Works for me here on the Android app on a Samsung tablet.
@matt1 are you just using the clickable widget on a page? its works fine in the browser but in the android app it just shows a grey box and no snapshot.
Yes a layout page with the widget is workig for me. If may be a browser support issue, I donāt know that area and how the apps work.
I have the same issue with web frames not working in the app. Everything is ok in a browser but in the app the page inside the frame doesnāt load which s annoying as i want to run a web based keypad for my intruder alarm in this.
Existing issue:
Video not played if HTTP URL is used for video and HTTPS is used to connect to server
Videos on the local "https:// localserver:8443 do not work. If this is changed to http:// localserver:8080, it works.
Added more features to the widget in the first post and added it to the marketplace.
Hi all,
It work for me:
- component: widget:ClickableCameraImage
streamURL: http://192.168.1.50:8048/snapshots.mjpeg
showSettings: true
showAlarms: true
thumbnailURL: http://192.168.1.50:8048/ipcamera.jpg
camera: FoscamCamera
switchItem: FoscamCamera_EnableMotionAlarm
But if i use the android app on the local LAN, when I try the OH3 UI android app, I dinĀ“t get any video.
On the other hand, if I try the old Basic UI, with the same URL on the sitemap scrip, IĀ“m able to get the video:
Text label="Camaras" icon="camera"
Video url="http://192.168.1.50:8048/snapshots.mjpeg" encoding="mjpeg"
//Image icon="camera" item=FoscamCamera_ImageURL url="http://192.168.1.50:8048/ipcamera.jpg" refresh=5000
Default item=FoscamCamera_EnableMotionAlarm label="Habilitacion Alarma Deteccion Movimiento" valuecolor=[ON="red",OFF="green"]
Default item=FoscamCamera_MotionAlarm label="Deteccion Movimiento" valuecolor=[ON="red",OFF="green"]
Switch item=FoscamCamera_AutoLED label="AutoControl Infrared LED"
Switch item=FoscamCamera_LEDControls label="Habilitacion Infrared LED"
any thougths?
See the above posts which are all similar to yours, it works on my Samsung tablet with the app so it is probably a browser issue needing something updated or installed. Best to raise an issue on github against the app since it appears that web frames are also doing the same thing reported above.
@matt1
I just started with the MainUI as a means to power my wall tablets, so sorry for the very basic question:
I do only want to display camera snapshots, no videos. How can I increase the size of the snapshot image that is displayed with the widget? thanks.
Edit the widget code using the developers tools when logged in as a admin. Change the height and width settings which is just css code which you can use screen size in % or pixels as per here
Hello everybody
I wonder if anyone has already managed to enable this widget with zoneminder bindign?
I will be very happy for any hint
It should work just fine if you supply it with URLS from zoneminder. However be aware of this issue that may be causing headachesā¦
Display streams and snapshots from ipcamera binding in oh-image - Add-ons / UIs - openHAB Community
In openhab.log iām getting this warning all the time I view the widget:
[e.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: MyCam_AudioAlarm
I didnāt configure an item for the audio alarm, because the camera is outside and with wind it doesnāt have any use. How can I disable this message without adding an AudioAlarm item?
uninstall and re add the widget as I just updated it to have show and hide of both the alarms separately. If you dont have the item created, just donāt tick the show alarm box and the message in the logs now wont appear.
Modified the widget for my doorphone. The first widget is for static image or moving MJEPG image. Second widget popups screenwide and can handle HLS stream for better quality.
