Color_temp in google assistant
TRADFRI bulb E14 WS 470lm with homekit and google ass - bulb works on mired value not Kelvin 250-454 range.
Group Swiatlo1 "Lampa 1"        { homekit="Lighting", ga="Light" [ colorTemperatureRange="250,454" ]}
            Switch ZigbeeKitchenBulbSwitch           "1 [%s]"              <light>                      (Swiatlo1) { homekit="Lighting.OnState", ga="lightPower", channel="mqtt:topic:mymqttbroker:ikeabulb01:switch"}
            Number ZigbeeKitchenBulbColorTemperature "1 [%s]"              <light>                      (Swiatlo1) { homekit="Lighting.ColorTemperature" [minValue=250, maxValue=454], ga="lightColorTemperature", channel="mqtt:topic:mymqttbroker:ikeabulb01:color_temp"}
            Dimmer ZigbeeKitchenBulbDim              "1 [%s]"              <light>                      (Swiatlo1) { homekit="Lighting.Brightness", ga="lightBrightness", channel="mqtt:topic:mymqttbroker:ikeabulb01:dimmer"}
            Number ZigbeeKitchenBulbQuality          "1 LinkQuality [%d]"  <qualityofservice>           (Swiatlo1) {channel="mqtt:topic:mymqttbroker:ikeabulb01:linkquality" }
Homekit is working ok. GA not:
docs:
(optional) useKelvin=true/false
(optional) colorTemperatureRange="minK,maxK"
Hint: if you want to use lightColorTemperature you either need to set useKelvin=true or colorTemperatureRange
can it be fixed in ga binding - on my setup i receive negative values from google home app
 Item 'ZigbeeKitchenBulbColorTemperature' received command -2718.6274509803925
2022-04-01 09:09:41.024 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'ZigbeeKitchenBulbColorTemperature' predicted to become -2718.6274509803925
2022-04-01 09:09:41.035 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZigbeeKitchenBulbColorTemperature' changed from 250 to -2718.6274509803925
2022-04-01 09:09:41.136 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZigbeeKitchenBulbQuality' changed from 51 to 54
2022-04-01 09:09:41.155 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZigbeeKitchenBulbColorTemperature' changed from -2718.6274509803925 to 250
2022-04-01 09:12:07.593 [INFO ] [openhab.event.ItemCommandEvent      ] - Item 'ZigbeeKitchenBulbColorTemperature' received command -2718.6274509803925
2022-04-01 09:12:07.609 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'ZigbeeKitchenBulbColorTemperature' predicted to become -2718.6274509803925
2022-04-01 09:12:07.619 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZigbeeKitchenBulbColorTemperature' changed from 250 to -2718.6274509803925
2022-04-01 09:12:07.745 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZigbeeKitchenBulbColorTemperature' changed from -2718.6274509803925 to 250
2022-04-01 09:12:15.648 [INFO ] [openhab.event.ItemCommandEvent      ] - Item 'ZigbeeKitchenBulbColorTemperature' received command -2228.4313725490197
2022-04-01 09:12:15.652 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'ZigbeeKitchenBulbColorTemperature' predicted to become -2228.4313725490197
2022-04-01 09:12:15.661 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZigbeeKitchenBulbColorTemperature' changed from 250 to -2228.4313725490197
2022-04-01 09:12:15.776 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZigbeeKitchenBulbColorTemperature' changed from -2228.4313725490197 to 250
2022-04-01 09:12:15.817 [INFO ] [openhab.event.ItemCommandEvent      ] - Item 'ZigbeeKitchenBulbColorTemperature' received command -1738.235294117647
2022-04-01 09:12:15.823 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'ZigbeeKitchenBulbColorTemperature' predicted to become -1738.235294117647
2022-04-01 09:12:15.828 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZigbeeKitchenBulbColorTemperature' changed from 250 to -1738.235294117647
2022-04-01 09:12:15.932 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZigbeeKitchenBulbColorTemperature' changed from -1738.235294117647 to 250
2022-04-01 09:12:26.251 [INFO ] [openhab.event.ItemCommandEvent      ] - Item 'ZigbeeKitchenBulbColorTemperature' received command -1248.0392156862745
2022-04-01 09:12:26.258 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'ZigbeeKitchenBulbColorTemperature' predicted to become -1248.0392156862745
2022-04-01 09:12:26.264 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZigbeeKitchenBulbColorTemperature' changed from 250 to -1248.0392156862745
2022-04-01 09:12:26.385 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZigbeeKitchenBulbColorTemperature' changed from -1248.0392156862745 to 250
2022-04-01 09:12:31.366 [INFO ] [openhab.event.ItemCommandEvent      ] - Item 'ZigbeeKitchenBulbColorTemperature' received command -757.8431372549019
2022-04-01 09:12:31.372 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'ZigbeeKitchenBulbColorTemperature' predicted to become -757.8431372549019
2022-04-01 09:12:31.379 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZigbeeKitchenBulbColorTemperature' changed from 250 to -757.8431372549019
2022-04-01 09:12:31.495 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZigbeeKitchenBulbColorTemperature' changed from -757.8431372549019 to 250
