Dear Community
thx for all the great work you are doing.
I’m starting to migrate my home automation system to OH3 and while doing this I started to create a custom widget.
I define colors for oh-knobs and for oh-links (to draw F7 icons) using the using the color: … keyword inside the widget definition.
However, I noticed that if I use e.g. color “blue” in the oh-link section (picked color shows: #4A94EC) this blue looks different then the color “blue” definition for oh-cards background (picked color shows: #A4CAF6) and also different from the primaryColor “blue” definition for the oh-knob (picked color shows: #0C00F5). I can align the primaryColor for the knob and the oh-cards background but the oh-link will only accept textual color names - no hex definitions or something like this.
Is there a way to set the color of the oh-link other then with a color name, or can I make an over-all “blue” definition?
I’m sure you guys can explain this behavior easily.
I’ve attached a screenshot that should illustrate the problem.
Thx for your support /jeko