uid: ClickablePTZCamera
tags:
- video
props:
parameters:
- context: item
label: Camera image URL
required: true
type: TEXT
- context: item
label: Camera stream URL
required: false
type: TEXT
- context: item
label: Motion item
required: false
type: TEXT
- context: item
label: Item for the door lock
required: false
type: TEXT
- context: item
label: Item for door state
required: false
type: TEXT
timestamp: Jul 30, 2022, 12:05:43 AM
component: f7-card
style:
box-shadow: 5px 5px 10px 1px var(--f7-bars-bg-color)
color: var(--f7-text-color)
max-height: 150px
font-size: medium
font-weight: 500
noShadow: false
slots:
default:
- component: oh-image
action: popover
actionModal: widget:Video
actionModalConfig:
camerahls: =props.camerahls
motionItem: =props.motionItem
lockItem: =props.lockItem
doorItem: =props.doorItem
item: =[props.camerajpeg]
lazy: false
style:
margin: 0px
padding: 0px
height: 150px
width: 100%
z-index: -2
- component: f7-row
style:
position: absolute
top: 2px
width: 99%
z-index: 30
slots:
default:
- component: oh-icon
icon: "=(items[props.doorItem].state === 'ON') ? 'door-closed' : 'door'"
style:
color: "=(items[props.doorItem].state === 'ON') ? 'cyan' : 'red'"
z-index: 99
visible: =props.doorItem !== undefined
width: 22
- component: oh-button
action: command
actionCommand: ON
actionItem: =props.lockItem
class: card-prevent-open
iconF7: "=(items[props.lockItem].state === 'ON') ? 'lock_open' : 'lock'"
style:
margin-left: auto
margin-right: auto
color: "=(items[props.lockItem].state === 'ON') ? 'cyan' : 'var(--f7-card-header-text-color)'"
z-index: 99
visible: =props.lockItem !== undefined
iconSize: 23
icon: "=(items[props.motionItem].state === 'ON') ? 'mymotion-on' : 'mymotion-off'"
style:
z-index: 99
visible: =props.motionItem !== undefined
width: 23
uid: Video
tags:
- video
props:
parameters:
- context: item
required: false
type: TEXT
- context: item
label: Motion item
required: false
type: TEXT
- context: item
required: false
type: TEXT
- context: item
required: false
type: TEXT
parameterGroups: []
timestamp: Jul 30, 2022, 12:07:00 AM
component: f7-card
class: no-margin
style:
--f7-card-margin-horizontal: 0px
font-size: medium
font-weight: 500
height: 100%
margin: 5
noShadow: false
padding: 0
text-shadow: 1px 0px 2px var(--f7-bars-bg-color), -1px 0px 2px var(--f7-bars-bg-color), 0px 0px 2px var(--f7-bars-bg-color), 0px 0px 3px var(--f7-bars-bg-color)
width: 100%
slots:
default:
- component: oh-video-card
hideControls: false
item: =props.camerahls
startManually: false
style:
height: 90%
- component: f7-row
style:
position: absolute
top: 10px
width: 99%
z-index: 30
slots:
default:
style:
z-index: 99
width: 30
action: command
actionCommand: ON
style:
margin-left: auto
margin-right: auto
z-index: 99
iconSize: 30
style:
z-index: 99
width: 30
If your using a static image, you can get it to auto refresh with thisā¦
oh-image - Image | openHAB
Also your first widget requires the second one to be created before the first one will work. Thanks for sharing how to get HLS working.
Hope together we will come someday to an universal widget, opening all cameras possibilities.
I have to call @JustinG for some magic. Trying to get ipcamera video record history widget working and a bit tired to figure out rather simple logic, so rewind and forward buttons donāt work.
MP4 history length contains a number of yet unrecorded mp4 file like if Domofon1.mp4 is present MP4 history length will be = 2. What Iām trying is to switch played file name, to enable widget user to browse through record history.
uid: videoArchive
tags:
- videoArchive
props:
parameters:
- context: item
description: Ipcamera MP4 history length item
label: MP4 history length
required: true
type: TEXT
parameterGroups: []
timestamp: Aug 9, 2022, 1:24:35 AM
component: f7-card
class: no-margin
style:
font-size: medium
font-weight: 500
height: auto
margin: 5
noShadow: false
padding: 0
width: 100%
slots:
default:
hideControls: false
url: '= vars.rewind != NULL ? "http://192.168.2.9:8080/static/doorphone/Domofon" + vars.rewind + ".mp4" : "http://192.168.2.9:8080/static/doorphone/Domofon" + (items[props.history].state -1) + ".mp4"'
type: video/mp4
style:
height: auto
width: auto
- component: f7-row
style:
position: absolute
top: 10px
width: 99%
z-index: 30
slots:
default:
action: variable
actionVariable: rewind
actionVariableValue: '=(vars.rewind > 1 || rewind == NULL) ? (items[props.history].state - 1) : 1'
iconColor: white
iconF7: backward_end
iconSize: 30
action: variable
actionVariableValue: '=vars.rewind < (items[props.history].state -1) ? (items[props.history].state + 1) : (items[props.history].state + 1)'
iconColor: white
iconF7: forward_end
iconSize: 30
And I cannot close this widget popovered by button
iconColor: white
iconF7: clear
iconSize: 30
popoverClose: widget:Video
The widget itself disappears from the screen, but still remains somehow active and itās path is still in the address field of browser, so iām getting an error if I reload openhabās page.
