash scripts are located in /etc/openhab2/exec-scripts, if you want a different storage make sure you change all references as well):
“/etc/openhab2/exec-scripts/moverules.sh”
#!/bin/bash
ORG=$1
NEW=$2
IGNORE=moverules.rules
for f in /etc/openhab2/rules/*.${ORG};
do
    CURRENT=$(basename $f)
    if [ "$CURRENT" == "$IGNORE" ]
    	echo "ignoring $IGNORE"
    else
        OLDFILE=$f
        NEWFILE=${f%$ORG}$NEW
        mv "$OLDFILE" "$NEWFILE"
    fi
done
I also translated the bash script to windows batch.
“C:\openHAB2\conf\exec-scripts\moverules.cmd”
@echo off
SET ORG=%1
SET NEW=%2
SET IGNORE="moverules.rules"
cd C:\openHAB2\conf\rules
for %%f in (*.%ORG%) do (
    if %%f NEQ %IGNORE% (
       echo  %%f %%~nf.%NEW%
Alternative 1: Two rules, no servicefile
One rule renames the rules to *.rules at startup + 240 seconds, one rule renames the rules to *.rules_away at shutdown. This variant is able to run under Windows.
Please be aware, this is untested, i do not run openHAB on windows.
Pros: no changes to service file, no need to reapply the patch after update, able to run on Windows
Cons: rules are not named rules while the service is not running, system needs one restart after a power loss or installation
Changes:
  • a rules file which calls the bash script (/etc/openhab2/rules/moverules.rules)
The single new rules file (moverules.rules):
val Integer secondsDelay = 240
val String executeCmdBack = "/etc/openhab2/exec-scripts/moverules.sh rules_away rules"
val String executeCmdAway = "/etc/openhab2/exec-scripts/moverules.sh rules rules_away"
// exchange above for that on windows
//val String executeCmdBack = "C:\openHAB2\conf\exec-scripts\moverules.cmd@@rules_away@@rules"
//val String executeCmdAway = "C:\openHAB2\conf\exec-scripts\moverules.cmd@@rules@@rules_away"
var Timer renameTimer = null
rule "rename rules back in"
    System started
    logInfo("renameRules", "system started triggered")
    if (renameTimer === null)
        renameTimer = createTimer(now.plusSeconds(secondsDelay))
                                logInfo("renameRules", "rename rules back in")
                                executeCommandLine(executeCmdBack)
        logInfo("renameRules", "timer created")
    else
        logInfo("renameRules", "timer already existing")
rule "rename rules away"
    System shuts down
    logInfo("renameRules", "rename rules away")
    executeCommandLine(executeCmdAway)
Alternative 2: Servicefile and one rule
Pros: rules are correctly named at all times, except for startup
Cons: The patch to the service file has to be done after each update to openHAB, just works on systemd enabled linux variants
Changes:
  • an addition to the service definition (/usr/lib/systemd/system/openhab2.service)
    System started
                                val String cmd = "/etc/openhab2/exec-scripts/moverules.sh rules_away rules"
                                executeCommandLine(cmd)
    else
The addition to the service file (in openhabian this is /usr/lib/systemd/system/openhab2.service )
Just add the line:
ExecStartPre=/etc/openhab2/exec-scripts/moverules.sh rules rules_away
The complete service file
[Unit]
Description=openHAB 2 - empowering the smart home
Documentation=http://docs.openhab.org
Documentation=https://community.openhab.org
Wants=network-online.target
After=network-online.target
[Service]
Environment=OPENHAB_HOME=/usr/share/openhab2
Environment=OPENHAB_CONF=/etc/openhab2
Environment=OPENHAB_RUNTIME=/usr/share/openhab2/runtime
Environment=OPENHAB_USERDATA=/var/lib/openhab2
Environment=OPENHAB_LOGDIR=/var/log/openhab2
Environment=OPENHAB_STARTMODE=daemon
EnvironmentFile=-/etc/default/openhab2
User=openhab
Group=openhab
WorkingDirectory=/usr/share/openhab2
ExecStart=/usr/share/openhab2/runtime/bin/karaf $OPENHAB_STARTMODE
ExecStop=/usr/share/openhab2/runtime/bin/karaf stop
SuccessExitStatus=0 143
RestartSec=5
Restart=on-failure
TimeoutStopSec=120
LimitNOFILE=102642
[Install]
WantedBy=multi-user.target
Alternative 3: Servicefile, no rules
Pros: rules are correctly named at all times, except for startup, no rules involved
Just add the lines:
ExecStartPost=/etc/openhab2/exec-scripts/moverules.sh rules_away rules
[Unit]
[Service]
User=openhab
Group=openhab
RestartSec=5
Restart=on-failure
TimeoutStopSec=120
LimitNOFILE=102642
[Install]
Hi @job,
I wonder whether it’s an improvement to your solution if you just use something like this (not tested):
ExecStartPre=/usr/bin/rename.ul .rules .x $OPENHAB_CONF/rules/*.rules
ExecStartPost=/bin/sleep 1m
ExecStartPost=/usr/bin/rename.ul .x .rules $OPENHAB_CONF/rules/*.x
Hi @ptweety,
If it works, it is of course simpler (=better). Just one file needs to be changed. :wink:
But i am unsure, if the StartPosts are started sequentially or in parallel, and if the sequence is defined strictly. I have no idea.
