Background: our country’s (South Africa) electrical supply is dodgy, and the provider is implementing loadshedding, effectively shutting down parts of the country’s electrical supply to manage the grid load. It is divided into Phases, with each Phase progressively meaning that you’ll have blackouts more often. We have schedules for these blackouts.
My Narada battery isn’t too good at supporting the Victron inverter to switch over when the grid loses power. To alleviate this, I switch to inverter only mode a few minutes before the blackout.
My switching commands and basic cron jobs are working. I currently do the switch irrespective of whether we have loadshedding or not.
Now to my question: I want to implement a five state switch to only switch over when we do have loadshedding, and only if we have loadshedding at the relevant Phase. But my code is looking terrible. I haven’t verified if the nested ifs work yet, but I’d like to hear if someone can offer suggestions as to better programming practise.
Goal of the code: check if it is 14:55 on the first of the month. (I have a Phase 1 slot at 15:00 on the first, and want to switch 5 minutes before then). Check if there is loadshedding in any of Phases 1-4 (“loadshedding” is a user controlled, 4-state, switch). If both conditions is true, do the switching.
The next portion will be to check for times where I have Phase 2 slots, and check if the “loadshedding” switch is set to Phases 2-4, and switch if necessary.
//rules to switch to "inverter only" before loadshedding starts
rule "loadshedding_before"
//stage 1
when Time cron "0 55 14 1 * ? *"
or Time cron "0 55 22 2 * ? *"
or Time cron "0 55 6 4 * ? *"
or Time cron "0 55 12 5 * ? *"
or Time cron "0 55 20 6 * ? *"
or Time cron "0 55 4 8 * ? *"
or Time cron "0 55 10 9 * ? *"
or Time cron "0 55 18 10 * ? *"
or Time cron "0 55 2 12 * ? *"
or Time cron "0 55 8 13 * ? *"
or Time cron "0 55 16 14 * ? *"
or Time cron "0 55 0 16 * ? *"
or Time cron "0 55 6 17 * ? *"
or Time cron "0 55 14 18 * ? *"
or Time cron "0 55 22 19 * ? *"
or Time cron "0 55 4 21 * ? *"
or Time cron "0 55 12 22 * ? *"
or Time cron "0 55 20 23 * ? *"
or Time cron "0 55 2 25 * ? *"
or Time cron "0 55 10 26 * ? *"
or Time cron "0 55 18 27 * ? *"
or Time cron "0 55 0 29 * ? *"
or Time cron "0 55 8 30 * ? *"
or Time cron "0 55 16 31 * ? *"
if (loadshedding.state.toString == "1" || loadshedding.state.toString == "2" || loadshedding.state.toString == "3" || loadshedding.state.toString == "4")
//logInfo("loadshedding.rules","enter")
sendBroadcastNotification("Loadshedding Phase 1")
//val mqttActions = getActions("mqtt","mqtt:broker:756389ee")
//mqttActions.publishMQTT("W/7c3866560fa4/vebus/261/Mode",'{"value": 2}')
//logInfo("loadshedding.rules","exit")
else when
//stage 2
or Time cron "0 55 6 1 * ? *"
or Time cron "0 55 14 2 * ? *"
or Time cron "0 55 22 3 * ? *"
or Time cron "0 55 4 5 * ? *"
or Time cron "0 55 12 6 * ? *"
or Time cron "0 55 20 7 * ? *"
or Time cron "0 55 2 9 * ? *"
or Time cron "0 55 10 10 * ? *"
or Time cron "0 55 18 11 * ? *"
or Time cron "0 55 0 13 * ? *"
or Time cron "0 55 8 14 * ? *"
or Time cron "0 55 16 15 * ? *"
or Time cron "0 55 6 18 * ? *"
or Time cron "0 55 14 19 * ? *"
or Time cron "0 55 22 20 * ? *"
or Time cron "0 55 4 22 * ? *"
or Time cron "0 55 12 23 * ? *"
or Time cron "0 55 20 24 * ? *"
or Time cron "0 55 2 26 * ? *"
or Time cron "0 55 10 27 * ? *"
or Time cron "0 55 18 28 * ? *"
or Time cron "0 55 0 30 * ? *"
or Time cron "0 55 8 31 * ? *"
if (loadshedding.state.toString == "2" || loadshedding.state.toString == "3" || loadshedding.state.toString == "4")
sendBroadcastNotification("Loadshedding Phase 2")
else when
//stage 3
Time cron "0 55 6 2 * ? *"
or Time cron "0 55 4 6 * ? *"
or Time cron "0 55 12 7 * ? *"
or Time cron "0 55 2 10 * ? *"
or Time cron "0 55 10 11 * ? *"
or Time cron "0 55 0 14 * ? *"
or Time cron "0 55 8 15 * ? *"
or Time cron "0 55 6 19 * ? *"
or Time cron "0 55 4 23 * ? *"
or Time cron "0 55 12 24 * ? *"
or Time cron "0 55 2 27 * ? *"
or Time cron "0 55 10 28 * ? *"
if (loadshedding.state.toString == "3" || loadshedding.state.toString == "4")
sendBroadcastNotification("Loadshedding Phase 3")
else when
//stage 4
Time cron "0 55 22 1 * ? *"
or Time cron "0 55 6 3 * ? *"
or Time cron "0 55 4 7 * ? *"
or Time cron "0 55 12 8 * ? *"
or Time cron "0 55 2 11 * ? *"
or Time cron "0 55 10 12 * ? *"
or Time cron "0 55 16 13 * ? *"
or Time cron "0 55 0 15 * ? *"
or Time cron "0 55 8 16 * ? *"
or Time cron "0 55 6 20 * ? *"
or Time cron "0 55 12 21 * ? *"
or Time cron "0 55 4 24 * ? *"
or Time cron "0 55 10 25 * ? *"
or Time cron "0 55 2 28 * ? *"
or Time cron "0 55 8 29 * ? *"
or Time cron "0 55 1 31 * ? *"
if (loadshedding.state.toString == "4")
sendBroadcastNotification("Loadshedding Phase 4")
