I tried openhab2.2 and now tried openhab2.3 snapshot, I still cannot make my cm11a work. When openhab starts, it gives the following error.
I still see the cm11a controller online in the Thing list. But if I define some X10 things with house and unit codes, they have an error saying UNINITIALIZED - HANDLER_INITIALIZING_ERROR
There is on catch though, I am using RCA HC60CRX which is re-branded by RCA and it should use the same interface. Not sure this is the problem.
2018-01-28 11:36:47.420 [ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method ‘ThingHandler.initialize()’ on ‘org.openhab.binding.cm11a.handler.Cm11aApplianceHandler@2409be3b’: null
at org.openhab.binding.cm11a.handler.Cm11aAbstractHandler.initialize(Cm11aAbstractHandler.java:85) [211:org.openhab.binding.cm11a:2.3.0.201801252322]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:?]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
at org.eclipse.smarthome.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:153) [109:org.eclipse.smarthome.core:0.10.0.201801231340]
at org.eclipse.smarthome.core.internal.common.Invocation.call(Invocation.java:53) [109:org.eclipse.smarthome.core:0.10.0.201801231340]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142) [?:?]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617) [?:?]
at java.lang.Thread.run(Thread.java:745) [?:?]
2018-01-28 11:36:47.443 [ERROR] [ome.core.thing.internal.ThingManager] - Exception occurred while initializing handler of thing ‘cm11a:switch:77c6c76f’: null
2018-01-28 11:36:51.541 [INFO ] [ing.cm11a.handler.Cm11aBridgeHandler] - Initialized CM11A X10 interface on: COM7