Additionally, the delay could be a configuration parameter.
This should be tested.
Thanks!
Is there a shutdown rule tirgger available to rename it back at shutdown?
rule "rename rules at shut down"
    something like
    System stopped
I don’t think renaming at shutdown would help. The underlying issues seem to be around threads and queuing at startup; the renaming trick makes system read the files again after the startup chaos has calmed done a bit?
Works fine for me. Thanks! I, too, have been wanting to implement that for ages, have just been to lazy. Sorry :slight_smile:
Just upgraded to latest snapshot and noticed this line went missing, apparently openhab2.service gets overwritten.
So we should think of a different method of ‘anchoring’ the move script.
Added 2 variants of the process. If you used the prior version, please have in mind, that i changed the suffix for unused rules from “rulesx” to “rules_away”.
Hi @job,
I like to come back an this topic with my current solution. Now it’s also tested and at least working for me :wink:
But first let me recommend to not alter the upstream version of the openhab2.service file. Instead I would go with an override of the same. One can do this with
That will create a new file /etc/systemd/system/openhab2.service.d/override.conf with all the content you like. This file will survive also an upgrade of openhab to the next version.
To undo such a change you can also activate the original state with
sudo systemctl revert openhab2.service
The content of the file may e.g. be (according Alternative 3 from the first post):
[Service]
Next we want to
sudo systemctl daemon-reload
Now, another alternative is to go with this override to the openhab2.service
[Service]
ExecStartPre=-/bin/bash -c '/usr/bin/find ${OPENHAB_CONF} -name "*.rules" -exec /usr/bin/rename.ul .rules .x {} \\;'
ExecStartPost=-/bin/sleep 90
ExecStartPost=-/bin/bash -c '/usr/bin/find ${OPENHAB_CONF} -name "*.x" -exec /usr/bin/rename.ul .x .rules {} \\;'
TimeoutStartSec=180
Well, TimeoutStartSec is optional, but I found it useful to prevent the openhab2.service to go into failed-state due to long startup times. I’ve set this value to the duration of the sleep (90 seconds) plus another 90 seconds.
:+1:
Nice, @ptweety.
That’s a great approach. Your approach will replace Alternative 2+3, if you don’t mind.
No rules, no shell schript, just a small override to the service configuration. Great!
Thanks.
Nice approach but seems it’s not applicable everywhere. I’m running a Jessie based openHABian which I believe is the most common Linux variant to find among OH users.
[14:25:55] root@openHABianPi:/home/pi# systemctl list-unit-files openhab2.service
UNIT FILE        STATE
openhab2.service enabled
1 unit files listed.
[14:25:58] root@openHABianPi:/home/pi# systemctl edit  openhab2.service
Unknown operation 'edit'.
[14:26:08] root@openHABianPi:/home/pi#
Hi @mstormi,
with debian jessie you have an outdated version of systemd that does not support systemctl edit. But you can create the folders for your services and your own override.conf file by yourself.
sudo mkdir /etc/systemd/system/openhab2.service.d
Thanks @job this certainly makes startup much faster and more stable.
As a side it also meant I could use a new naming convention on my rule files so that I could control loading order as well. Just suffixed everything with a numeric like:
nnn-myrule.rules
Also added a little sleep (1 second for now) in between each ‘mv’ (or in my case ‘ln’) so OH has a little breather as it picks up each file. Still playing with whether it is worth it and how long to sleep but just felt it was better than dumping the whole ‘rules’ loading on it at once.
There of course is the big point how to process items files before processing the rules which is what all of this thread is about, but what’s the point in introducing a processing order inside the set of rules files?
I don’t think it’s absolutely essential but I do have certain rule files that I consider more low level than others. Maybe generic helpers like item synchronisation, MQTT messaging for group state changes (can’t get the binding to do that for me), alert and debug rules etc so I’d rather load those early on.
Also the likes of Astro rules trigger a lot events in other rules ‘on change’ so why not just ensure it is loaded early updated and then the other startup rules will initialise themselves from the latest value rather than initialise and then change seconds later.
So maybe more preference and optimisation than a requirement :slight_smile:
If anyone is looking for a solution in combination with the official docker-image, you can use a ramdisk (option in docker) and create a custom entrypoint, that copies all files to that ramdisk before the rules above renames them.
I am considering to implement your workaround (alternative 1).
Two question though.
  1. The 240 seconds timer (waiting time) is pretty system depended, I guess.
    So how to know when the system is ready for activating the rules?
  2. I have a “system started” rule to initialize some items during startup in place already.
    WIll this still work?
  1. yes, it is system dependent. Watch your log. You will see. At some time no bindings, things or services are being initialized, it’s just simple item-changes. (Be aware, all changes from NULL to anything are persistence initializing)
  2. you need to put this rule in the moverules.rule file, then it will work. Otherwise not.
Alternative 1 needs one shutdown to become functional.
Alright - thanks a lot.
This is no longer on problem using the current release of OpenHABian
