Closed: Upgrade not possible
Dear all,
I’m currently running ‘openHAB 2.2.0 Build #1058
When I want to upgrade to the latest build usinf openhabian-config, I ge man error messages:
[20:55:54] openhabian@openhab:~$ sudo openhabian-config
[sudo] password for openhabian:
Das hat nicht funktioniert, bitte nochmal probieren.
2017-10-22_20:56:18_CEST [openHABian] Checking for root privileges... OK
2017-10-22_20:56:18_CEST [openHABian] Loading configuration file '/etc/openhabian.conf'... OK
2017-10-22_20:56:25_CEST [openHABian] Installing or switching to openHAB 2.2 SNAPSHOT (unstable)...
$ apt update
OK   http://archive.raspberrypi.org jessie InRelease
OK   http://mirrordirector.raspbian.org jessie InRelease
OK   http://archive.raspberrypi.org jessie/main armhf Packages
OK   http://mirrordirector.raspbian.org jessie/main armhf Packages
OK   http://mirrordirector.raspbian.org jessie/contrib armhf Packages
OK   http://mirrordirector.raspbian.org jessie/non-free armhf Packages
OK   http://archive.raspberrypi.org jessie/ui armhf Packages
OK   http://mirrordirector.raspbian.org jessie/rpi armhf Packages
OK   https://deb.nodesource.com jessie InRelease
Holen: 1 https://deb.nodesource.com jessie/main Sources [763 B]
Ign http://openhab.jfrog.io unstable InRelease
Ign https://dl.bintray.com jessie InRelease
Ign https://repos.influxdata.com jessie InRelease
Fehl http://openhab.jfrog.io unstable Release.gpg
  Verbindung mit openhab.jfrog.io:http nicht möglich:
Ign http://openhab.jfrog.io unstable Release
Fehl http://openhab.jfrog.io unstable/main armhf Packages
Fehl http://openhab.jfrog.io unstable/main Translation-de_DE
Fehl http://openhab.jfrog.io unstable/main Translation-de_DE.UTF-8
Fehl http://openhab.jfrog.io unstable/main Translation-en
Holen: 2 https://deb.nodesource.com jessie/main armhf Packages [976 B]
Holen: 3 https://deb.nodesource.com jessie/main Translation-de_DE [162 B]
Holen: 4 https://deb.nodesource.com jessie/main Translation-de [162 B]
Ign http://archive.raspberrypi.org jessie/main Translation-de_DE
Holen: 5 https://deb.nodesource.com jessie/main Translation-de_DE.UTF-8 [162 B]
Ign http://archive.raspberrypi.org jessie/main Translation-de_DE.UTF-8
Ign http://archive.raspberrypi.org jessie/main Translation-en
Ign http://archive.raspberrypi.org jessie/ui Translation-de_DE
Holen: 6 https://deb.nodesource.com jessie/main Translation-en [162 B]
Ign http://mirrordirector.raspbian.org jessie/contrib Translation-de_DE
Ign http://archive.raspberrypi.org jessie/ui Translation-de_DE.UTF-8
Holen: 7 https://deb.nodesource.com jessie/main Translation-de_DE [162 B]
Ign http://mirrordirector.raspbian.org jessie/contrib Translation-de_DE.UTF-8
Ign http://archive.raspberrypi.org jessie/ui Translation-en
Ign http://mirrordirector.raspbian.org jessie/contrib Translation-en
Ign http://mirrordirector.raspbian.org jessie/main Translation-de_DE
Holen: 8 https://deb.nodesource.com jessie/main Translation-de [162 B]
Ign http://mirrordirector.raspbian.org jessie/main Translation-de_DE.UTF-8