And maybe itās better to use actionPhotos for history widget, but I canāt even imagine how to dynamically form inside a widget itās array of video URLs to get
actionPhotos:
- html: <video src="http://192.168.2.9:8080/static/doorphone/Domofon" + (items[props.history].state -1) + ".mp4"></video>
- html: <video src="http://192.168.2.9:8080/static/doorphone/Domofon" + (items[props.history].state -2) + ".mp4"></video>
- html: <video src="http://192.168.2.9:8080/static/doorphone/Domofon" + (items[props.history].state -3) + ".mp4"></video>
I see a few things going on here:
In the javascript-like expressions in the widget you rarely have to explicitly test if a variable is empty or undefined because both of these states are interpreted as false values and any existing state is interpreted as a true value. Just in case you ever do come across one of the situations where it is better to explicitly test if something exists, in these expressions it would be
vars.rewind === undefined
Also, instead of duplicating all the url, you can put the ternary expression right in the middle where you need the change. So this line can work better and be simplified to:
url: = "http://192.168.2.9:8080/static/doorphone/Domofon" + ((vars.rewind)?(vars.rewind):(items[props.history].state -1)) + ".mp4"
But I would take it even one step further. Because of the way or
expressions are evaluated, you can use an even more convenient shortcut for using a default value if a variable doesnāt exist. The or
expression will fully evaluate the first condition and if that condition is true it will return that value, only if the first condition is false does it both to evaluate the second condition. If the second condition is true it returns the second conditions value. That gives us:
url: = "http://192.168.2.9:8080/static/doorphone/Domofon" + (vars.rewind || items[props.history].state -1) + ".mp4"
Some of the same issue here (plus you forgot the vars
in front of the rewind
in the second condition):
But, more than that, 1) you donāt want to change the variable to the item state minus 1, you want to decrement the variable itself and 2) while it is probably best practice to test if vars.rewind
exists before checking if it is greater than one, itās not really necessary; ( vars.rewind > 1)
will still be false if vars.rewind
doesnāt exist . So formally this could look like:
actionVariableValue: =( vars.rewind && vars.rewind > 1 )?(vars.rewind - 1):1
But you could also reduce it to this:
actionVariableValue: =( vars.rewind > 1 )?(vars.rewind - 1):1
The main problem here:
appears to be that you have the same value for both the true result and the false result. This stems from the same issue as above (most of the time you want the new variable value to be based old variable value).
actionVariableValue: =( vars.rewind < (items[props.history].state -1))?(vars.rewind + 1):(items[props.history].state - 1)
The popoverClose
property comes directly from the f7 base component, not the OH features overlaid on top. This means that this property doesnāt understand OH specific things such as widget or page IDs. If you are going to use this property then you have to set the value to a css selector that uniquely identifies your popver. Most of the time I do this just by adding a non-standard class name to the widget:
component: f7-card
class:
- no-margin
- video_history_popup
Then the appropriate css selector would look like this:
popoverClose: .popover.video_history_popup
I have to agree that this is probably not feasible at the moment (wellā¦sufficiently non-trivial to probably not be worth it).
Thanks, this one: actionVariableValue: =( vars.rewind > 1 )?(vars.rewind - 1):1
is genius. And with much more clear brains today iāve seen my mistakes. Almost did it, but a rather big issue still remains - the video is not loading when i popup the widget until two switches from live to archive. And used all kind of css sizes, but still canāt fit the entire video into page - a small part in bottom is hidden and shows up only in fullscreen mode.
uid: Video
tags:
- video
props:
parameters:
- context: item
required: false
type: TEXT
- context: item
label: Motion item
required: false
type: TEXT
- context: item
required: false
type: TEXT
- context: item
required: false
type: TEXT
- context: item
required: true
type: TEXT
parameterGroups: []
timestamp: Aug 10, 2022, 2:56:17 AM
component: f7-card
class: videoPopover
key: '=(vars.rewind === undefined) ? Math.random() : Math.random() + vars.rewind'
style:
font-size: medium
font-weight: 500
height: auto
margin: 5
noShadow: false
padding: 0
width: 100%
slots:
default:
hideControls: false
style:
height: auto
width: auto
url: =items[props.camerahls].state
visible: =vars.archive != 2
hideControls: false
style:
height: auto
width: auto
url: ="http://192.168.2.9:8080/static/doorphone/Domofon" + (vars.rewind || items[props.history].state -1) + ".mp4"
visible: =vars.archive == 2
- component: f7-row
style:
position: absolute
top: 10px
width: 99%
z-index: 30
slots:
default:
action: variable
actionVariable: archive
actionVariableValue: 2
iconColor: white
iconF7: folder
iconSize: 30
visible: =(vars.archive !== 2)
action: variable
actionVariableValue: 1
iconColor: white
iconF7: videocam
iconSize: 30
visible: =(vars.archive == 2)
action: variable
actionVariableValue: =(vars.rewind != undefined)?(( vars.rewind > 1 )?(vars.rewind - 1):1):(items[props.history].state -2)
iconColor: white
iconSize: 30
style:
z-index: 99
visible: =((props.doorItem !== undefined) && (vars.archive !== 2))
width: 30
action: command
actionCommand: ON
iconSize: 30
style:
margin-left: auto
margin-right: auto
z-index: 99
visible: =((props.lockItem !== undefined) && (vars.archive !== 2))
style:
z-index: 99
visible: =((props.motionItem !== undefined) && (vars.archive !== 2))
width: 30
action: variable
actionVariableValue: =( vars.rewind < items[props.history].state - 1)?(vars.rewind + 1):(items[props.history].state - 1)
iconColor: white
iconF7: forward_end
iconSize: 30
iconColor: white
iconF7: clear
iconSize: 30
popoverClose: .videoPopover
style:
z-index: 99
tooltip: ŠŠ°ŠŗŃŃŃŃ
