See here:
So you mean to capture the MQTT message in a string item and then run a rule to extract the values?
I would be interested in what folder and file the paperui stores the settings.
in the userdata folder:
/srv/openhab2-userdata/jsondb (for openHABian)
OR
/var/lib/openhab2/jsondb
@matzR I’m using the following to “bridge” between my phone sending Owntracks data via MQTT and the new GPSTracker binding:
val String gpsLoggerUrl = 'http://127.0.0.1:8080/gpstracker/owntracks'
val String json = (Mobile_Owntracks.state as StringType).toString
sendHttpPostRequest(gpsLoggerUrl, "application/json", json)
The Mobile_Owntracks item is bound to my phone’s MQTT topic using the 2.4 binding.
yes there they are, thank you very much:grinning:
Did you found a solution?
No,
This is solvable with a JS transform
I’ve got the same error as this. I tried defining the actions above the rule and in the rule with the same result. I have my broker defined in a file and works fine receiving messages.
Bridge mqtt:broker:synology [ host="192.168.0.12",secure=false ]
Thing mqtt:topic:alarm {
Channels:
Type string : alarmstaterequest "Alarm State" [stateTopic="home/alarm/set", allowedStates="DISARM,ARM_HOME,ARM_AWAY"]
And this is my current rule:
import java.util.concurrent.locks.ReentrantLock
val ReentrantLock lock = new ReentrantLock()
val actions = getActions("mqtt", "mqtt:broker:synology")
rule "Alarm Panel Action Received"
Item alarmpanelRequest changed
lock.lock()
try {
switch(alarmpanelRequest.state.toString) {
case "DISARM": {
OhAlarmState.postUpdate("disarmed")
actions.publishMQTT("home/alarm","disarmed")
sendPushoverMessage(pushoverBuilder("Disarm").withTitle("Alarm Panel").withSound("falling"))
case "ARM_HOME": {
OhAlarmState.postUpdate("home")
sendPushoverMessage(pushoverBuilder("Arm").withTitle("Alarm Panel").withSound("falling"))
actions.publishMQTT("home/alarm","armed_home")
case "ARM_AWAY": {
OhAlarmState.postUpdate("armed")
actions.publishMQTT("home/alarm","armed_away")
} catch(Exception e) {
logError("Error", "Alarm Panel Action Received: " + e.getMessage)
} finally{
lock.unlock()
The actions.publishMQTT failes with
[ERROR] [eclipse.smarthome.model.script.Error] - Alarm Panel Action Received: Instance is not an MQTTActions class.
It works for this guy:
Why are you using a lock?