Ign http://mirrordirector.raspbian.org jessie/main Translation-en
Ign http://mirrordirector.raspbian.org jessie/non-free Translation-de_DE
Ign http://mirrordirector.raspbian.org jessie/non-free Translation-de_DE.UTF-8
Ign http://mirrordirector.raspbian.org jessie/non-free Translation-en
Ign http://mirrordirector.raspbian.org jessie/rpi Translation-de_DE
Ign http://mirrordirector.raspbian.org jessie/rpi Translation-de_DE.UTF-8
Ign http://mirrordirector.raspbian.org jessie/rpi Translation-en
Holen: 9 https://deb.nodesource.com jessie/main Translation-de_DE.UTF-8 [162 B]
Ign https://dl.bintray.com jessie Release.gpg
Ign https://repos.influxdata.com jessie Release.gpg
Holen: 10 https://deb.nodesource.com jessie/main Translation-en [162 B]
Holen: 11 https://deb.nodesource.com jessie/main Translation-de_DE [162 B]
Holen: 12 https://deb.nodesource.com jessie/main Translation-de [162 B]
Holen: 13 https://deb.nodesource.com jessie/main Translation-de_DE.UTF-8 [162 B]
Holen: 14 https://deb.nodesource.com jessie/main Translation-en [162 B]
Holen: 15 https://deb.nodesource.com jessie/main Translation-de_DE [162 B]
Holen: 16 https://deb.nodesource.com jessie/main Translation-de [162 B]
Holen: 17 https://deb.nodesource.com jessie/main Translation-de_DE.UTF-8 [162 B]
Holen: 18 https://deb.nodesource.com jessie/main Translation-en [162 B]
Holen: 19 https://deb.nodesource.com jessie/main Translation-de_DE [162 B]
Ign https://deb.nodesource.com jessie/main Translation-de_DE
Holen: 20 https://deb.nodesource.com jessie/main Translation-de [162 B]
Holen: 21 https://deb.nodesource.com jessie/main Translation-de_DE.UTF-8 [162 B]
Ign https://deb.nodesource.com jessie/main Translation-de_DE.UTF-8
Holen: 22 https://deb.nodesource.com jessie/main Translation-en [162 B]
Ign https://deb.nodesource.com jessie/main Translation-en
Ign http://repos.azulsystems.com stable InRelease
Fehl http://repos.azulsystems.com stable Release.gpg
  Verbindung mit repos.azulsystems.com:http nicht möglich: [IP: 13.32.132.117 80]
Ign http://repos.azulsystems.com stable Release
Fehl http://repos.azulsystems.com stable/main armhf Packages
Fehl http://repos.azulsystems.com stable/main Translation-de_DE
Fehl http://repos.azulsystems.com stable/main Translation-de_DE.UTF-8
Fehl http://repos.azulsystems.com stable/main Translation-en
Fehl https://repos.influxdata.com jessie/stable armhf Packages
  Failed to connect to repos.influxdata.com port 443: Keine Route zum Zielrechner
Fehl https://dl.bintray.com jessie/main armhf Packages
  Failed to connect to dl.bintray.com port 443: Keine Route zum Zielrechner
Ign https://repos.influxdata.com jessie/stable Translation-de_DE
Ign https://dl.bintray.com jessie/main Translation-de_DE
Ign https://dl.bintray.com jessie/main Translation-de_DE.UTF-8
Ign https://repos.influxdata.com jessie/stable Translation-de_DE.UTF-8
Ign https://dl.bintray.com jessie/main Translation-en
Ign https://repos.influxdata.com jessie/stable Translation-en
Es wurden 1.739 B in 1 min 35 s geholt (18 B/s).
