Hallo !
I am a Openhabian User. My Rasberry das two USB sticks. One for Enocean and one for zwave. The zwave controller is Aeotec AEOEZW090-C. Everything fine, then I added a third stick to my Raspberry for Homegear (CUL CC1101).
All works great, except for zwave. The controller is no longer recognized. If I turn off the CUL, then zwave goes again as usual.
I am using / dev / ttyAMA0. And assume that this is the problem.
Config.txt
dtoverlay=pi3-disable-bt
enable_uart=1
dtparam=spi=on
dtparam=i2c_arm=on
Cmdline.txt
wc_otg.lpm_enable=0 console=tty1 root=PARTUUID=395b58d5-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
I added to /etc/default/openhab2
EXTRA_JAVA_OPTS="-Dgnu.io.rxtx.SerialPorts=/dev/ttyUSB0:/dev/ttyS0:/dev/ttyS2:/dev/ttyACM0:/dev/ttyAMA0"
Log
2018-06-23 19:29:56.918 [INFO ] [ing.zwave.handler.ZWaveSerialHandler] - Serial port is initialized 2018-06-23 19:29:56.939 [hingStatusInfoChangedEvent] - 'zwave:device:9ad38bd4:node7' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline 2018-06-23 19:29:56.978 [INFO ] [mmandclass.ZWaveSecurityCommandClass] - Update networkKey 2018-06-23 19:29:56.991 [hingStatusInfoChangedEvent] - 'zwave:device:9ad38bd4:node3' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING 2018-06-23 19:29:57.158 [hingStatusInfoChangedEvent] - 'zwave:device:9ad38bd4:node2' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING 2018-06-23 19:29:57.174 [hingStatusInfoChangedEvent] - 'zwave:device:9ad38bd4:node3' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline 2018-06-23 19:29:57.190 [hingStatusInfoChangedEvent] - 'zwave:device:9ad38bd4:node2' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline 2018-06-23 19:29:57.231 [INFO ] [ve.internal.protocol.ZWaveController] - Starting ZWave controller 2018-06-23 19:29:57.238 [INFO ] [ve.internal.protocol.ZWaveController] - ZWave timeout is set to 5000ms. Soft reset is false. 2018-06-23 19:29:57.417 [hingStatusInfoChangedEvent] - 'zwave:device:9ad38bd4:node4' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING 2018-06-23 19:29:57.436 [hingStatusInfoChangedEvent] - 'zwave:device:9ad38bd4:node5' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING 2018-06-23 19:29:57.444 [hingStatusInfoChangedEvent] - 'zwave:device:9ad38bd4:node5' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline 2018-06-23 19:29:57.489 [hingStatusInfoChangedEvent] - 'zwave:device:9ad38bd4:node4' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline 2018-06-23 19:29:57.496 [hingStatusInfoChangedEvent] - 'zwave:device:9ad38bd4:node9' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING 2018-06-23 19:29:57.521 [hingStatusInfoChangedEvent] - 'zwave:device:9ad38bd4:node9' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline 2018-06-23 19:29:57.528 [hingStatusInfoChangedEvent] - 'zwave:device:9ad38bd4:node8' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING 2018-06-23 19:29:57.546 [hingStatusInfoChangedEvent] - 'zwave:device:9ad38bd4:node8' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline 2018-06-23 19:29:57.553 [hingStatusInfoChangedEvent] - 'zwave:device:9ad38bd4:node6' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING 2018-06-23 19:29:57.568 [hingStatusInfoChangedEvent] - 'zwave:device:9ad38bd4:node6' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline 2018-06-23 19:30:35.142 [INFO ] [age.SerialApiGetInitDataMessageClass] - ZWave Controller using Controller API 2018-06-23 19:30:35.146 [INFO ] [age.SerialApiGetInitDataMessageClass] - ZWave Controller is Primary Controller 2018-06-23 19:30:35.150 [INFO ] [age.SerialApiGetInitDataMessageClass] - ------------Number of Nodes Found Registered to ZWave Controller------------ 2018-06-23 19:30:42.941 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:9ad38bd4' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE 2018-06-23 19:30:42.992 [hingStatusInfoChangedEvent] - 'zwave:device:9ad38bd4:node7' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE 2018-06-23 19:30:43.016 [hingStatusInfoChangedEvent] - 'zwave:device:9ad38bd4:node9' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE 2018-06-23 19:30:43.025 [hingStatusInfoChangedEvent] - 'zwave:device:9ad38bd4:node6' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE 2018-06-23 19:30:43.032 [hingStatusInfoChangedEvent] - 'zwave:device:9ad38bd4:node8' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE 2018-06-23 19:30:43.044 [hingStatusInfoChangedEvent] - 'zwave:device:9ad38bd4:node2' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE 2018-06-23 19:30:43.050 [hingStatusInfoChangedEvent] - 'zwave:device:9ad38bd4:node3' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE 2018-06-23 19:30:43.053 [me.event.ThingUpdatedEvent] - Thing 'zwave:device:9ad38bd4:node9' has been updated. 2018-06-23 19:30:43.114 [hingStatusInfoChangedEvent] - 'zwave:device:9ad38bd4:node4' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE 2018-06-23 19:30:43.126 [hingStatusInfoChangedEvent] - 'zwave:device:9ad38bd4:node5' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE 2018-06-23 19:30:43.167 [me.event.ThingUpdatedEvent] - Thing 'zwave:device:9ad38bd4:node6' has been updated. 2018-06-23 19:30:47.854 [hingStatusInfoChangedEvent] - 'zwave:device:9ad38bd4:node6' changed from ONLINE to ONLINE: Node initialising: PROTOINFO 2018-06-23 19:30:47.864 [hingStatusInfoChangedEvent] - 'zwave:device:9ad38bd4:node3' changed from ONLINE to ONLINE: Node initialising: PROTOINFO 2018-06-23 19:30:47.873 [hingStatusInfoChangedEvent] - 'zwave:device:9ad38bd4:node5' changed from ONLINE to ONLINE: Node initialising: PROTOINFO 2018-06-23 19:30:47.884 [hingStatusInfoChangedEvent] - 'zwave:device:9ad38bd4:node4' changed from ONLINE to ONLINE: Node initialising: PROTOINFO 2018-06-23 19:30:47.899 [hingStatusInfoChangedEvent] - 'zwave:device:9ad38bd4:node9' changed from ONLINE to ONLINE: Node initialising: PROTOINFO 2018-06-23 19:30:47.907 [hingStatusInfoChangedEvent] - 'zwave:device:9ad38bd4:node2' changed from ONLINE to ONLINE: Node initialising: PROTOINFO 2018-06-23 19:31:33.769 [hingStatusInfoChangedEvent] - 'zwave:device:9ad38bd4:node3' changed from ONLINE: Node initialising: PROTOINFO to ONLINE: Node initialising: INIT_NEIGHBORS 2018-06-23 19:31:33.790 [hingStatusInfoChangedEvent] - 'zwave:device:9ad38bd4:node5' changed from ONLINE: Node initialising: PROTOINFO to ONLINE: Node initialising: INIT_NEIGHBORS 2018-06-23 19:31:33.807 [hingStatusInfoChangedEvent] - 'zwave:device:9ad38bd4:node4' changed from ONLINE: Node initialising: PROTOINFO to ONLINE: Node initialising: INIT_NEIGHBORS 2018-06-23 19:31:33.819 [hingStatusInfoChangedEvent] - 'zwave:device:9ad38bd4:node9' changed from ONLINE: Node initialising: PROTOINFO to ONLINE: Node initialising: INIT_NEIGHBORS 2018-06-23 19:31:33.836 [hingStatusInfoChangedEvent] - 'zwave:device:9ad38bd4:node2' changed from ONLINE: Node initialising: PROTOINFO to ONLINE: Node initialising: INIT_NEIGHBORS 2018-06-23 19:31:33.853 [hingStatusInfoChangedEvent] - 'zwave:device:9ad38bd4:node6' changed from ONLINE: Node initialising: PROTOINFO to ONLINE: Node initialising: INIT_NEIGHBORS 2018-06-23 19:31:33.997 [hingStatusInfoChangedEvent] - 