Hey,
im experiencing a bug when trying the colorpicker “Ackolor style”. Im trying to get the widget to work with my yeelight but its just showing the color. If im trying to click on it the popup does just rarely show up and after picking nothing happens.
Here my error in console: x replaces https and ip:port cuz of restrictions
Hey thanks for reply
The HSL slider is writing this indeed but I cant trigger the ackolor style to show up and have a look. I’ve also tried the “yeelight widget” from the gallery, its not working either…
The items state is a hexa grafik|690x135
I tried the color function but it doesnt show up either
i got the popup to show up with the “scene_name” item which is empty and this is what im getting in the iobroker log when i pick a color. The browsers Inspector is showing the same error as meantioned in the first post
host.raspberrypi
2020-05-28 12:36:46.397
info
Restart adapter system.adapter.yeelight-2.0 because enabled
host.raspberrypi
info
instance system.adapter.yeelight-2.0 terminated with code 0 (NO_ERROR)
host.raspberrypi
2020-05-28 12:36:46.396
error
Caught by controller[0]: at processImmediate (internal/timers.js:456:21)
host.raspberrypi
error
Caught by controller[0]: at Immediate. (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4855:34)
host.raspberrypi
error
Caught by controller[0]: at Adapter.emit (events.js:315:20)
host.raspberrypi
2020-05-28 12:36:46.395
error
Caught by controller[0]: at Adapter. (/opt/iobroker/node_modules/iobroker.yeelight-2/main.js:44:21)
host.raspberrypi
error
Caught by controller[0]: at uploadState (/opt/iobroker/node_modules/iobroker.yeelight-2/main.js:111:39)
host.raspberrypi
error
Caught by controller[0]: at Object.parse (/opt/iobroker/node_modules/circular-json/build/circular-json.node.js:196:32)
host.raspberrypi
2020-05-28 12:36:46.394
error
Caught by controller[0]: at JSON.parse ()
host.raspberrypi
2020-05-28 12:36:46.393
error
Caught by controller[0]: SyntaxError: Unexpected token N in JSON at position 0
yeelight-2.0
2020-05-28 12:36:45.855
info
(14008) Terminated (NO_ERROR): Without reason
yeelight-2.0
2020-05-28 12:36:45.853
info
(14008) terminating
yeelight-2.0
2020-05-28 12:36:45.790
info
(14008) cleaned everything up…
yeelight-2.0
2020-05-28 12:36:45.786
error
(14008) SyntaxError: Unexpected token N in JSON at position 0 at JSON.parse () at Object.parse (/opt/iobroker/node_modules/circular-json/build/circular-json.node.js:196:32) at u
yeelight-2.0
2020-05-28 12:36:45.783
error
(14008) uncaught exception: Unexpected token N in JSON at position 0
