tnemrap
(Michael Parment)
July 3, 2021, 5:43pm
1
I have a rule for presence simulation and have problem with my color items.
I use JDBC MariaDB as persistence.
when i use
light.historicState(ZonedDateTime.now().minusDays(7), persistence).state.toString
i get on all color items
Script execution of rule with UID 'Simulering' failed: class java.lang.String cannot be cast to class java.lang.Integer (java.lang.String and java.lang.Integer are in module java.base of loader 'bootstrap')
They are stored in MariaDB as varchar as e.g. 184,100,52.
All other items works ok.
What can be the problem?
/Mike
cweitkamp
(Christoph Weitkamp)
February 6, 2022, 12:58pm
2
I submitted a fix for this
openhab:main
← cweitkamp:bugfix-12218-jdbc-coloritem
opened 12:57PM - 06 Feb 22 UTC
- Fixed ClassCastException for `ColorItem` / `HSBType`
Fixes #12218
Signe… d-off-by: Christoph Weitkamp <github@christophweitkamp.de>
Thanks for contributing to the openHAB project!
Please describe the goal and effect of your PR here.
Pay attention to the below notes and to *the guidelines* for this repository.
Feel free to delete any comment sections in the template (starting with "<!--").
ATTENTION: Don't use "git merge" when working with your pull request branch!
This can clutter your Git history and make your PR unuseable.
Use "git rebase" instead. See this forum post for further details:
https://community.openhab.org/t/rebase-your-code-or-how-to-fix-your-git-history-before-requesting-a-pull/129358
Add one or more appropriate labels to make your PR show up in the release notes.
E.g. enhancement, bug, documentation, new binding
This can only be done by yourself if you already contributed to this repo.
If your PR's code is not backward compatible with previous releases (which
should be avoided), add a message to the release notes by filing another PR:
https://github.com/openhab/openhab-distro/blob/main/distributions/openhab/src/main/resources/bin/update.lst
# Title
Provide a short summary in the *Title* above. It will show up in the release notes.
For example:
- [homematic] Improve communication with weak signal devices
- [timemachine][WIP] Initial contribution
# Description
Please give a few sentences describing the overall goals of the pull request.
Give enough details to make the improvement and changes of the PR understandable
to both developers and tech-savy users.
Please keep the following in mind:
- What is the classification of the PR, e.g. Bugfix, Improvement, Novel Addition, ... ?
- Did you describe the PRs motivation and goal?
- Did you provide a link to any prior discussion, e.g. an issue or community forum thread?
- Did you describe new features for the end user?
- Did you describe any noteworthy changes in usage for the end user?
- Was the documentation updated accordingly, e.g. the add-on README?
- Does your contribution follow the coding guidelines:
https://www.openhab.org/docs/developer/guidelines.html
- Did you check for any (relevant) issues from the static code analysis:
https://www.openhab.org/docs/developer/bindings/#include-the-binding-in-the-build
- Did you sign-off your work:
https://www.openhab.org/docs/developer/contributing.html#sign-your-work
# Testing
Your pull request will automatically be built and available under the following folder:
https://openhab.jfrog.io/ui/native/libs-pullrequest-local/org/openhab/addons/bundles/
It is a good practice to add a URL to your built JAR in this pull request description,
so it is easier for the community to test your Add-on.
If your pull request contains a new binding, it will likely take some time
before it is reviewed and processed by maintainers.
That said, consider submitting your Add-on in the Marketplace:
https://community.openhab.org/c/marketplace/69
Don't forget to submit a thread about your Add-on in the openHAB community:
https://community.openhab.org/c/add-ons