W: Fehlschlag beim Holen von http://openhab.jfrog.io/openhab/openhab-linuxpkg/dists/unstable/Release.gpg  Verbindung mit openhab.jfrog.io:http nicht möglich:
W: Fehlschlag beim Holen von http://openhab.jfrog.io/openhab/openhab-linuxpkg/dists/unstable/main/binary-armhf/Packages  Verbindung mit openhab.jfrog.io:http nicht möglich:
W: Fehlschlag beim Holen von http://openhab.jfrog.io/openhab/openhab-linuxpkg/dists/unstable/main/i18n/Translation-de_DE  Verbindung mit openhab.jfrog.io:http nicht möglich:
W: Fehlschlag beim Holen von http://openhab.jfrog.io/openhab/openhab-linuxpkg/dists/unstable/main/i18n/Translation-de  Verbindung mit openhab.jfrog.io:http nicht möglich:
W: Fehlschlag beim Holen von http://openhab.jfrog.io/openhab/openhab-linuxpkg/dists/unstable/main/i18n/Translation-de_DE.UTF-8  Verbindung mit openhab.jfrog.io:http nicht möglich:
W: Fehlschlag beim Holen von http://openhab.jfrog.io/openhab/openhab-linuxpkg/dists/unstable/main/i18n/Translation-en  Verbindung mit openhab.jfrog.io:http nicht möglich:
W: Fehlschlag beim Holen von https://dl.bintray.com/fg2it/deb/dists/jessie/main/binary-armhf/Packages  Failed to connect to dl.bintray.com port 443: Keine Route zum Zielrechner
W: Fehlschlag beim Holen von https://repos.influxdata.com/debian/dists/jessie/stable/binary-armhf/Packages  Failed to connect to repos.influxdata.com port 443: Keine Route zum Zielrechner
W: Fehlschlag beim Holen von http://repos.azulsystems.com/debian/dists/stable/Release.gpg  Verbindung mit repos.azulsystems.com:http nicht möglich: [IP: 13.32.132.117 80]
W: Fehlschlag beim Holen von http://repos.azulsystems.com/debian/dists/stable/main/binary-armhf/Packages  Verbindung mit repos.azulsystems.com:http nicht möglich: [IP: 13.32.132.117 80]
W: Fehlschlag beim Holen von http://repos.azulsystems.com/debian/dists/stable/main/i18n/Translation-de_DE  Verbindung mit repos.azulsystems.com:http nicht möglich: [IP: 13.32.132.117 80]
W: Fehlschlag beim Holen von http://repos.azulsystems.com/debian/dists/stable/main/i18n/Translation-de  Verbindung mit repos.azulsystems.com:http nicht möglich: [IP: 13.32.132.117 80]
W: Fehlschlag beim Holen von http://repos.azulsystems.com/debian/dists/stable/main/i18n/Translation-de_DE.UTF-8  Verbindung mit repos.azulsystems.com:http nicht möglich: [IP: 13.32.132.117 80]
W: Fehlschlag beim Holen von http://repos.azulsystems.com/debian/dists/stable/main/i18n/Translation-en  Verbindung mit repos.azulsystems.com:http nicht möglich: [IP: 13.32.132.117 80]
E: Einige Indexdateien konnten nicht heruntergeladen werden. Sie wurden ignoriert oder alte an ihrer Stelle benutzt.
$ apt -y install openhab2
Paketlisten werden gelesen... Fertig
Abhängigkeitsbaum wird aufgebaut.
Statusinformationen werden eingelesen.... Fertig
Die folgenden Pakete werden aktualisiert (Upgrade):
  openhab2
1 aktualisiert, 0 neu installiert, 0 zu entfernen und 2 nicht aktualisiert.
Es müssen 62,5 MB an Archiven heruntergeladen werden.
Nach dieser Operation werden 49,2 kB Plattenplatz freigegeben.
WARNUNG: Die folgenden Pakete können nicht authentifiziert werden!
  openhab2
E: Es gab Probleme und -y wurde ohne --force-yes verwendet.
FAILED (apt)
Similar messages I get, when trying fallbvack to stable 2.1.0 release:
2017-10-22_20:58:55_CEST [openHABian] Checking for root privileges... OK
2017-10-22_20:58:56_CEST [openHABian] Loading configuration file '/etc/openhabian.conf'... OK
2017-10-22_20:59:05_CEST [openHABian] Installing or switching to openHAB 2.1.0 (stable)...
$ wget -O openhab-key.asc https://bintray.com/user/downloadSubjectPublicKey?username=openhab
--2017-10-22 20:59:06--  https://bintray.com/user/downloadSubjectPublicKey?username=openhab
Auflösen des Hostnamen »bintray.com (bintray.com)«... 75.126.118.184
Verbindungsaufbau zu bintray.com (bintray.com)|75.126.118.184|:443... fehlgeschlagen: Keine Route zum Zielrechner.
$ apt-key add openhab-key.asc
gpg: Keine gültigen OpenPGP-Daten gefunden.
FAILED (key)
[20:59:13] openhabian@openhab:
Maybe someone of you experience the same?
Thanks a lot.
Best Regards,
Matthias
now it works. don’t know what happened.
