Im still working through the 1.8 to 2.0 migration. In general Im new to this but had 1.8 working pretty well with only a few bindings.
wemo,myq,enphase,nest
My issue now is myopenhab is offline. I remember when I setup 1.8 I had to enter the uuid and secret. I do not see this in 2.0. Does it exist?
Some other issues. when using paperui the only bindings I see are wemo and nest but when I use openhab for android I can still control my garage doors.
To get both files you have to install the “openHAB Cloud Connector” add-on first. On Windows you will then find the uuid in directory <Install>\userdata and the secret file in directory <Install>\userdata\openhabcloud.
Hmmm, I tested it with the latest snapshot build on Windows 10 and both files were created when I installed the connector.
There was a similar problem but on Linux: No uuid, secret.
Maybe you can try to uninstanll the connector, restart openHAb and install it again.
It worked this time, I had some issues with other bindings that kept uninstalling. Now that that is resolved after removing and reinstalling the files are there.
