Hi all,
I have openhab 1 running on a Pi and want to control RGBW LED strip connected to an ESP8266 wifi node from openhab .
white LED (ch4) can be turned on and off from openhab but the RGB LEDs do not respond.
MQTT spy shows nothing gets published when using the color picker.
In items I have ..
Group WIFI_RGB_2 "WiFi RGB 2" (All)
Color fWIFI_RGB_2 "RGB" <slider> (WIFI_RGB_2)
String WIFI_RGB_2_RGB (WIFI_RGB_2) {mqtt=">[broker:/openHAB/RGB_2/Color:command:*:default]"}
Switch WIFI_RGB_2_Switch1 "W1" (WIFI_RGB_2) {mqtt=">[broker:/openHAB/RGB_2 /SW1:command:ON:100],>[broker:/openHAB/RGB_2/SW1:command:OFF:0]"}
In rules I have …
import org.openhab.core.library.types.*
var HSBType hsbValue
var int redValue
var int greenValue
var int blueValue
var String RGBvalues
rule "Set RGB 2 value"
Item fWIFI_RGB_2 changed
hsbValue = fWIFI_RGB_2.state as HSBType
redValue = hsbValue.red.intValue
greenValue = hsbValue.green.intValue
blueValue = hsbValue.blue.intValue
RGBvalues= redValue.toString + ";" + greenValue.toString + ";" + blueValue.toString
sendCommand( WIFI_RGB_2_RGB, RGBvalues )
logInfo( "fWIFI_RGB_2", RGBvalues )
In sitemap I have …
Frame label="RGB" {
Colorpicker item=fWIFI_RGB_2 icon="slider"
Switch item=WIFI_RGB_2_Switch1 label="Ch4"
In openhab.log …
2018-07-24 18:58:23.840 [ERROR] [o.u.i.items.ItemUIRegistryImpl] - Cannot retrieve item fWIFI_RGB_2 for widget org.openhab.model.sitemap.Colorpicker
org.openhab.core.items.ItemNotFoundException: Item 'WIFI_RGB_2_Switch1' could not be found in the item registry
2018-07-24 18:58:14.200 [INFO ] [c.internal.ModelRepositoryImpl] - Refreshing model 'default.sitemap'
2018-07-24 18:58:22.293 [ERROR] [o.u.i.items.ItemUIRegistryImpl] - Cannot retrieve item fWIFI_RGB_2 for widget org.openhab.model.sitemap.Colorpicker
2018-07-24 18:58:22.311 [ERROR] [o.u.i.items.ItemUIRegistryImpl] - Cannot retrieve item fWIFI_RGB_2 for widget org.openhab.model.sitemap.Colorpicker
2018-07-24 18:58:22.350 [ERROR] [o.u.i.items.ItemUIRegistryImpl] - Cannot retrieve item fWIFI_RGB_2 for widget org.openhab.model.sitemap.Colorpicker
2018-07-24 18:58:22.364 [ERROR] [o.u.i.items.ItemUIRegistryImpl] - Cannot retrieve item fWIFI_RGB_2 for widget org.openhab.model.sitemap.Colorpicker
2018-07-24 18:58:22.479 [WARN ] [.o.u.w.i.render.SwitchRenderer] - Cannot determine item type of 'WIFI_RGB_2_Switch1'
2018-07-24 18:58:22.511 [ERROR] [o.u.i.items.ItemUIRegistryImpl] - Cannot retrieve item WIFI_RGB_2_Switch1 for widget org.openhab.model.sitemap.Switch
2018-07-24 18:58:22.540 [ERROR] [o.u.i.items.ItemUIRegistryImpl] - Cannot retrieve item WIFI_RGB_2_Switch1 for widget org.openhab.model.sitemap.Switch
2018-07-24 18:58:22.590 [ERROR] [o.u.i.items.ItemUIRegistryImpl] - Cannot retrieve item WIFI_RGB_2_Switch1 for widget org.openhab.model.sitemap.Switch
2018-07-24 18:58:22.595 [ERROR] [o.u.i.items.ItemUIRegistryImpl] - Cannot retrieve item WIFI_RGB_2_Switch1 for widget org.openhab.model.sitemap.Switch
2018-07-24 18:58:22.849 [ERROR] [o.u.i.items.ItemUIRegistryImpl] - Cannot retrieve item teac2 for widget org.openhab.model.sitemap.Slider
2018-07-24 18:58:22.883 [ERROR] [o.u.i.items.ItemUIRegistryImpl] - Cannot retrieve item teac2 for widget org.openhab.model.sitemap.Slider
2018-07-24 18:58:22.923 [ERROR] [o.u.i.items.ItemUIRegistryImpl] - Cannot retrieve item teac2 for widget org.openhab.model.sitemap.Slider
2018-07-24 18:58:23.856 [ERROR] [o.u.i.items.ItemUIRegistryImpl] - Cannot retrieve item fWIFI_RGB_2 for widget org.openhab.model.sitemap.Colorpicker
2018-07-24 18:58:23.879 [ERROR] [o.u.i.items.ItemUIRegistryImpl] - Cannot retrieve item fWIFI_RGB_2 for widget org.openhab.model.sitemap.Colorpicker
2018-07-24 18:58:23.889 [ERROR] [o.u.i.items.ItemUIRegistryImpl] - Cannot retrieve item fWIFI_RGB_2 for widget org.openhab.model.sitemap.Colorpicker
2018-07-24 18:58:23.995 [WARN ] [.o.u.w.i.render.SwitchRenderer] - Cannot determine item type of 'WIFI_RGB_2_Switch1'
Can anyone explain why the color picker is not publishing to MQTT and how to fix it ?
Can post more logs if needed.