'zwave:device:9ad38bd4:node3' changed from ONLINE: Node initialising: INIT_NEIGHBORS to ONLINE: Node initialising: FAILED_CHECK 2018-06-23 19:31:34.022 [hingStatusInfoChangedEvent] - 'zwave:device:9ad38bd4:node5' changed from ONLINE: Node initialising: INIT_NEIGHBORS to ONLINE: Node initialising: FAILED_CHECK 2018-06-23 19:31:34.050 [hingStatusInfoChangedEvent] - 'zwave:device:9ad38bd4:node4' changed from ONLINE: Node initialising: INIT_NEIGHBORS to ONLINE: Node initialising: FAILED_CHECK 2018-06-23 19:31:34.076 [hingStatusInfoChangedEvent] - 'zwave:device:9ad38bd4:node9' changed from ONLINE: Node initialising: INIT_NEIGHBORS to ONLINE: Node initialising: FAILED_CHECK 2018-06-23 19:31:34.099 [hingStatusInfoChangedEvent] - 'zwave:device:9ad38bd4:node2' changed from ONLINE: Node initialising: INIT_NEIGHBORS to ONLINE: Node initialising: FAILED_CHECK 2018-06-23 19:31:34.121 [hingStatusInfoChangedEvent] - 'zwave:device:9ad38bd4:node6' changed from ONLINE: Node initialising: INIT_NEIGHBORS to ONLINE: Node initialising: FAILED_CHECK 2018-06-23 19:31:34.134 [hingStatusInfoChangedEvent] - 'zwave:device:9ad38bd4:node3' changed from ONLINE: Node initialising: FAILED_CHECK to ONLINE: Node initialising: WAIT 2018-06-23 19:31:34.141 [hingStatusInfoChangedEvent] - 'zwave:device:9ad38bd4:node3' changed from ONLINE: Node initialising: WAIT to ONLINE: Node initialising: PING 2018-06-23 19:31:34.153 [hingStatusInfoChangedEvent] - 'zwave:device:9ad38bd4:node5' changed from ONLINE: Node initialising: FAILED_CHECK to ONLINE: Node initialising: WAIT 2018-06-23 19:31:34.162 [hingStatusInfoChangedEvent] - 'zwave:device:9ad38bd4:node5' changed from ONLINE: Node initialising: WAIT to ONLINE: Node initialising: PING 2018-06-23 19:31:34.178 [hingStatusInfoChangedEvent] - 'zwave:device:9ad38bd4:node4' changed from ONLINE: Node initialising: FAILED_CHECK to ONLINE: Node initialising: WAIT 2018-06-23 19:31:34.190 [hingStatusInfoChangedEvent] - 'zwave:device:9ad38bd4:node4' changed from ONLINE: Node initialising: WAIT to ONLINE: Node initialising: PING 2018-06-23 19:31:34.197 [hingStatusInfoChangedEvent] - 'zwave:device:9ad38bd4:node9' changed from ONLINE: Node initialising: FAILED_CHECK to ONLINE: Node initialising: WAIT 2018-06-23 19:31:34.205 [hingStatusInfoChangedEvent] - 'zwave:device:9ad38bd4:node9' changed from ONLINE: Node initialising: WAIT to ONLINE: Node initialising: PING 2018-06-23 19:31:34.214 [hingStatusInfoChangedEvent] - 'zwave:device:9ad38bd4:node2' changed from ONLINE: Node initialising: FAILED_CHECK to ONLINE: Node initialising: WAIT 2018-06-23 19:31:34.219 [hingStatusInfoChangedEvent] - 'zwave:device:9ad38bd4:node2' changed from ONLINE: Node initialising: WAIT to ONLINE: Node initialising: PING 2018-06-23 19:31:34.236 [hingStatusInfoChangedEvent] - 'zwave:device:9ad38bd4:node6' changed from ONLINE: Node initialising: FAILED_CHECK to ONLINE: Node initialising: WAIT 2018-06-23 19:31:34.247 [hingStatusInfoChangedEvent] - 'zwave:device:9ad38bd4:node6' changed from ONLINE: Node initialising: WAIT to ONLINE: Node initialising: PING 2018-06-23 19:31:34.275 [hingStatusInfoChangedEvent] - 'zwave:device:9ad38bd4:node9' changed from ONLINE: Node initialising: PING to ONLINE 2018-06-23 19:31:34.289 [hingStatusInfoChangedEvent] - 'zwave:device:9ad38bd4:node9' changed from ONLINE to ONLINE: Node initialising: DETAILS 2018-06-23 19:31:34.299 [hingStatusInfoChangedEvent] - 'zwave:device:9ad38bd4:node9' changed from ONLINE: Node initialising: DETAILS to ONLINE: Node initialising: GET_CONFIGURATION
Thanks for any hint or help.`
Bernhard
