# CO2 Sensors that work with Openhab
**URL:** <https://community.openhab.org/t/co2-sensors-that-work-with-openhab/101297>\
**Category:** DIY\
**Created:** [June 24, 2020, 9:13pm UTC](https://community.openhab.org/t/co2-sensors-that-work-with-openhab/101297 "2020-06-24T21:13:31Z")\
**Posts on this page:** 1\
**Showing post:** 20
<div class="post-metadata">
**Author:** ![m4rk](https://community.openhab.org/user_avatar/community.openhab.org/m4rk/32/49247_2.png) [@m4rk](https://community.openhab.org/u/m4rk)\
**Post date:** [February 8, 2022, 6:48pm UTC](https://community.openhab.org/t/co2-sensors-that-work-with-openhab/101297/20 "2022-02-08T18:48:56Z")
</div>
I use Awair Element to monitor temp, humidity, co2, pm2.5, voc. It seems to be sensitive, accurate, and stable as far as I can tell. Fresh air co2 =400pm. Detects the other half with her creams and potions and quickly detects co2 rise when someone enters the room. It’s not cheap!! It has a phone app and API possibilities. It calibrates when the room is ventilated and has built-in fan to force air over the sensors. The fan is a bit noisy for bedroom use and sensitive ears. Mains powered, no battery
Here is the write-up I made on how to get the data into openhab and Grafana
> [@Awair Element air quality monitor - data charting without using a binding](https://community.openhab.org/t/awair-element-air-quality-monitor-data-charting-without-using-a-binding/119161):
> My setup (Prerequisites for openHAB v3): openHAB3 installed on a RPi4 using openhabian image: [download page](https://www.openhab.org/download/) Grafana and Influx installed via menu. Some familiarity with using these in openHAB will be needed!! Grafana gauges are a plugin called D3 gauge by Brian Gann. To install Influx and Grafana use a console window and open the config menu: sudo openhabian-config … menu item 20-24 HTTP binding installed via openhab addons menu: http://“IP of your openHAB server”:8080/settings/addons A…
_[View the full topic](https://community.openhab.org/t/co2-sensors-that-work-with-openhab/101297)._
