I try to use Homekit and Alexa with my OpenHab 2.2 Configuration.
Unfortunately I have some issues I can’t solve on myself.
I want to manage all items in Openhab. I don’t want create groups in Alexa or Homekit.
My Items look like that:
//Wohnzimmer Stehlampe Sofa Links///
Color Light_Living_Sofa_Links_1_Color "Farbe" <ColorLight> (GroupDimmer_Lights_Living, GroupColor_Lights_Living) { channel="hue:0210:0017884ab0d6:4:color" }
Alexa finds all tagged Items and in my home app there are also listed.
But the items are not correctly implemented:
The items are only recognized as “Switches” in Alexa. But I am able to dim the lights.
The Items in Homekit can only be switched on/off.
I am not able to change the Color of the bulbs.
In this version there is one Color Group which have got one dimmer bulb and one color bulb.
I also tried a group with only color lights; without luck.
Do you have some ideas how to solve these problems?
TIA
I do not know if that works with groups in openhab, but I use it like this:
Every lamp configured individually for homekit
assign the lamps to the same room
Then you can say “Switch room to green” to SIRI
yes, this should work.
But than i have to managed my groups/rooms in different systems several times.
I hope i will find a solution to configure the setup just in one place (openhab)
I have a similar problem, I am grouping DMX/Artnet-lights with the groups.
Alexa and Googlehome are recognizing the Group:Color item as Coloritems and I can set colors with voicecommands. In Homekit it only shows up as switch.
When I put the Group:Color item in a sitemap I can choose colors with the colorpicker but in contrast to the dimmer and switch-item changes on single items in that group are not reflected in the group-colorpickeritem.
I don’t know if there is a problem that the HSB-Value is not returned to the group in any way like in the switch or dimmer-item. I tried things like Group:color:MAX, …MIN, …SUM but nothing worked.
MDAR
#7
Hi
I have a couple of Art-NET lights I would like to set the colour of via Google Assistant.
Can you explain how you have this working please?
I have tried adding the tag “Color” or “Colour” to the colorpicker Item but it just isn’t detected by Google Assistant.
